6.4L Power Stroke Engine and DrivetrainDiscussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008 Super-Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
To make a long story short, running low on coolant. Yep, Job 1. Have not taken a really close look under the truck, but I know we're leaking coolant somewhere. So I had to top the reservoir off with something. Only thing I could get my hands on at the time was some green Prestone 50/50. After the fact I realized the Motorcraft guide states that you should only use Motorcraft gold.
Is this a ploy to get more of my $ than they already have, and have I made a major blunder, or am I OK?
By the way, taking the truck into the shop to have it looked after and get those safety recalls taken care of. Also thinking about persuading the tech to perform a reflash. More details later.
2008 6.4L F250 CC 4x4 Lariat, Job 1, Silver Metallic, Torqueshift 5spd Auto, 3.73, ESOF, Block Heater, Camper Pkg, Offroad Pkg, Audiophile Stereo, Captains Chairs, Heated Seats, Tow Command, Upfitter Switches, working on the B&W Turnover Ball Gooseneck Hitch... and lovin' every bit of it!!!
Any antifreeze that is the same chemical formula as Motorcraft Premium Gold is okay. Zerex G-05 is the same thing. And there are some other brands that make a G-05 too, but I stick to either Motorcraft or Zerex. I have found Zerex G-05 at Autozone, but they don't always have it in stock. G-05® Antifreeze/ Coolant
Not a "major" blunder, but a blunder nevertheless. In a nutshell, you have ruined your coolant, and it needs to be flushed out pretty soon. No emergency, but I would do it within a few weeks or a few thousand miles. And I wouldn't trust any dealer or quick-lube place to do it right. So do it yourself (DIY).
Plain ole Prestone green antifreeze (no longer available) was high silicate. It was never intended for use in diesel engines because it doesn't work right with supplemental coolant additive(SCA). And if you have green antifreeze mixed with your G-05, then you must maintain th SCA level in the coolant as though it were green antifreeze.
So in effect, the old Prestone green antifreeze mixed with G-05 coolant will be fine for a gasoline engine, but it ruins the coolant for use in a diesel engine.
The Fleetguard page 444-4D linked mentions that it's okay to mix Prestone Heavy Duty antifreeze with various Fleetguard antifreeze formulas. Prestone Heavy duty is intended for use in diesel engines when SCA is maintained in the coolant. But you didn't use Heavy Duty (in the black jug), it sounds like you used plain ole high-silicon Prestone in the yellow jug. And that article makes no mention of high-silicone Prestone being mixed with antifreeze being used in diesel engines.
So I'll repeat, you have ruined your coolant for use in a diesel engine.
Thanks for all the feedback. I put about a half gallon of 50/50 in the reservoir. This was the end of last week. So I'll get it taken care of bright and early Saturday morning. Then again, I'll be into the dealer first thing Monday for a possible rad replacement, so I might wait until then. Either way, not making this mistake again... I'll have a gallon of the gold in my truck box at all times from now on. Lesson learned.
