Go Back   Diesel Forum - The Diesel Stop.com > 2008-Up Super Duties > 6.4L Power Stroke Engine and Drivetrain
6.4L Power Stroke Engine and Drivetrain Discussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008 Super-Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Old 03-13-2008, 09:44 PM   #1 (permalink)
Low Sulfur or Ultra low
Need some advise on this fuel. A friend put the low sulfur in his 08 instead of the ultra low. What harm will this do? He just told me today that the pump he has been using states Low Sulfur not Ultra low Sulfur.
He said he only stops at this station once a month and has been been there 8 times in the past and just realize this today.
He said the other place he stops at has a big sticker on the pump saying Ultra Low Sulfur.
sg2005 is offline
Old 03-13-2008, 10:02 PM   #2 (permalink)
I think: No harm at all......Period.....It's probably actually better as far as lubrication goes. I would think if he were to keep using it he might regenerate a little more. Do you know if he has had a regeneration yet. Just curious.
737tdi
2008 F350 4X4 Supercab
2003 VW TDI
1995 F150
1969 Ford 3/4 ton Camper Special
737tdi is offline
Old 03-13-2008, 10:16 PM   #3 (permalink)
737tdi,
He has about 19k on the clock and has has the regen but didnt notice anything different with the wrong fuel.
sg2005 is offline
Old 03-13-2008, 10:24 PM   #4 (permalink)
Engine31's Avatar
My Photos: (10)
Isn't ULSD Fed. law now??
I've heard of some stations that just didn't change the sticker on the pump.
F450 Lariat 4X4, red, 4.88's, everything but the moonroof, S & B Intake, Banks exhaust, Amsoil.
Engine31 is offline
Old 03-13-2008, 10:34 PM   #5 (permalink)
I thought the same. I called the Turkey Hill where he was using and they said that there main office didnt do the switch over to the ULSD. So i bet alot of people didnt even think to look for the new sticker thinking what you said is to be true.
sg2005 is offline
Old 03-14-2008, 04:42 AM   #6 (permalink)
Low sulfur will cause damage to the DPF. Ford will not fix it under warranty, price tag on parts alone is said to be in the $1500 range. Don't do it.
Red 2002 F-350 XLT SRW 4x4 7.3L reg. cab 6-speed rubber floors traded at 50K for:
Red 2005 F-350 XLT SRW 4x4 6.0L reg. cab 6-speed rubber floors BFG 12.5x35 mud-terrains, no lift traded for:
Red 2008 F-350 XLT SRW 4x4 6.4 reg. cab 6-speed. Got carpet this time- audiophile stereo deletes rubber floors. BFG 12.5x35 mud terrains, no lift.
torino73 is offline
Old 03-14-2008, 08:17 AM   #7 (permalink)
George C's Avatar
I agree.
You will definitely be impressed when your DPF fails, and you are picking up the tag.
It is CLEARLY written on the fuel cap.
No excuse..
My 2008 F-350
http://community.webshots.com/user/GeorgeC1959
George C is offline
Old 03-14-2008, 09:39 AM   #8 (permalink)
It won't cause the DPF to fail. It will just not last as long.
However, the station probably just hasn't updated the stickers on their pumps.
rlchv70 is offline
Old 03-14-2008, 10:55 AM   #9 (permalink)
Go to the flying j website, Flying J: Current Diesel Fuel Prices Pricing , this shows they even have stations with lsd.
In my answer to the question I was not saying you should use low sulphur diesel, I was merely saying it will not hurt the engine. As richV70 said, it will not cause the dpf to fail, it will merely shorten it's life. Which none of us no what that life is, I am very confident it is less than what Ford says. Being a pessimest here but anything that goes through the temperature swings this thing does is going to have problems.
737tdi
2003 VW TDI
1995 F150
737tdi is offline
Old 03-14-2008, 06:40 PM   #10 (permalink)
titaniumfan's Avatar
Just to repeat, aside from Alaska and California, ULSD isn't *required* in all states until December 2010, though 80% of a refinery's output today must be ULSD. If you don't see a ULSD sticker you should assume that it is still LSD (as I discovered at a Las Vegas truck stop) All diesel sold in California is already ULSD. See
Ultra Low Sulfur Diesel will be the primary highway diesel fuel produced - Clean Diesel Fuel Alliance
for the gory details.
2008 F-450 Lariat Job 1 w/ 4.88, 98 gal. Transfer Flow tank in bed, Tekonsha P3 brake controller (6 electric over hydraulic disc brakes on toyhauler, not supported with TowCommand), TrailerSaver TS3 air hitch, all for a 2007 Glendale Titanium 36E41MPRV toyhauler
SOLD 2006 Silverado 2500HD LT3 (LBZ Duramax)
titaniumfan is offline
Old 03-15-2008, 08:18 AM   #11 (permalink)
ULSD will not do any major damage to the engine with one tank but can harm the emissions equipment it will also cause a lot more regen.
As far as being mandated, most places have already converted because of availability but it is not required by the government until 2010.
08 F350 Crew Cab Lariat - Ride Rite bags & Compressor -- Level Kit
RT76 is offline
Old 03-15-2008, 10:04 AM   #12 (permalink)
TedWhite posted this on 02-03-2008:
"... it's simply NOT TRUE that using lsd will plug the DPF as you were told by that technican. The fact is, techs are only parroting what they have been told by Ford but I haven't met one yet who has actually done the scientific research to find out if it is true. It's NOT !!!!
Here are some interesting links to SCIENTIFIC REPORTS from tests done by EPA appointed labs and the vehicle manufacturers:
www.aseanenvironment.info/Abstract/41014571.pdf
for the effect of sulfur on DOCs (Diesel Oxygen Catalysts).
www.nrel.gov/docs/fy02osti/31600.pdf
for Diesel Emissions Control Sulfur Effects Project
http://www.nrel.gov/vehiclesandfuels...pdfs/40015.pdf
for the Effect of Biodiesel Blends on DPF performance
http://www.osti.gov/bridge/servlets/...ive/828945.pdf
for Fuel Formulation Effects on Emission Control
www.sae.org/technical/papers/2002-01-2788
for Fuel Sulfur Effect on Membrane-Coated Diesel Particulate Filter
http://www.nrel.gov/vehiclesandfuels...erim3final.pdf
for Diesel Fuel Sulfur Effects on Particulate Emissions
http://www.pecj.or.jp/japanese/divis...zuhisaMOGI.pdf
for effects of sulfur on DPF performance
The FACT is, running LSD will NOT destroy a modern DPF. All of the Government and manufacturer testing gives the same results - it takes at least 40,000 miles for lsd to begin to have a long term effect on the DPF. That's right, AT LEAST 40,000 MILES ON LSD TO EVEN REGISTER ANY CHANGES IN DPF PERFORMANCE !!!!!
As you will see from reading the above material, the reason why it is illegal to use lsd has nothing to do with preserving the DPF. It all has to do with emissions. When fuel with more than 300ppm sulfur is burned in a vehicle with a DOC and DPF the sulfur compound emissions EXCEED the reductions achieved by the DPF. At 500ppm, which is the lsd maximum, the emissions of sulfur compounds are way over the allowable limit, despite being invisible, because the DOC helps form those sulfur compounds.
The new emissions systems have been around in the field now for long enough to start registering problems if lsd was clogging DPFs - it's NOT happening, but plenty of people are using lsd, either deliberately, or inadvertently.
FORD doesn't want you to use lsd because they have to give warranty coverage on the DPF to 100,000 miles, but if you use nothing but lsd you MIGHT shorten the time before the DPF has to be physically cleaned of ash deposits. That means FORD would have to pay and there's no way for them to know that it was caused by lsd.
I'm not counselling anyone to deliberately use lsd, I'm just providing FACTS instead of opinions. If anyone can find a single scientific study which proves me wrong, please post it here and I'll happily admit I was wrong.
And just for the record, I am presently in
Mexico, having used higher sulfur fuel since Dec 1st with NO PROBLEMS and more than 6,000 miles of driving. I've also met and spoken with drivers of other Ford, GM and Dodge new engine, all of whom have NO PROBLEMS. The highest mileage on lsd to date in Mexico is a Dodge in the Baja with around 10,000 miles on high sulfur fuel.
So PLEASE, when you see other opinions and inuendos about lsd in forums, put a link to this post so that people can read the SCIENTIFIC FACTS instead of unsupported opinions. And that includes dealerships, who are either uninformed or deliberately lying to you.
Online
2007.5 Chevy Silverado 2500HD with LMM Duramax, LTZ, long bed.
2008 F450 PU 6.4, 4.30 gear
2008 Snowriver 108 truck camper
2005 Jeep Rubicon Unlimited
Clattertruck is offline
Old 03-15-2008, 01:45 PM   #13 (permalink)
Good job on the research, Clatter.
2008 F350 SRW SB KR almost all options including moonroof, nav, etc. Ordered May 14, received July 4, 2007.
F350 4x4 CC SWB SRW 2003.25 6.0/Auto, FX4, Lariat, Toreador Red/Arizona Tan, Bench Seats, Moonroof, etc. Ordered Nov.6, 2002. Received Jan 30, 2003. Pulling 1992 Alfa 34' 12200GVWR with Pulliam SuperGlide. Retrax. 86000 miles and counting. Traded, July 4, 2007
kalalp is offline
Old 03-15-2008, 08:06 PM   #14 (permalink)
Super Duty John's Avatar
My Photos: (55)
Here is a link to Flying J fuel stops and you can see they clearly sell low sulfur at a lot of their stations. BTW, you can check all the prices around the country too.
John
2008 Job 2 F-350 4x4 Crew Cab SWB dually
Lariat with the chrome package.
Super Duty John is offline
Old 03-15-2008, 10:13 PM   #15 (permalink)
I used half LSD and half ULSD and I got an increase in mpg from 12 to 18 in my 2008 Ford F-350. This was aroung 11K miles.
GERM is offline
