Passive Regeneration -- Urban Legend? - Diesel Forum - TheDieselStop.com
Old 12-12-2008, 01:56 PM   #1 (permalink)
GEARJAMMER's Avatar
My Photos: (10)
Post Passive Regeneration -- Urban Legend?
I have all of the latest and greatest flashes, so I know when my truck goes into regeneration. The harder I work the truck, the more it regens, whether I'm towing, loaded, or empty.
I think passive regens are an urban legend!
Shawn
2008 F-450 JOB-1, 4 X 4 with 4.30's, auto with manual transfer case with factory cup holders. All options except sunroof and nav. Line X with Extra. 24K Draw-Tite Signature Series Fifth Wheel Hitch. 65 Gallon KSH Marine fuel/tool combo in bed. Viair 480C compressor with 8 gallon tank. Hadley Air Horns hooked up to Auto Mate alarm. Chime/Light Killer Mod. Polished Job-1 exhaust tips. Transmission upgraded to JOB-2 filter, pan, and lines. External filter eliminated.
PICTURES
GEARJAMMER is offline
Old 12-12-2008, 02:12 PM   #2 (permalink)
Stymie's Avatar
a passive regen means it regens while driving and doesnt overtly effect the truck, as opposed to active regen at idle(or so i was told)
2008 Ford F-250 CC SB
6" Stage II Pro Comp Lift
17x9 Pro Comp 7189
37x12.5 BFG M/T KM2's
Spartan/4" duals/AFE
Try the SEARCH Button
Stymie is offline
Old 12-12-2008, 02:47 PM   #3 (permalink)
GEARJAMMER's Avatar
My Photos: (10)
I hear you and I was told the same thing. I'm calling B/S on what we've been told. The more I pour the "coal" to it the more it regens. As I stated above, the harder the truck works, the more regens I have.
Shawn
PICTURES
Old 12-12-2008, 02:58 PM   #4 (permalink)
F450Mikey's Avatar
Shawn
I think with the latest greatest flashes Ford reset the parameters/thresholds for passive regens. I notice them less and less. It is the active regens at idle that are a thing of the past!
2008 F450 Dark Shadow Gray Lariat "Pick Up" Job 1
2006 Weekend Warrior FSC 2800
2005 Honda CRF 450R
F450Mikey is offline
Old 12-13-2008, 12:54 AM   #5 (permalink)
Shawn
The thing here is a matter of definition. Active regen is when the PCM commands excess fuel into the DPF to burn out the soot. When the engine is operating at a level where there is less oxygen than fuel, it will soot. (heavy load with low boost for the engine rpm and load) So when you have your foot in it hard, it is going to active regen more, because more soot means more plugging and more of the PCM stepping in and doing something about it. Passive occurs at mid level loads where there is a surplus of air and still enough exhaust heat to burn off the soot. The PCM has nothing to do with it.
Basically there is a fine line between right foot positions where too little or too much will lead to more active regens. But when baby bear is just right....
Dad always said,"Knowledge is limited but stupidity knows no bounds."
YT90SC is offline
Old 12-13-2008, 09:51 AM   #6 (permalink)
GEARJAMMER's Avatar
My Photos: (10)
I Disagree.
This is where I have to disagree. The original explanation of a passive regeneration was to work the motor hard enough to get the exhaust hot enough to burn the particles out of the DPF. When you do this, you create more soot even at "mid level loads." That's a given. If you drive as you suggest, you are creating less soot and the exhaust will never get hot enough
Maybe someone can tell us what the exhaust temperatures run during an active regeneration. I would think for a passive regeneration to burn off the soot particles, the exhaust temperatures would have to be very close to the exhaust temperatures during an active regeneration. That is simply not going to happen
Shawn
PICTURES
Old 12-13-2008, 11:44 AM   #7 (permalink)
I had an active regeneration yesterday. According to my EVO monitor, the EGT in town were running about 700-800, once I got on the interstate and above 50-mph the
EGT shot up to 1100-1200, even though the boost levels were low. On my 04, I would not see those EGT levels unless I was towing the camper with high boost and air conditioning on. It was interesting to note, that I had about 10-15 minutes of in town driving before I could get on the highway, but once I got on the highway, the active cleaning went much quicker due to the higher temps. So, I am thinking anytime I have a regen, to take a quick lap around the beltline to expidite the cleaning process. I wonder if the in town driving with the lower egt's would qualify for a passive regen? This was my first regen as my truck only has 700 miles on it.
IN GARAGE: 2011 F350 4x4 C.C./L.B Dark Blue Pearl....Loaded
Traded 2009 F350 4x4 C.C./L.B.- 6.4 Auto
Traded in 2004 6.0 4x4 Crew Cab
Traded in 2000 V-10 4x4 Island Blue Supercab
gossamar is offline
Old 12-13-2008, 12:27 PM   #8 (permalink)
1800 degrees F or more from what I've read.
timid1 is offline
Old 12-13-2008, 05:41 PM   #9 (permalink)
Stalwart's Avatar
UM . . . NO! 1000-1100 is more like it. No OEM is going to subject the turbos to that kind of abuse, you'll only see those numbers in full out race trucks. It wasn't that many years ago that EGT's 1200 degrees would run the risk of melting parts on turbo Diesels.
Stalwart is offline
Old 12-13-2008, 06:00 PM   #10 (permalink)
compman72's Avatar
My Photos: (9)
Could that be the temps in the DPF when cleaning??
2008 F250 XL Crew cab, manual 4x4, 6.4L, Job 3, TorqueShift, w/ Decor group, Camper Pkg, Off Road Pkg, LWB, Power Equipment Group, Tow Command, Knapheide Utility Bed with sliding top. Built 2/5/2008 & Purchased 9-1-08
08B07 Flash 1-16-09
Firestone Ride Rite Air Springs 3-20-09
Radiator (end cap leak) @ 34,100 miles 11-19-09
11B23 PCM Recalibration 4-11-11
Hydroboost Replacement (leaking Power Steering Fluid) @ 82,866 miles 7/25/11
Upper & Lower Hoses (new design) @ 90,000 miles 11/10/11
compman72 is offline
Old 12-13-2008, 10:25 PM   #11 (permalink)
passive regens?
I am by far not a mechanic or some guru on diesels, but my 2008 6.4 job 1 last week went into a regen, it told me on the message center: cleaning exhust filter and was smokeing even in the city but it had to be over 30 the mileage went dn to around 7.3 mph, but this week the mileage went dn to around 7.8 mph no message was on the dash and it smelled, was this a passive regen oh and the idle was high when in park.
jasvan10 is offline
Old 12-14-2008, 01:31 PM   #12 (permalink)
GEARJAMMER's Avatar
My Photos: (10)
Post It sounds like your truck was in regen
Do you have the latest flash like I do? It's the one they stopped doing. The "CLEANING EXHAUST FILTER" stays on in the message center the entire time unless you hit reset.
It sounds like you have an older flash. The "CLEANING EXHAUST FILTER" message only stays lighted for a couple of seconds. Is it possible you could have missed it? With the high idle in park, it sounds like your truck was in an "active regeration" and not a "passive regen."
With the older flash where you could have missed the "CLEANING EXHAUST FILTER" in the message center, all you have to do is is hit "SETUP" and then "RESET." This will run a check at it will show if you are in an "active regeration."
IMHO I think a so called "passive regeration" is a fable, urban legend, or a very nice bedtime story told to us by mother .
Shawn :smokin"
PICTURES
Old 12-15-2008, 04:46 PM   #13 (permalink)
Stalwart's Avatar
Passive regeneration will most definitely occur but VERY few of us work our trucks hard enough to make it happen. To get EGT's to 1000+ degrees for 5-10 minutes is a fairly hard pull. I've done it on my F450 but I was at 35,500 lb. GCVW at the time. That day of pulling I completely missed my regular, like clockwork, regen.
Stalwart is offline
Old 12-15-2008, 07:01 PM   #14 (permalink)
GEARJAMMER's Avatar
My Photos: (10)
Exclamation Look at my original post.
What build is your truck? When you have a "regeneration," does the message center stay lit with the "CLEANING EXHAUST FILTER" message? Could you have missed the message for "regeneration?" If you go back to my very first post, when I pull hard and I get regular "regenerations." They are to close together to allow for a "passive regeneration." Until I got the latest flash, I believed in the "passive regeneration." I no longer believe this. In fact, it's a real eye opener to see how much the truck does go into "regeneration."
Shawn
PICTURES
Old 12-15-2008, 07:28 PM   #15 (permalink)
Greyman's Avatar
My Photos: (6)
"Passive regen happens whenever exhaust temps exceed approx. 1,076 degrees F without a fuel consumption penalty. Active regens occur when the DPF sensor triggers a burn off and requires the engine to force higher exhaust temps, 1,076 to 1,200 degrees F." This is out of Diesel Power Mag., from the mouth of Charlie Freese a GM duramax engineer. I'm guessing our motor is close to the same.
2008 F350 CC SRW LONGBED Larait, moonrf, pwr slider, tow comm., backup cam.& sensors, camper pack., chrome pack.,audiophile, 60/40, 3.73 LS,stock 6.4, Torreador Red/Silver accent, Ride-rite air bags 2071 and 2219 controller,torklift stable load bumpers, dieselsite external tranny filter kit, duraflaps front and rear, Line-X, A.R.E. Z-series canopy, keyless entry, fold-down front slider, 2 lights. Tork lift camper tie-downs, Fast-Guns
10'2" Citation Supreme w/slide & all opt.s
1978 F250 Supercab 4wd Camper Special , 400, Edelbrock Performer 600 carb & intake, 4.10 LS, C-6, custom autosound radio, new interior, 68,000 orig.
1978 F150 reg cab xlt lariat trailer special 400 stock
1970 Torino Cobra 429 CJ C-6 13.02@ 103 1/4 mile, 3.50 Trac. Lok
1970 Torino GT Conv. 4 speed 351C 2bbl
Greyman is offline
