Go Back   Diesel Forum - The Diesel Stop.com > 2008-Up Super Duties > 6.4L Power Stroke Engine and Drivetrain
6.4L Power Stroke Engine and Drivetrain Discussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008 Super-Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Old 10-15-2007, 10:40 AM   #1 (permalink)
Question 6.4L ambulance over 6.0L
My Service is discussing new ambulances and we are deciding between an F series with the 6.4 and an E series with the 6.0 does anyone have any info that can help?
thanks
2000 F350: AIS Intake
nunook is offline
Old 10-15-2007, 11:12 AM   #2 (permalink)
ford_doctor's Avatar
Re: Question 6.4L ambulance over 6.0L
I was involved in a discussion concerning the use of F-Series trucks in lieu of other makes or gas powered Econolines for use as ambulances. I recall the only main issue was the vehicle height, the F-Series being higher than an Econoline with the ambulance prep package. I don't know the specifics of the package but I was informed that there is a company that modifies the rear suspension with air bag springs that rides lower AND has the ability to squat. This is key to safe loading and unloading.
Ford Master Diesel Technician
ford_doctor is offline
Old 10-15-2007, 12:00 PM   #3 (permalink)
My department just got about 10 Rescue's that are all 6.0L E-series..... we've had alot of problems with them.... We've had several that have just died on a run and had to be towed into the shop. If that helps at all. I'd get the F-series with the 6.4L...... the truck is more comfortable in the front anyways!
2008, F-250, FX4, Crew Cab, Short Bed, Oxford White w/ black interior, Dual Alternators, Sat. Navigation & Radio, Overhead DVD System, ESOF, Solid Rear Window, 3.73 Limited Slip, Upfitter Switches, Tow Command System w/ Power Scope Mirrors, Power Seats, and the Reverse Aid Sensor - Edge Insight Monitor, 2.5" Donahoe Racing Lift Kit, Fox 2.0" Piggy-Back Shocks, KMC Beadlocks w/ 35" Toyo M/T's, MBRP DPF back exhaust, Recon mirror lights, Fitch Fuel Catalyst, Randy Ellis Design Light Bar, Line-X, MotoBar, Gentex Temp/Direction Mirror
RRose is offline
Old 10-15-2007, 04:36 PM   #4 (permalink)
Word is that the 6.4 will be going into the E series within a month or so. 2008 vans with gas engines are on dealer lots. I think that the "cab off" procedure may require some/many quick disconnect wire harness' and some rethinking of the cab to box junction. That is assuming that ford will certify the E-6.4 for ambulance use. Don't know if they have certified a gas E for ambulance use.
toalpi is offline
Old 10-15-2007, 04:41 PM   #5 (permalink)
A 6.4 is better on the enviroment with all the idling the ambulance will do.
Y2K excursion XLT 2wd, ordered july '99, built august '99, delivered september 9 '99, 4R100 fried & replaced at 900 miles still running like a champ
exoval is offline
Old 10-15-2007, 10:18 PM   #6 (permalink)
The E's already have the 6.0 for 2008 that is what for is going to be doing and it is unsertain about the future of E's with diesels
nunook is offline
Old 10-16-2007, 01:38 AM   #7 (permalink)
KINGTUT's Avatar
My Photos: (19)
My local municipality went total gasser after several failures with the 6.0 and a lawsuit. Don't know what that says about the 6.4. The paramedics down at City Hall got tired of mopping the oil out of the bay along with some no start/mechanical deficiency issues.
KINGTUT is offline
Old 10-16-2007, 04:18 PM   #8 (permalink)
I thought ford dropped diesel all to gether in the E series. Was that in vans and not van chassis?
1969 Ford F-250 Camper Special 360 V8 4 speed
1998 Ford Explorer XLT 4X4 4.0L V6 124K
Stock. Daily Driver
2001 F-350, Ext Cab, LB, XLT, 4X4, 127k
K&N Filter, Walker BTM, Edge Evo
B99 Biodiesel.
2004 F-250 6.0, CC, SB, Lariat, 66k, BFG 285 A/Ts
Stock.
CWU 2010
01F350PSD4x4 is offline
Old 10-16-2007, 04:36 PM   #9 (permalink)
yes it was a late '08 add in, both vans and chassis but it is still a detuned 6.0l
nunook is offline
Old 10-16-2007, 04:37 PM   #10 (permalink)
this is my problem. People wnat the van chassis but I am unsure about the engine.
nunook is offline
Old 10-17-2007, 12:09 AM   #11 (permalink)
Avoid the 6.0L in a modular application. They're not much better, but acceptable, in a "vanbulance" type application.
I work part-time for a private service that does mainly interfacility work. We have 7.3's and 6.0's. The "fleet manager" (a.k.a. mechanic) has extensive experience with Ford diesels-he was a Ford tech at one time. He just about pulls his hair out over the 6.0's. He doesn't think we'll get anywhere near the miles out of them that we do the 7.3's (usually around 250-300k relatively trouble free miles).
One of the big problems he sees, especially in the modular applications, is the heat buildup under the hood because the motor has to work so hard. It fries the wiring, electronics, belts, hoses, etc.
I'm not a professional wrench bender, not even much of an amateur one, but one of the beliefs I hold dear is "There is no substitute for cubic inches". The mechanic tends to agree with me; he likens it to taking a small framed person, putting them on steroids, and having them compete in powerlifting contests with the big guys. The little guy may be able to keep up for awhile, but eventually he will give out, and usually way before the big guys.
People don't dial 911 because things are going right.
HuskerMedic is offline
Old 10-17-2007, 02:01 AM   #12 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Nunook</div><div class="ubbcode-body">yes it was a late '08 add in, both vans and chassis but it is still a detuned 6.0l </div></div>It hasn't happened yet. Word is now 6.4
toalpi is offline
Old 10-17-2007, 11:06 AM   #13 (permalink)
I can add some info on this, no specifics however since I'm not directly involved, but here in my area, we have an ambulance company with similar experiences of Kingtut and RRose.
They are running the 6.0's and have had nothing but huge problems with the entire 16 truck fleet!! Enough for a lawsuit to get started, and usually have as many as 6 of the 16 down at any given time for one thing or another.
Last I heard, they're dumping the entire fleet of 16 for something else from GM. [img]/forums/images/%%GRAEMLIN_URL%%/mad.gif[/img]
TurboDave, EWCS(SW)USN Ret
H&N Turbo 6 Racing
Seviervile TN
A MAN AND HIS TRUCK, IT'S A BEATUFUL THING
01 Excursion LTD (EBM3) 7.3L, PSD, Turbo, 4X2, TTS Race Magnum (original owner)
86 GN (original owner)
87 GN (second owner)
08 Honda Accord EX-L
My Photo Gallery
turbodave is offline
Old 10-17-2007, 02:21 PM   #14 (permalink)
I would strongly recommend going with the the F series chassis over the E series. The 6.4L so far seems like its going to be good. Much quieter and plenty of power. Havent heard of any major problems. My dept. has an F550 4x4 w/ air ride suspension and its great. Much nicer to drive than our secondary amb. which is an E series and plenty of room to work w/paitents in the back. The suspension automatically dumps when back doors are opened which makes easy to load/unload gurney and easy to get in and out of. No height issue at all. Hope this helps
ktm923 is offline
Old 10-24-2007, 02:12 PM   #15 (permalink)
Texrob1's Avatar
Send a message via Yahoo to Texrob1
I just saw Laporte Tx EMS got a new F450 Ambulance,Very Nice & Rugged looking Rig,it makes the Deer park EMS F350's look kind of small..
2005 F250 XLT wedgewood blue 4x4 C/C SWB,6.0L PSD, Auto.(Member of 05 STC Failure Club ) 2006 Expedition Eddie Bauer,5.4L (Wife's) NRA Life Member. TSRA Life member.
Texrob1 is offline
