Intermittent oil light at start up - Diesel Forum - TheDieselStop.com
 1Likes
  • 1 Post By wingnut60
post #1 of 4 (permalink) Old 04-20-2017, 05:33 PM Thread Starter
I have a 2008 f250 6.4 with 99k on it. Runs great but when first started the oil lamp comes on for a half second. Do not remember ever seeing that previously. Oil is full. Should I be concerned and what could be causing this? Never comes on again after it is running. Just for a split second when first started. Any help would be appreciated. Love this truck and do not want to hurt it.
gregslife51 is offline
post #2 of 4 (permalink) Old 04-20-2017, 07:05 PM
I had the same issue and what fixed it for me was replacing the aftermarket oil filter plastic housing with an OEM version. I swore that wouldn't make any difference, but several reputable diesel mechanic friends told me that try it and sure enough it worked. Comparing the two side-by-side I couldn't tell you what the difference was, but damned if it didn't fix my issue.
Sent from my XT1585 using Tapatalk
diode_ee is offline
post #3 of 4 (permalink) Old 04-21-2017, 09:41 PM
wingnut60's Avatar
I think the after-market filter/housing cap is allowing draindown of oil after shutdown--based on diode_ee post, that is probably the problem. Only use Ford/Motorcraft filters and OEM caps/housings--there is a difference. And on the fuel filters also--if you ever get a no-start after changing the fuel filter with anything other than a Motorcraft, then immediately replace with MC and bleed air off.
ford_doctor likes this.
2010 F450 Lariat 4x4--died, but reborn
2009 F450 Lariat 4x4--died, scrapped
2007 F350 KR DRW CC 4x4-Gone to pasture
2015 Mobile Suites 38RSSA--hoping for another 10 years
2005 Mobile Suites 36TK3--traded, 10 years of camping memories
wingnut60 is offline
post #4 of 4 (permalink) Old Yesterday, 06:15 AM
That was my thinking on what was causing the light. The difference is very slight as it wasn't evident when comparing then side-by-side
diode_ee is offline
  Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 6.4L Power Stroke Engine and Drivetrain
