6.4L Power Stroke Engine and DrivetrainDiscussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008 Super-Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
I had noticed the truck always seemed to start quickly and consistently... here is how it actually works:
(from this document )
Background
The 2007 F53 motor home stripped chassis and the 2008 F-SuperDuty models have a new engine starting strategy programmed into the Powertrain Control Module (PCM).
Description
One-Touch Integrated Start (OTIS):
The subject vehicles have One-Touch Integrated Start (OTIS), a computer-assisted cranking
system. This feature assists in starting the engine. If the ignition key is turned to the START
position and released when the engine begins cranking, the engine may continue cranking for up
to 10 seconds or until the vehicle starts.
Once the ignition is turned to the START position, the PCM reads starter motor request (SMR)
from the ignition switch and gains control of the starter engagement. The customer is no longer in
the loop after the initial crank request, the customer may release the key to the RUN/START
position. The PCM will disengage the starter motor based on the following events:
• The engine is started (rpm threshold)
• A set time has been exceeded
• The ignition key has been turned to the OFF position
The applicable Ford Shop Manual and the Owner's Guide contain detailed OTIS information.
Black/black leather 2008 F250 FX4 - work in progress - 20" KMC Hotwheels d-back in black, RDS 60gal aux. tank/toolbox Gallery
Black 2002 7.3 Excursion (sold) - 103k and lots of mods, great truck!
my BMW has this feature but on the fords it applies only to gassers not diesels wish mt truck had it every so often I get in the truck after driving the car turn the key and let go and wonder what happened daaa
1974 Ranchro 351 cj green gold
1983 Ranger STX 5 speed bright orange
1987 F-250 ext cab 6.9 White with custom brown side Paint
1999 CC F-250 Lariet FX4 Amber Loaded with all Options LB
2004 SC F-250 XL White tow package
2005 CC F-250 King Ranch Dark Copper FX4 Loaded with all Options SB
2008 F-350 King Ranch Blue Pearl loaded
Land Rovers and Range Rovers have this feature as well
December, '02 build F-250 CC 4X4 Lariat 6.0/Torqshift,Toreador Red over Arizona Beige 4X4 FX4 w/ moon roof. Fancied up with Stull grill insert, chromed tow hooks/bed tie downs, painted door handles, King Ranch flares, Inyati bed liner and short cubbyhole mat. Latest addition: Edge 3" lift Bonspeed eight spoke wheels w/Toyo Open Country 325/60R18 AT's Pics http://community.webshots.com/user/going_going_gone
I have some friends that just bought an '07 1/2 ton dodge with the little v8 (4.7). It has that "feature" too. I personally think it's dumb-if you can't manage to operate a starter you probably should not be driving in the first place. Seems like a way to drive the price of a new vehicle up even more.
1998 12v 5 spd 2wd dually, 271k on truck, bhaf, piers 370's, timing at 16.5 deg, 3k gsk, #0 plate full forward, afc arm on shelf in shop, htb2 64-14 turbo with wastegate set at 45 psi, southbend dual disk clutch, detroit locker, has broken 2 stock dana 80 limited slip units, has run 14.65 at 98 granny shifting the 5 spd, dynoed at 450 hp and 906 ft/lbs on REALLY STINGY dyno
Actually it's just technology, kinda like Fuel injection, piezo injectors, halogen lights. I have it on my 97 bimmer, so it isnt new by any stretch.
Sure it's technology-no one would deny that. The examples you listed of technology serve at least some notable purpose. Saving one from the daunting task of operating an ignition key seems to fall into the "technology" category but not the "notable purpose" category. I'm not crying for the days when a car might not start on a cold morning and an automatic transmission was something only the rich had, but this is getting ridiculous. You can bet the cost to develop it was passed on to everyone who buys the vehicle, including those not stumped or unduly strained by ignition key operation.
It's a solution in search of a problem.
I push a blue button on my FOB while I'm rinsing out my cereal bowl in the morning and 30 seconds later when I go out in the driveway the truck is running, the defrost is on when its cold outside and the air is running when its hot outside.
Make that factory standard.
2008 F450 CC Lariat White/Gold, JAD Solutions Lights, 62 Gal Titan, B&W Hitch, Ford Gold Remote Start, TruckTrunk box, Viair 550+2x2.5gal receiver
