Oil Leak, upper pipe that connects turbo's - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 11-08-2010, 08:00 AM Thread Starter
Sorry for the description. Not really sure what to call the pipe, but it appears that is goes from the first turbo (where the intake is) and goes into the second turbo.
Looks like oil is leaking where there is a connection in the pipe. I took a pictures that I hope will help out. Had my brother in laws truck right next to mine yesterday. Identical truck, no leak at all. Dry as dry could be.
Any input?
2011 F350 FX4 Crew Cab Lariat 6.2 Liter
2008 Ski-doo MXZX REV-XP 800R
2008 Yamaha Grizzly 700EFI
2008 Yamaha Phazer RTX
JIM342STRKR is offline
post #2 of 5 (permalink) Old 11-08-2010, 08:11 AM
senix's Avatar
Well I am thinking you have a seal for the turbos leaking
See the link:
http://www.backglass.org/duncan/ps64...ion_System.pdf
Page 26.
08F250 CC 6.4 PSD
Banks 6 gun/ram air
40' Stoneridge 5th wheel, coming in at 15.4K.
senix is offline
post #3 of 5 (permalink) Old 11-08-2010, 10:33 AM
OH10Diesel's Avatar
Hey sorry to hear about your problem. What you are seeing an oil leak on your turbo crossover pipe, I noticed this also on my truck about a month ago. 1 dealer tried telling me it was normal, well I like you looked at my buddies truck and sure enough super clean and no oil. So i got a second opinion from a different dealership service tech..... here is what they found and fixed under warranty: They ran an All in 1 DYE test and they found seals at the turbo crossover pipe and at the extension pipe at the turbo both leaking, they removed the degas bottle, and cross over pipe, then replaced gaskets that mount inside of crossover pipe, also had to replace the gasket that mounts into turbo. Hope this helps.
2012 F250 Lariat CC SB 6.7 PSD
Platinum White - Lariat Ultimate
OH10Diesel is offline
post #4 of 5 (permalink) Old 10-10-2016, 08:40 PM
Are these seals able to be purchased and replaced on your own? Just noticed these leaks on my truck
Sent from my SAMSUNG-SM-G930A using Tapatalk
warrior3535 is offline
post #5 of 5 (permalink) Old 10-10-2016, 08:42 PM
Also just switched oils. Would this cause the issue? I recently moved from texas to alaska. So needed to switch toa synthetic oil and lighter weight for the winter time
  Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 6.4L Power Stroke Engine and Drivetrain
