6.4L Power Stroke Engine and DrivetrainDiscussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008-Up Super Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Hi guys;
Question about undercoating an oil pan...is it ok to undercoat an oil pan on a ford deisel engine? Remember, it costs about 2000.00 to lift the engine or cab to replace an oil pan cover. Ford oil pans are known to rot out after 4-5 years...i've heard that from many ford owners as well as different mechanics..I want to undercoat the oil pan with waxoyl, a product that has been successful in the european market for 30+ years. But I wonder if there is any danger of restricting heat loss through the oil pan, because of this undercoating. I can't see any harm, since the engine already has an oil cooler on it (Ford deisel engines). So the question is, will there be any danger of the deisel engine overheating/damage due to undercoating the oil pan? I am getting the truck undercoated with waxoyl and I thought why not do the oil pan as well? Thanks for any advice. JimmyMD.
naw go for it or just coat it every once and a while with rustoleum. Although, since you are going to undercoat the oil pan be sure to do the whole truck. It is shocking how fast these trucks rust.
Before thinking about undercoating the truck, be sure to consult the Ford docs, I think the Body Builder's Layout Book has the info. Basically, you can't undercoat a good 50% or the truck due to the high exhaust system temperatures lest the whole thing go up in flames.
Undercoat it, I did mine.I also work at a bodyshop and we have a dealer right next door, and undercoat trucks for them all the time, and I haven't seen one go up in flames yet!!
__________________ 3/28/03 F250 6.0L PSD ,TORQSHIFT,CC,SB,FX4,LARIAT
Charcoal Gray/Black,
Tint,RhinoLined,Sirius,Roll&Lock,Strobes,
SCT X3 Custom Tuned by Innovative,
MBRP Stainless 4" Turbo Back,
ISSPRO Pyro,Boost, & Trans Gauges
Prodigy Brake Controller,Remote Start and Turbo Cooldown,
High Idle Mod., PM-13A on the Oil Pan,
HFCM Plug Upgrade,DieselSite Coolant Filter,
Energy Suspension Bushings,& Stanadyne every tank
I did have both of our trucks rust proofed and undercoated. Lucky the guy like my 08 and nearly dipped the truck in the undercoat paint and their Zeibart rust proofer.... :-) So i have high hopes...our 05 had more under body rust then my 19yr old suburban... I would suggest everybody take a look under your trucks, our 05 had a ton of rust on the sides (under body) and behind the rear wheels (underbody). We do keep our trucks for ever, so i plan to be driving these trucks for the next 20 yrs.
Correct.....i Get Mine Spot Checked Every Year,i Cant Imagine A Payment On A New Truck.my Pan Is Done And Pretty Much The Whole Truck,no Flames Yet.although That Would Eliminate My Payment...mmmmm....lol
2002 f250 lariat 7.3 200k(motor has 170k)
original 4r100 tranny....200k and counting
knock on wood......
tony wildman chip......
stock,economy,daily,towing,extreme,smoke.
red elc good for 150k
4r100 1-2 2-3 3-4sonnax accumulator valves,.427 sonnax line pressure mod valve
4.125"yes thats 4 1/8" diy tymar intake(size matters...lol)
AIH delete,ccv delete,zoodad mod,
4" exhaust no muff
built my own leafs for 4.0 of lift!!!!!!
18" xd bronze revolvers with 325 nittos to wrap them
isspro pyro and boost guages on pillar mount....
I did mine myself as well. I used the Rus Fre system. That was 2 years and 50K miles ago. I got it as close to the exhust as I thought I could go but not behind it as much.
2011 F350 Lariat DK.Blue/Silver,Black Leather Crew Cab,Short Box SRW. Supplemental Heater,3.55 ELD, Remote Starter. Used for hauling 16ft x 8.5ft. Work Trailer , 8ft. Fisher Plow, Lance 820 truck camper for those days I can get away.
Has anyone used Fluid Film on their truck,you can get it in spray cans for do it yourself apps. I was thinking of using it on mine seems easy enough to apply. Randy
I have started to use rubberized undercoating on mine. Just a bit at a time. Mine is a 2005 and quite rotten already (cant tell from the outside but under it looks rough) - Looks very nice after the treatment
I removed the rust, coated with POR15, then used rubberized undercoating. I am about 50% done thus far. I also coated the chassis with POR15. I have gone though about 6 cans thus far.
Then, I coated the inner door seams, body parts and tail gate seams with oil. (We have done ths to our fords in the past and it appears to work well - we also have a 95 van with NO RUST.
I wish I could have had it done but it was just too much $$$ when compared to $7.00 a can.
yea it was expensive ($340) but they did the underbody, frame and wheel wells with the undercoater plus they sprayed the inner body with the rust proofer. Luckily, ford does supply body plugs so they just remove the plugs, spray and reinstall the plugs. I was quite happy. Will go back in two years and have it done all over again just to be sure. I did the same with the rust, scraped and then painted with rustoleum so when they did their thing all of the rust was taken care of... These trucks are just too expensive to rust that fast, it is unacceptable in my opinion. What ever ford does to rust proof they need to do better.
