P2263 - No check ENG light and loss of power ?? - Diesel Forum - TheDieselStop.com
post #1 of 17 (permalink) Old 08-29-2012, 03:07 PM Thread Starter
Hey guys I have been having an issue with my 2008 3rd job F450. I am running a MiniMax on 160 tune and have deleted the DPF an installed an S&B intake. When pulling long steep grades with my 16,000lb trailer I lose boost and power. All of my temps/egts/boost are normal and then its like one of my turbos kick out and my max boost is 24 psi. Once I pull over read my code P2263 then turn the truck off and then back on is fine until the next long pull. The truck does not do it empty or with my 7000 lb trailer hooked to it. I have had it into PowerShops who have loaded the truck down with their dyno and they were unable to duplicate the situation? I'm lost and you guys are my last chance/hope.
Thanks in advance for any help,
Stick thrower
stickthrower is offline
post #2 of 17 (permalink) Old 08-29-2012, 03:12 PM
senix's Avatar
Electronics to the turbos or the turbos themselves is what I suspect.
that code just refers to a system error.
08F250 CC 6.4 PSD
Banks 6 gun/ram air
40' Stoneridge 5th wheel, coming in at 15.4K.
senix is offline
post #3 of 17 (permalink) Old 08-29-2012, 03:47 PM Thread Starter
Senix,
Thanks for the response, ya its a very generic code for the turbos. Either way not good electronics or turbos themselves.
Stickthrower
post #4 of 17 (permalink) Old 08-30-2012, 01:29 PM
Bullett's Avatar
code 2263
My F450 did the same thing when I was pulling a long hill with a load. Went into limp mode. I stopped and checked turbo hoses, one was leaking a little bit and I tighten it up and put my mini max back to "mild" from "wild" and everything worked fine so far.
08 F450 CC Lariat 4X4 auto 488's Mini Max Dpf/cat delete
Bullett is offline
post #5 of 17 (permalink) Old 08-30-2012, 03:02 PM Thread Starter
Bullet, Thanks for the lead, I may have over looked one. I will go back and check. My truck does it on mild also.
2008 F450 3 - 4.30 - DPF gone - S&B intake - Proflo EGR delete - All ran by H&S-MiniMax.
post #6 of 17 (permalink) Old 08-31-2012, 10:33 AM
Bullett's Avatar
code 2263
I saw a little over 30# of boost just before it went into limp mode the check engine light came on. I didn't see the boost go that high on "mild". So now when I'm towing I leave it on mild. The truck seems to like that better.
Bullett is offline
post #7 of 17 (permalink) Old 08-31-2012, 11:59 AM
hkyplr's Avatar
Send a message via MSN to hkyplr Send a message via Yahoo to hkyplr
30 pounds isn't excessive, I have seen close to 40 before with no I'll effects... Except fuel mileage.
2008 F350 CC Long Bed Lariat 4x4 SRW Job 1. H&S Mini Maxx running Mild tunes (for the moment) and S2L Trans tune. 4" Diamond Eye Downpipe back exhaust. S&B CAI. 5th Wheel Hitch. Front Receiver Hitch. Bakflip Tonneau Cover.
hkyplr is offline
post #8 of 17 (permalink) Old 09-24-2012, 01:27 PM Thread Starter
Location of the Exhaust Back Pressure Sensor in 2008?
Okay I am going to try the cheap fix first. Cleaning the Exhaust Back Pressure Sensor. The EBP sensor seems to be getting the most votes from the power shops and technicians I have been talking to. I forgot to ask on important question though - Where is the located? Any ideas?
Thanks in advance,
Stickthrower
post #9 of 17 (permalink) Old 09-24-2012, 11:07 PM
wingnut60's Avatar
I have an '09 and tow 17k--no way can I use even the mild level without elevated EGT. I would have thought that even if it tows ok, the EGT should be over 1400, not 'normal.' or could you define 'normal'? Just my thoughts...
Joe
2010 F450 Lariat 4x4--died, but reborn
2009 F450 Lariat 4x4--died, scrapped
2007 F350 KR DRW CC 4x4-Gone to pasture
2015 Mobile Suites 38RSSA--hoping for another 10 years
2005 Mobile Suites 36TK3--traded, 10 years of camping memories
wingnut60 is offline
post #10 of 17 (permalink) Old 09-25-2012, 05:29 AM Thread Starter
Wingnut60,
My EGTs are 1350 and below, MiniMax is set to defuel @ 1400, my boost is around 34 psi, coolant temp is around 218 degrees. Transmission temp is around 170. I thought those were within limits maybe not?
Wingnut60 what is your normal temps and speed when pulling heavy loads on long grades?
Thanks,
Stickthrower
post #11 of 17 (permalink) Old 09-25-2012, 05:59 AM
senix's Avatar
Originally Posted by stickthrower View Post
Wingnut60,
Thanks,
Stickthrower
Actually those are right in the ball park on a heavy load and long grades. I can usually come right in there. Maybe even higher on the coolant temps.
08F250 CC 6.4 PSD
Banks 6 gun/ram air
senix is offline
post #12 of 17 (permalink) Old 09-25-2012, 12:13 PM
hkyplr's Avatar
Wingnut60,
Thanks,
Stickthrower
I agree, there is nothing wrong with those numbers. Although, I personally wouldn't live very long at 1350 degrees or above.
hkyplr is offline
post #13 of 17 (permalink) Old 09-25-2012, 05:45 PM Thread Starter
Ya 1300 - 1400 sounds crazy hot; I have been told as long as I keep around 1300 I should be good and 1400 briefly. Thanks for chiming in this is all good knowledge for a green weeny like me.
Thanks again,
StickThrower
post #14 of 17 (permalink) Old 09-26-2012, 12:14 PM
Bullett's Avatar
I run as high as 1300* EGT's, 208* trans, 220* water (fan comes on), 232* oil, when pulling hard in 100* heat here in AZ.
Bullett is offline
post #15 of 17 (permalink) Old 09-26-2012, 12:36 PM
Mine runs about the same.
2008 Ford F250 6.4l PSD Lariat Super Cab, Long Bed
2006 Jayco Jay Flight 27.5 RLS Fifth Wheel
zedd is offline
  Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 6.4L Power Stroke Engine and Drivetrain
