Job 1 truck? - Diesel Forum - TheDieselStop.com
Old 10-21-2009, 09:06 PM   #1 (permalink)
Job 1 truck?
I think I have a job 1 truck but I don't know how to tell. What are the issues with the job 1 that I should go address with the dealer now?
'08 F250 SD CC 4x4 6.4 PSD
Lancelot is offline
Old 10-21-2009, 10:55 PM   #2 (permalink)
softballdad's Avatar
I have a JOB 1 as well, and have had no major issues in the 33K I've put on it.
JOB 1 '08 F-350 4X4 LARIAT CC 6.4 DRW 4.10
B&W COMPANION 5TH WHEEL HITCH
EDGE INSIGHT GAUGE CLUSTER
FORD MOBIL EASE HANDS FREE SYSTEM
08 HEARTLAND BIGHORN 3670RL
softballdad is offline
Old 10-22-2009, 05:14 AM   #3 (permalink)
senix's Avatar
What is your date of manufacture? That will tell the job series. I will have to look it up to be accurate but a job1 ran up to Jan 08, then job 2 for a couple of months and then job 3 late winter. Mine is a job 3 mar 08.
08F250 CC 6.4 PSD
Banks 6 gun/ram air
40' Stoneridge 5th wheel, coming in at 14K.
senix is offline
Old 10-22-2009, 08:40 AM   #4 (permalink)
StanMI's Avatar
Mine's a Job 1. No issues.
2008 F350 Lariat CC Black two tone and darn near everything else.
StanMI is offline
Old 10-22-2009, 10:33 AM   #5 (permalink)
Job 2 began around Aug 1 or Sept 1 of 07. Job 3 around Jan 08. All +/- a little.
'08 F350 Lariat CC 6.4 DRW 4.10 4x4 manual hubs and 62 gal fuel tank.
rskeans is offline
Old 10-22-2009, 11:10 AM   #6 (permalink)
senix's Avatar
I really couldn't recall. thanks
08F250 CC 6.4 PSD
Banks 6 gun/ram air
senix is offline
Old 10-22-2009, 01:06 PM   #7 (permalink)
chuck_s_jr's Avatar
I have a job 1 no problems at all. It pulls great and runs great with 19000 lbs toy hauler fitfh wheel trailer with 5 people in the truck.
2008 Job1 F450 Crew Cab Lariat 4x4 6.4L 4.88 GCWR 33000
My trailer is 2009 Inferno 4012sl Toy Hauler GVWR 19000 soldl Aug. 2011
My new Trailer 2012 DRV
pic
chuck_s_jr is offline
Old 10-22-2009, 11:39 PM   #8 (permalink)
Stymie's Avatar
build date and vin are the easiest. if its built before 8/07 its a job 1, 8/07-12/07 job 2 and the rest are job 3's. If you havent had the venturi t installed i'd recommend it(radiator stuff) but other than that the major differences are options(chrome package, back up camera stuff like that). I've heard from 1 source the later build trucks have a few stronger internal trans pieces. But nothing i'd concern myself over. Also, the job 1 has a different tranny filtration setup
2008 Ford F-250 CC SB
6" Stage II Pro Comp Lift
17x9 Pro Comp 7189
37x12.5 BFG M/T KM2's
Spartan/4" duals/AFE
Try the SEARCH Button
Stymie is offline
Old 10-23-2009, 06:12 AM   #9 (permalink)
Just minor stuff. It's a GREAT TRUCK. ENJOY!
-external transmission filter; be aware of more frequent trans. oil and filter change interval (30K)
-Job #2 trucks have an air dam, the plastic part below the front bumper that may increase mpg. Do a search on this forum for air dam. I added one, but it's not a big deal.
-radiators have been an issue. Keep a close eye on your radiator fluid level.
The only thing I can think of to address with the dealer is to make sure you have the most up to date program, and any recalls/TSB (technical service bulletins) and the like. And get the radiator pressure tested. They should add a venturi T valve to keep the pressure in check.
Hope this helps. Others here are way more on top of this than me and will jump in I'm sure!
TPompei is offline
