6.4L Power Stroke Engine and DrivetrainDiscussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008 Super-Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
I've gotten stuck around my property when plowing and I noticed when I go to give it gas after sanding etc. to try to get out I don't get any power and the wheels won't spin or move. The truck just boggs down.
Is this what they call Turbo Lag?or maybe the truck had cooled down and I didn't have the power? I don't remember this happening to my 7.3.
Fortunetly I haven't got stuck enought to give you more infoon either trucks but I noticed this and it got me thinking about it and maybe how to prevent it again.
But if I'm to guess I'd say the truck was cooled down and didn't have the power to go and or spin the wheels. These diesels are different then gassers like this right?
08 F350 Lariet DK.Blue/Silver CC Short Box SRW. Auto transmission, Manual 4x4,Supplemental Cab Heater,3.73 Limited Slip.Gator Guard Bedliner, 6.5 x 12 Sno-Pro,8ft. Fisher.
04 Lance 820.
i had that issue too, you also cant go from R - 1 or the motor all but dies. and i don't have TC
2008 Ford F-250 CC SB
6" Stage II Pro Comp Lift
17x9 Pro Comp 7189
37x12.5 BFG M/T KM2's Try the SEARCH Button Because It's Probably already been asked
I bet it is the traction control. My Dad's 08 F-450 will light them up no problem with the T/C turned off.
If you live in AZ come join us at Arizona Powerstroke Group... Click here... http://www.azpsg.com/index.php?referrerid=6
99.5 F-350 PSD Lariat, 4x4 Off Road, CC, SB, 3.73's, NVK2, BTS Trans and T/C, V-10 and Tru-Cool Max Trans Cooler, Evans NPG Coolant, BTS 100 HP Chip, ART Cryogenically Treated & Slotted Rotors with Performance Friction Brake Pads, Dynatrac Spin Free HD Front Hubs, TAG I & II, Ford AIS Intake, 4 inch Stainless Exhaust from turbo to 5 inch chrome tip. Auto Meter Ultra Cobalt Gauges. 35X12.5 BFG KO's on 16x10 Rims, Bilstein Shocks.
Sorry folks: I had it on view in display mode and just saw Captcaper's post, not the replys.
Hey Captcaper: I'm just wondering if you have the traction control option. I have my first F350 on order and I didn't order traction control because that what happens to a friends 08 if he has traction control on. I'm going to be new to diesel and the SD fords but not 4X4 drive,so please excuse the newbie egnorance. I'm interested in the answer also. I'm sure someone on this site will have the right one.
I don't have Traction Control ..At least I didn't order it and it doesn't snow on my Window Sticker..but it's something else when I go to give it throttle and nothing..
Maybe it got cold as I dug out snow and put sand around it and I didn't have enought power to start the tires spinning?
I did put it into low range to get the wheels moving a couple of times. I don't understand the post above about the trans .. It felt like it had no power.. No rpms,etc. just bogged down. This has happend a few times while getting stuck..
Why am I getting stuck? lot's of ice under snow and heavy front end with 8ft. fisher plow and nothing in the rear and sometimes I do had 600lbs in the rear and still end up sliding just enough to get sucked in..
I do own a very aggressive set of chains now.. just came in Fri.
04 Lance 820.
Captcaper: Well if you don't have a switch "TCS" left of where the trailer brake control on the dash(or would be if you have the trailer brake control), then you don't have it, at least that is where my friend switch is, just a thought.
I have experienced this as well. both in my personal truck (2008 F-350) and work truck (2008 F-250).
What happens is the truck defuels for the first couple of seconds when going from forward to reverse. It makes it impossible to "rock" the truck out of the snow or mud as you can't keep the momentum. Extremely frustrating as this was all it would take to get out of a number of situations. Working on very large construction projects puts you in this situation plenty of times.
Could your air filter be clogged with Ice and or Snow? I don't know if this is possible with a plow on the front, but just a thought... I have read on here where this new front end was having issues with this. I would discuss this with your dealer. I think they have something to fix it. Good luck and keep us posted please...
08 F350 DRW FX4 CC 172" Black on Black Leather Job#1 Remote Start Rhino liner Extang Express Tonno cover (14,800)
fulltilt, read what is above you. this is exactly it. it is defueling. mine did it in 60 degree weather, and it wasnt raining or snowing or anything.
17x9 Pro Comp 7189
Ford has been doing this for a while my 06 6.0 will defuel when trying to rock it, which ya cant
New truck 06 F350 Amarillo, CC,SB all options except power pedals and upfitters. Old Truck 03 f250 cc,sb, fx4,7.3 lariat,sonic blue. 4.5 donahoe lift, bilstiens, cowl hood, 5" hypermax, DI 6 pos chip, Great Truck! SOLD <img src="/ubbthreads/images/graemlins/frown.gif" alt="" />
2007 TBSS Black(stock)
88 mustang vert, a few goodies
86 t-bird in the works
