Go Back   Diesel Forum - The Diesel Stop.com > 2008-Up Super Duties > 6.4L Power Stroke Engine and Drivetrain
6.4L Power Stroke Engine and Drivetrain Discussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008 Super-Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Old 11-10-2007, 03:53 PM   #1 (permalink)
LSD fuel mileage improvement
Well, I was in a bind earlier this week and had to put 1/2 tank of LSD in the 6.4. I was not too worried about it since I have a smoker anyway and dealer is scheduled to swap DPF as soon as they get one. But here is the interesting part. With LSD I was getting 19 MPG at 70 MPH and 2K RPM in the F250 with 3.73 rears according to the lie-o-meter. It normally reads 17 mpg in the same conditions with ULSD. Go figure. LSD is only supposed to be 1 to 3% better, not over 10%.
2008 6.4L F250 KR CC 4wd on order
boat_fan1 is offline
Old 11-11-2007, 10:14 AM   #2 (permalink)
Re: LSD fuel mileage improvement
What's really astounding here, is the fact that you watch the computer toy.
2003 KR F-250 4X4 CC SWB, 6.0, 5 Speed Auto, 3.73 Axle, no Limited slip. Rhino bedliner, Unicover bed cover.
Built on February 19, '03
#2 93 F-150 XLT, 5 Liter, Auto, 4X4, X Cab. 231,000 miles. Uses no oil between changes.
montanafan is offline
Old 11-11-2007, 12:45 PM   #3 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: montanafan</div><div class="ubbcode-body">What's really astounding here, is the fact that you watch the computer. </div></div>
The computer is the truck has very useful infomation on it. Why somone would not watch the guages on a truck surprises me. ford spent thousands on the ability to tell us drivers how our truck was performimg.
exoval is offline
Old 11-11-2007, 01:33 PM   #4 (permalink)
You are correct, and the thermometer and compass are relatively accurate. They missed the boat by a country mile on the mileage toy, though. That should be considered to be more of a toy than anything representative of a useful instrument. The "miles to empty" can be pretty accurate at times, though.
We've had hundreds of forum members write about the MPG readout, and most think it is a joke. Furthermore, the error is not consistent.
Old 11-11-2007, 03:11 PM   #5 (permalink)
The computer on my 03, 6.0 was not accurate at all. My 08 has been consistently within .3 of hand calculated.
JD
08, 6.4, F-350, torqshift, SRW, lariat, 4X4, LB, CC, Pueblo gold (Built the week of 04/09/07)Arrived 4/24/07 brought home 4/26/07
http://rides.webshots.com/photo/2919...01044415MSbgrF
jhughd is offline
Old 11-11-2007, 03:45 PM   #6 (permalink)
Not regarding the lack of constructive comments....
I find it very interesting that the difference between ULSD and LSD would be that great. It is not supposed to be. Even if you are stepping outside the box and using the instruments/gages/readouts in your truck.
I understand that the factory lie-o-meter is usually wrong when compared to hand figured numbers.
However, common sense should prevail here!
Lets say that you are consistantly seeing 17.0mpg on factory readout for X amount of miles (whether or not that number is gnats ass accurate does not apply). And now you only change 1 variable (ie; LSD vice ULSD) and get a substatial increase in mileage.....I would be asking the same questions also.
Who cares if the factory gage is wrong! For 90% of us the gage IS wrong...but it is a CONSTANT wrong (very little delta).
LittleBigRig is offline
Old 11-11-2007, 04:07 PM   #7 (permalink)
FINE69's Avatar
I agree with LittleBigRig, whether the factory lie-o-meter is accurate or not is totally irrelevant to this discussion. Its kinda funny how somebody on this board always has to knit-pick someone else's story, or ideas.
2005 F-350 4x4 Supercab, Lariat, LWB, SRW, FX4, 6.0, Auto. Oxford White/Arizona Beige. MBRP SS Turbo-back Cool Duals-Cat Delete Pipe, DieselSite coolant filter, Mag-Hytec dif cover, Royal Purple Syn. lube in axles, 325-65/R18 Nitto Terra Grapplers on Weld Evo Cheyenne-8 18x8.5 wheels. Fabtech 2" Leveling kit, Bilstein 5100's. Precision Billet grille, Lund Interceptor, Husky liners, Rhino liner, Weatherguard toolbox, 8' Western Ultramount Poly Pro snowplow, 15% tint. Built 12/04
http://community.webshots.com/user/FineFord
FINE69 is offline
Old 11-11-2007, 05:41 PM   #8 (permalink)
I have been using my " lie-ometer" to see if I could spot the mpg degradation when my truck did a regen...Appears I can. With about 85 miles since last reset..my computer told me i had a 15.3 avg mpg , driving empty around town ,,and local freeways. I noticed a regen cycle start..passive, I quess since I was driving at the time. Avg mileage went to 13.6 in 10 additional miles of driving. My conclusion..mileage must be around 5 mpg during a regen?
If I got 15.3 all the time..I would be a happy camper....
2008 F350 Crew Cab 6.4 PSD 4X4
Excel 33RSO 5th Wheel M/C Lift on the back
jayhirsch is offline
Old 11-11-2007, 11:08 PM   #9 (permalink)
I have been in the fuels refining business for more years and in more states than I care to recount.
Here is what is going on with ULSD vs LSD: To sell into the commercial pipeline market at 15 ppm Sulfur, and to account for minor contamination in transit, refineries are generally targeting 8 ppm Sulfur from the Hydro Desulfurization units. In the last 5 years, refining has had to spend billions of dollars to "turn gasoline into gasoline" (drop S from 100 ppm to 30 ppm) and "turn diesel into diesel (drop S from 500 ppm to 15 ppm). In addition to the billions in capital cost, the operating costs increase and the production volumes decrease.....additional processing steps inevitably crack some materials to LPG and fuel gas which has a lower value.
LSD is typically heavier (higher distillation end point) than ULSD, and tends to be at a higher cetane value. Bottom line, the ULSD with a lower distillation curve will contain fewer BTU's per pound and thermodynamically will deliver less energy to the wheels. This is why you will usually see better economy with LSD vs ULSD. You will see the same shift in mileage from summer to winter in northern climates....when the cloud point has to shift below 20F in September or so for the winter season, the practical way to do that is to shift some kerosene to diesel in the fractionation processess. It keeps the fuel from clouding/gelling, but it also delivers less energy per pound of fuel.
NRA Lifer - 2001 Platinum Edition F-250 Crew Cab PSD 4X4, Line-X. Prior owner of a 1989 E-350 7.3L and 1984 6.9L diesel.
Wayne, PA
Awl_Bidness is offline
Old 11-12-2007, 01:04 AM   #10 (permalink)
Yeah, what he said!
08 F450 4x4 CC KR
06 F250 4x4 CC KR V-10 lots of goodies.
Kimminau2 is offline
Old 11-12-2007, 09:40 AM   #11 (permalink)
I think you are correct in most of your statement. The refinery I just retired from produces 7 PPM of S, but the ULSD has a natural Cetane number higher than LSD. We marketed LSD with a Cetane number of 43, but the ULSD is 46. The refinery of which I speak runs 100% of Diesel related products through its ULSD hydrotreaters, so they can blend any of those products with any others.
Whatever the arguement, the truth is that any mileage changes because of the difference should be very minimal and hard to even detect. Winter blend can, and probably will, show a difference in both mileage and performance.
