losing coolant - Diesel Forum - TheDieselStop.com
Old 11-19-2012, 02:36 PM   #1 (permalink)
losing coolant
I have been losing coolant for about 4 years now. It comes from the cap on the degas bottle, bout once a month i put about 2 qts in it. Ive replaced the cap and it still does it. Does anybody know what could be causing it. Ive read all over about radiator leaks and hose leaks and orings but I have had none of these leak. It only comes from the cap. Ive tested the air in the degas bottle for diesel exhaust with a blue point test kit and its been negative everytime. I bought this truck new in 4/2007. Its a job 1 and I did the venturi hose kit when it first came out and Im still running with original radiator. I have 61k miles. Any help is appreciated. Thx
2008 F350 SRW CC SB KING RANCH
Dav700 is offline   Reply With Quote
Old 11-19-2012, 03:49 PM   #2 (permalink)
foreman1063's Avatar
Head gaskets leaking/head studs stretching.
foreman1063 is offline   Reply With Quote
Old 11-19-2012, 04:13 PM   #3 (permalink)
2nd that. Could also be EGR cooler.
Doubletap is offline   Reply With Quote
Old 11-19-2012, 05:07 PM   #4 (permalink)
senix's Avatar
No exhaust gases in the degas bottle. Not a headgasket issue.
Look at EGR valve and coolers. If you have the old style EGR valve I would bet that is it.
Coolers with that amount of loss would have been a bunch of white smoke I'd imagine.
08F250 CC 6.4 PSD
Banks 6 gun/ram air
40' Stoneridge 5th wheel, coming in at 15.4K.
senix is offline   Reply With Quote
Old 11-19-2012, 06:38 PM   #5 (permalink)
Iam4MSU's Avatar
Generally when you have puking back through the Degas bottle it means that you have a clogged oil cooler. If you are using Ford Premium yellow silicate coolant junk or other silicate coolant, it is prone to cause the silicate to gel thus clogging the coolant pores of the oil cooler. With the inability of the proper amount of coolant to flow through the oil cooler (heat Exchanger) the oil becomes hotter than it should thus the oil cooler is hotter than it should be. Because it is hotter and the coolant flow is less, the amount of heat transferred to the coolant will cause it to flash boil and puke the superheated coolant back through the degas bottle and overpressurizing the 16 pound cap. That will produce the white stuff you see around the degas cap and bottle.
You can try to back flush the oil cooler using Restore to disolve the silicate gel. It may help but it may also completely clog the oil cooler further thus causing the needed replacement even sooner.
I just replaced mine myself as well as the EGR cooler.
2004 F250 Crew Cab King Ranch Lariat FX4 Saddle Leather 6.0 L FUMOTO Valve
AIRAID 4" straight No CAT No MUFF
Nitto Terra Grapplers All Terrain LT285/75R16 10 PR Everything else pretty much stock
NEW Ranchos installed 8/15/2010
WORK IN PROGRESS - R&R EGR COOLER, OIL COOLER, THERMOSTAT, TURBO BOLTS, GASKETS, ORINGS, and adding a COOLANT FILTER WITH NEW COOLANT AND FLUSH
Anyone Got Birds? Will Travel to Hunt!
We are all just Village Idiots,
Enamoured with our own shadow,
Oblivious to the setting sun!
Iam4MSU is offline   Reply With Quote
Old 11-20-2012, 05:04 AM   #6 (permalink)
I was losing cooolant for 3 years turned out to be headgaskets. Have the pressure checked in the degas bottle. Mine was through the roof. You will also see white spots around the bottle.
