My Low Pressure Fuel Pump Failed,Dealer Acted Like It Was My Fault:Advice Please - Diesel Forum - TheDieselStop.com
Old 10-16-2009, 07:32 PM   #1 (permalink)
My 2009 with 11,000 miles just quit like you turned off the key. At first I thought I may have run out of fuel cause I knew it was low and was going to refuel just down the road. I looked at the display and it said 39 miles to empty. I know for a fact it will run well beyond the distance to empty,so I felt satisfied I wasn't and idiot for running out of fuel. I am 53 and have never done that in my life.
Anyway had it towed to dealer. Picked it up and asked the mechanic what was wrong. He said I ran it out of fuel. Well,I did feel like an idiot then,but said,it said 39 miles to empty. I said If I ran out of fuel the gage must have crapped out cause I have run it lower than that with room to spare. He said DON'T DO THAT. I said I don't normally.Then he said we also had to replace the low pressure fuel pump. This was well into the conversation. I said so the pump was bad,he said yes. I said,well then that was the problem. He never said yes,
Was he implying running low on fuel could burn up the pump? And is the low pressure fuel pump a common failure? Help me out here guys.
diesel doug is offline
Old 10-16-2009, 09:32 PM   #2 (permalink)
senix's Avatar
nope, he was trying to lay blame on something that just failed. I normally fill up as soon as the message center hits 50 miles left, but I have run it down into the 20's before no problem Don't like to but I have.
08F250 CC 6.4 PSD
Banks 6 gun/ram air
40' Stoneridge 5th wheel, coming in at 14K.
senix is online now
Old 10-16-2009, 09:45 PM   #3 (permalink)
ZeroOne's Avatar
There have been quite a few people who have run their tank down to 0 miles or close, to do the harpoon mod (requires dropping the tank). They still had a couple of gallons left, even at that reading. I don't think you did anything wrong at all.
Side note: anyone else notice when they fill up that the gauge doesn't go all the way up to full? Mine stops just before the needle touches the F's white line.... and i do top off.
Unofficially for sale / entertaining offers.
PM me if interested or for more details on it.
'08 6.4 CC/SWB F350 Black FX4, 8" Rize/OUO on 38x15.50s, 4.56 gears,
photo2, photo3
ZeroOne is offline
Old 10-17-2009, 07:02 AM   #4 (permalink)
Shinny's Avatar
Side note: anyone else notice when they fill up that the gauge doesn't go all the way up to full? Mine stops just before the needle touches the F's white line.... and i do top off.[/quote]
Mine goes past the Full mark and I've heard of people running down to "zero miles to empty" without problems
'08 F250 FX4 6.4L Super Duty Crew Cab SB Silver Metallic & Dark Shadow Grey Job 1
Extang Trifecta Bed Cover,
High Idle Mod,
Spray in Bed Liner
second radiator
EGR Valve replaced
100% Stock
Shinny is offline
Old 10-17-2009, 10:48 AM   #5 (permalink)
Mine goes slightly past the full mark and I have run it down to 15 miles to empty. Didn't want to but was on an unfamiliar highway without a lot of stations carrying diesel.
2008, F-250 Lariat, Job 3, 6.4 PSD, 3.73 Gearing, Edge Insight, 4X4 Off-Road, White over Pueblo Gold, Extended Cab.
SDStanger is offline
Old 10-17-2009, 12:43 PM   #6 (permalink)
Stymie's Avatar
i noticed when i filled my truck yesterday the dashdaq wouldnt read above 99.997% which i thought was odd
2008 Ford F-250 CC SB
6" Stage II Pro Comp Lift
17x9 Pro Comp 7189
37x12.5 BFG M/T KM2's
Spartan/4" duals/AFE
Try the SEARCH Button
Stymie is offline
Old 10-17-2009, 07:01 PM   #7 (permalink)
PRO-4 #31's Avatar
I have and always run mine about 30 miles past the 0 to empty. Most of the time i fill it up when it says 50 to E and it only takes about 32gals. I get about 320 to 360 out of a tank hand calculated . Got the extended warranty so if it fails they can fix it tuck has 13k on it have had it for well over a year still driving old faithful 7.3.
2008 F350 4x4 6.4 Job 3 spartan
2005 Dodge Viper SRT-10 Mamba Edition 4 sale(sold)
2008 Volvo C30 T5
2008 36f Hallmark
2006 Chrysler 300 SRT-8
2002 F350 7.3
2009 Fastrack Engineering Pro-4 (2010 ASA PRO-4 champion)
PRO-4 #31 is offline
Old 10-17-2009, 09:16 PM   #8 (permalink)
ZeroOne's Avatar
LOL, are you making fun of me??
Seriously though, my gauge stops at the level that 2 days worth of driving would bring it down to, from full. Just seemed strange that it started all of a sudden, so I thought I'd ask.
photo2, photo3
ZeroOne is offline
Old 10-18-2009, 03:05 AM   #9 (permalink)
Stymie's Avatar
nope, that is a true post. I was filling the truck, it clicked off. I put another 2.8 gallons in after that. Started the truck up, the gauge read full but the DD read 99.997
17x9 Pro Comp 7189
Stymie is offline
Old 10-18-2009, 10:10 AM   #10 (permalink)
ZeroOne's Avatar
Oh ok... wasn't sure with the number you posted. 99.997 is pretty close to 100% though. Maybe if there were fewer decimals, it would have just rounded up or something. I feel like mine, where the gauge stops now, would be like 85-90%.
photo2, photo3
ZeroOne is offline
Old 10-27-2009, 12:16 AM   #11 (permalink)
Jonstoy's Avatar
i had a chat with an old diesel mechanic at one of my local dealerships and he told me that the 6.4 have problems with the injectors letting oil past the oil rings and this lets the diesel into the oil. And he also told me that the low pressure fuel pump has also been an issue with the 6.4. He said that those are really the only two major problems with the 6.4. At the time he was actually working on one 6.4 where he had to replace the low pressure pump and he said that he would have to pull the cab.
RIP 2008 CC LB 6.4...Rolled 3.5 times and walked away with only 4 scratches....Brand new 2010 F-350 CC LB 6.4 Lariat SRW, Camper package, Snow plow, dual alternators, cab lights, Back up camera and tail gate step, Rhino lined box, 6 inch pro comp lift kit, 35"x 12.5 toyo Mt tires, Buckstop outback bumper, 12000 warn winch, 4 lightforce driving lights on bumper, Spartan tuner and dpf delete with 4 inch mbrp exhaust, Winter studded cooper tires...stock size.
Jonstoy is offline
Old 10-28-2009, 10:38 AM   #12 (permalink)
The low pressure pump just takes a few minutes to replace. The high pressure pump is the one you need to pull the cab.
Old 11-01-2009, 12:05 AM   #13 (permalink)
Jonstoy's Avatar
ohh sorry my mistake.
Jonstoy is offline
