Just Changed The Fuel Filters - Diesel Forum - TheDieselStop.com
Old 03-10-2008, 10:27 PM   #1 (permalink)
I just changed the fuel filters on my 08 F250 today, 10215 miles, I thought maybe someone could use the info that I had to go thur to complete. First, the nut size on the filter tops is 36mm. I found to use a socket was the best way to remove the frame mount filter. I started with the frame filter, had to use the water sep drain to remove the fuel before removing top. Found that the wiring loom was in the way, its held in place by a zip tie. After moving the loom I was able to get to the nut on top of filer. After unscrewing the filter top I was able to get the old filter and top out by pulling down, not a real user friendly intallation, Ford could of done better!!! The top filter went real well. Just placed rags under the filter lip to catch the overflow fuel, still had some overflow/spill when I installed the new filter. Will not happen next time!!! I followed the user manual and toggled the ing on and off for 30 sec 6 times to purge the system, No problem starting after changing the filters
By the way I got my filters from dieselfiltersonling.com. They had the best price for the Motorcraft filters. Hope this helps
08 F250 King Ranch 4X4,
goakes is offline
Old 03-11-2008, 12:32 AM   #2 (permalink)
Jcard's Avatar
I use about 4 socket extensions to reach in from behind the transfercase, keeps fuel from running down my arm.
08 550 lariat silver crew
Previous Fords
05 350 lariat silver crew (wrecked)
04 250 lariat silver crew
04 250 lariat silver crew (lemon)
2000 350 xlt silver crew
late 99 350 xlt silver crew
Jcard is offline
Old 03-11-2008, 08:35 AM   #3 (permalink)
t613's Avatar
Good stuff, thanks for the info.!
Tim
2008 F-250 XLT Supercab 4X4 6.4L Auto, short bed
Toreador Red, 3.73 gears, Job 1, Huntsville motor
t613 is offline
Old 03-11-2008, 09:18 PM   #4 (permalink)
ssharber's Avatar
I'm a newbie and have 1 question
On the frame mounted filter, you said you used the drain lever for the water seperator before removing the cap. Will the lever drain ALL the fuel from the filter or will it just continue to fill up due to pressure? Ive drained mine like the manual says, and am familiar with Diesels, but not Powerstrokes. Just wondering how much to drain before I realize either its draining whats in the filter or its just going to keep draining. Thanks for such a great site and any advice anyone has!
ssharber is offline
Old 03-11-2008, 11:10 PM   #5 (permalink)
thanks for the info...ill be doing my filters myself as well...
stunya is offline
Old 03-12-2008, 07:05 AM   #6 (permalink)
Seapig53's Avatar
Thanks goakes for the useful information. You are the man
~Mike~
2008 F-450 CC Lariat...Plus moon roof
Seapig53 is offline
Old 03-12-2008, 09:28 AM   #7 (permalink)
When I changed mine, I drained the fuel/water separator before removing the cap, and got almost a quart of liquid before it stopped flowing....
2008 F-350 6.4 Job 1 SRW LWB 4x4 Lariat Crew Cab, Dark Blue Pearl/Pueblo Gold, With all options except the tailgate step and cab clearance lights.
Truck PICS
Duane_Miller is offline
Old 03-12-2008, 09:46 AM   #8 (permalink)
I havent done this yet, but i think that it stops flowing... it only drains what is in the seperator... someone correct me if i am wrong...
2008 F350 CC Lariat 4x4 LOADED!
2008TTCC is offline
