P0088 Error Code - Diesel Forum - TheDieselStop.com
Old 11-16-2009, 08:51 PM   #1 (permalink)
Question P0088 Error Code -HELP!!
2008 F350 6.4 with 120,000miles. Service engine light came on. Had dealer read codes and came back with "P0088 Fuel rail/System Pressure-Too High"
Service tech indicated probable high pressure fuel pump. If replacement required, cab has to come off. Could be $3000!!!! and no factory warranty. Has anybody seen this error code? Does it really indicate high pressure fuel pump failure? Truck is going back to garage to further investigate (they did not have time when I took it in first time) and wondering what else go trigger P088 code?
chuckyleb is offline
Old 11-16-2009, 09:24 PM   #2 (permalink)
tattoocharlie's Avatar
My Photos: (5)
ouchhhhh!!!!!!!!!!good luck,thats the main reason ive been afraid to buy the new sd,repair outta warranty
2002 f250 lariat 7.3 200k(motor has 170k)
original 4r100 tranny....200k and counting
knock on wood......
tony wildman chip......
stock,economy,daily,towing,extreme,smoke.
red elc good for 150k
4r100 1-2 2-3 3-4sonnax accumulator valves,.427 sonnax line pressure mod valve
4.125"yes thats 4 1/8" diy tymar intake(size matters...lol)
AIH delete,ccv delete,zoodad mod,
4" exhaust no muff
built my own leafs for 4.0 of lift!!!!!!
18" xd bronze revolvers with 325 nittos to wrap them
isspro pyro and boost guages on pillar mount....
tattoocharlie is online now
Old 11-17-2009, 03:38 PM   #3 (permalink)
Stymie's Avatar
did they clear the code? Did it come back? There have been more than a few high pressure pumps replaced, but usually for low pressure not to much.
2008 Ford F-250 CC SB
6" Stage II Pro Comp Lift
17x9 Pro Comp 7189
37x12.5 BFG M/T KM2's
Spartan/4" duals/AFE
Try the SEARCH Button
Stymie is offline
Old 11-17-2009, 05:26 PM   #4 (permalink)
Thanks for the reply. Yes they cleared it, and it came back a few hundread miles later. I purchased the truck in Florida and had a 2000 mile drive in front of me. It ran good but the service enine light came back some 5-600 miles later. Still now the truck runs good,good acceleration. Fuel consumption was actually not bad (16 mpg) if I kept it under 70mph. By the way, do you know if these trucks have a governor to limit speed? I read somewhere that Ford had a 75-80 mph limit due to factory installed tires only being rated to 85mph? I am hoping it is only a sensor or poor/bad connection or cable, but the dealer's mechanic seem to think the high pressure pump was the culprit. I'm like you, I would think a failing pump would have low pressure not high?
Old 11-17-2009, 08:16 PM   #5 (permalink)
senix's Avatar
i'd look over the connections and clear the code again. 16 is about what I get at that speed too.
08F250 CC 6.4 PSD
Banks 6 gun/ram air
40' Stoneridge 5th wheel, coming in at 14K.
senix is offline
Old 11-17-2009, 11:33 PM   #6 (permalink)
Stymie's Avatar
the 250-350 have a limiter at 97 the 450's have a limiter in the 80's
17x9 Pro Comp 7189
Stymie is offline
