MAJOR oil leak HELP ! - Diesel Forum - TheDieselStop.com
post #1 of 11 (permalink) Old 04-07-2012, 02:34 PM Thread Starter
Pulled in the driveway this morning shut the truck off ran in the house for about an hour. go back out to wash the truck and see 2 huge i'm talking like 1ft. x 2ft. puddles of oil under the truck. pop the hood oil all in the valley on the underside of hood above the turbo. clean that oil up and checked dipstick reads full, so I start truck cant see any leaks from anywhere from above. Look underneath and it's just pouring out between bell housing and rear of motor from what I can tell right now. going to power wash it all down and recheck. My question is whats the probability of the leak being the Bed Plate? or other possibilities. I'm still figuring out the 6.4 if it was my 7.3 it would be no problem to figure out and even repair myself. This 6.4 just has too many hoses and crap all over the place, don't really know where to start.
Early '99 F350 stamp date 02/98 4X4 SW Reg. Cab Long Bed, Auto, 4'' lift, 35"s, 4" Turbo back straight piped MBPR, Banks cold air, Stage 1 Injectors, TS Beans Tunes, Modded 17,Turbo Master Wastegate, Triple A Pillar GloShift gauges, KCM HPX line, Riffraff FPx, Black CPS,
Hutch and Harpoon Mod. AE, 208,000 miles
2008 Job 1 6.4 F350 CCLB Lariat AFE CAI, 4" downpiped straight back, H&S Mini Max
lang is offline
post #2 of 11 (permalink) Old 04-07-2012, 03:15 PM Thread Starter
Originally Posted by shoguy89 View Post
Like the 6.0L engines, the oil cooler is located i the valey, below the oil filter housing. My guess is that you've got an o-ring seal rolled out from one of those places. The oil that leaks under pressure pools in the valley and moves to the rear of the engine and falls to the ground at the back of the engine.
Look deep into the valley and se if you can see where the leak is coming from. Hopefully, it's not too far down.
Will start there. brings back memories of the HPOP plug o-ring blowing out on my 7.3 multiple times.
Thanks for the reply
lang is offline
post #3 of 11 (permalink) Old 04-07-2012, 08:48 PM Thread Starter
Fixed ! Oil filter oring
lang is offline
post #4 of 11 (permalink) Old 04-08-2012, 05:40 PM
Powerstroke2000's Avatar
My Photos: (17)
Whew....that was an easy fix then!
Odd that it showed that there was on 'oil loss' on the dipstick though?
Bedplate, why the heck wasn't the block made all in one piece, eliminating one gasket...or place for an oil failure?
2009 F450 4X4 Superduty King Ranch
6.4 Diesel, 4.30's.
Powerstroke2000 is offline
post #5 of 11 (permalink) Old 04-09-2012, 01:37 AM
Capt Dong's Avatar
what was wrong with your oring?
Capt Dong is offline
post #6 of 11 (permalink) Old 04-09-2012, 07:37 AM
Odd that it showed that there was no 'oil loss' on the dipstick though?
The split block is much stronger.
The block parts at the crank centerline. This makes the lower part of the block one piece and very strong. There are no more individual main caps. The main caps are incorporated into a one rigid member. This also allows for automated assembly. These things are built by robots so the bedplate feature helps them get it together. All the fasteners are torqued at the same time and the bedplate is sealed with a silicone rubber rope seal that fits in a groove on the bedplate and seals against the flat on the bottom of the block.
Doug Lewis
Ford Performance Specialists
351 Six Flags Pkwy SE
Mableton, GA 30126
770-949-7191
Not Racist, Not Violent
Just no longer Silent!
Question with Boldness.
2008 F-450 King Ranch w/4.30 gears
SCT Custom Tuning by FPS, Deleted, 16mpg
2001 F-250 Platinum Edition - Gone, but not forgotten
CIA, Garrett GTP38R, 4" Exhaust, SCT Custom Tuning by FPS
shoguy89 is offline
post #7 of 11 (permalink) Old 04-09-2012, 10:04 PM
FLATBED ED's Avatar
Yeah, mine failed also. When I loosened the cap,it came apart. It had broke.
Don't know why, never had it happen before. They may be defective. Made in China?
FLATBED ED,99 F-450(May she rest in peace)
2008 F-550 w/16-ft. Flatbed(buried on top of my 1999)
FLATBED ED is offline
post #8 of 11 (permalink) Old 04-09-2012, 10:48 PM
Capt Dong's Avatar
A new o ring come with every new filter. Maybe it wasn't replaced. That's horrible if it were defective.
post #9 of 11 (permalink) Old 04-10-2012, 12:21 AM Thread Starter
I would say Human error on my part. for some reason the o-ring slipped out of the groove on the filter cap and ended up at the top of the cap. Strange that it first showed up now, I changed the oil 2000 miles ago.
lang is offline
post #10 of 11 (permalink) Old 04-11-2012, 06:21 AM
Capt Dong's Avatar
at least it was that and nothing major.
post #11 of 11 (permalink) Old 04-11-2012, 11:01 AM
FLATBED ED's Avatar
Be sure to lube the o-ring before install. Don't think it was your fault. Also, be sure to install it rather tight. A loose cap may allow the oil to escape and damage the o-ring.
  Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 6.4L Power Stroke Engine and Drivetrain
