6.4L Power Stroke Engine and DrivetrainDiscussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008 Super-Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Coming from a 7.3 PSD, I have no experience with the internal cartridge filters that come on the 6.0's and 6.4's. Any tricks to changing them....assume they drain down when engine has been off...so you don't have a big mess on top of the engine? Also..since you can't pre fill them like the old spin on filters...do you just start the engine up and not worry about how long it takes to fill the filter? Thanks.
2008 F350 Crew Cab 6.4 PSD 4X4
Excel 33RSO 5th Wheel M/C Lift on the back
Remember to loosen the filter cap first to allow the filter housing to drain back into the crankcase before removing the drain plug. As for filling filters before installing them, that is a bad practice.
. Ford Master Diesel Technician
Take some paper towels up into the engine compartment with you. No matter how carefully I try to flip the filter upside down, so any drips go in the cap while I'm taking it over to the drain pain, a drop or two always falls - wouldn't want that down in your nice new clean engine!
Duncan
The 1997 F250HD Crewcab: Picture
The 2000 XLT Excursion <font color="red">(SOLD)</font>: Picture
The 2003 F250 Crewcab 6.0L: Web page
The 6.0L Bible: Web page
The 6.4L Bible: Web page
You might want to invest in a 36MM socket for the nut on top of the oil filter housing. It also fits the nut on the fuel filter.
Makes it a lot easier.
DRDON
2008 F350 Lariat CC PSD 2WD Auto. 172" Dark Blue Pearl Clearcoat Metallic/Pueblo Gold 5"Chrome CabSteps Camper Pkg. HD Alt. Tow Command Upfitter Switches, 25K Air Safe Hitch, Retrax Cover, Timbrens, WOLO 120 db air horn, and more.
2007 Ameri-Camp Summit Ridge Reserve 40' 5th wheel trailer, 3/Slides, chrome wheels, Mor-ryde suspension, dual A/C, theatre system, solid surface counter tops, king bed, power jacks front/rear, 50 AMP service, sealed underside, heated tanks and more. MY PICTURES: http://good-times.webshots.com/album/558384049kmtqSi
I too want to know more about this. I have always put a little oil in a spin on filter. Why is that a bad practice? Just here to learn! Thanks!!
I think he is talking about upside down filters (messy, messy), not standard spin on filters.
Andy
Early 99 5-98, F350 extended cab, DRW LB 245,000 miles and counting, Hood insulation delete (Soaked with fuel), Hutch mod, Harpoon mod. Otherwise, pure stock (for now)
You only need two tools: WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
