Go Back   Diesel Forum - The Diesel Stop.com > 2008-Up Super Duties > 6.4L Power Stroke Engine and Drivetrain
6.4L Power Stroke Engine and Drivetrain Discussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008 Super-Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Old 11-15-2007, 09:21 AM   #1 (permalink)
Rearend humming???
I own an F-450 w/ 4.88 gears, and at certain speeds I can hear a humming noise on the rearend. If I throttle it up a little ,it goes away then let go @ about 30-40 mph you can hear it hum. The truck has 27K miles on it now so I think I better take it in for inspection. Any one with similar problem??
jayflores is offline
Old 11-15-2007, 09:51 AM   #2 (permalink)
My Photos: (14)
Re: Rearend humming???
I have an F-450 4x4 w/4.30 axle and the maximum traction rear tires. I have noticed more tire noise at certain speeds but no rear end noise. If you're hearing a change in noise at different throttle settings it could be the ring gear. Try putting it in neutral when you hear the noise. If you still hear it then it's probably the tires.
'08 F-450 King Ranch 4x4, 6.4 PSD, Torqueshift, 4.30, white/pueblo gold, Job 2 build.http://photos.thedieselstop.com/show...00/ppuser/6352
JESSE 1 is offline
Old 11-15-2007, 11:09 PM   #3 (permalink)
My 08 F-250 4x4 CC w/3.73 axle with 4200 miles has low frequency humming/light vibration that started a week ago. Something in my drive line begins humming when I get right past 50 mph and goes away once I get to 60mph. I can take my foot off the accelerator when it starts and the noise will stop but will resume as soon as I put my foot back in it. I haven't had a chance to take it in but this along with the 2 injectors I've already had changed plus the rattle in the dash that sounds like a mouse has got me regretting I bought this thing and that fuel economy and regens only add to my frustrations. I'll ask about the rear end when I drop it off, Thanks
Tomas in Lake Jackson, Texas
'08 F-250 Lariat, 4x4, Crew Cab, SWB, 2" lift, Harley 20's, white/pueblo gold, Job 1
tomres2003 is offline
Old 11-16-2007, 02:10 AM   #4 (permalink)
I seem to remember a few TSB's about driveshafts on 08's with dana axles (80 & S110) and moan/drone/whine condition @ 1500-2000rpm and/or 50-60mph.
Was only for the DRW's though.
Sorry I couldn't be more help.
LittleBigRig is offline
Old 11-16-2007, 10:56 AM   #5 (permalink)
guardrail22's Avatar
have the carrier bearing for the driveshaft checked
2008 F450 CC Lariat White/Gold, JAD Solutions Lights, 62 Gal Titan, B&W Hitch, Ford Gold Remote Start, TruckTrunk box, Viair 550+2x2.5gal receiver
New Truck
http://www.f150online.com/galleries/....cfm?num=15052
Traded In Nov 07: 2003 F250 CC LB XLT 4x2 PowerStroke, Captains Chairs, White/Parchment, Torqshift, Heated Mirrors, Trailer hitch, Adv Security Group, Clearance Lights, Adj Pedals, Privacy Glass, Sliding RW
Delivered 11/27/2002
7100# with full fuel and no occupants
towing a 2005 Pilgrim 306RL-SS w/Hensly Arrow
http://www.f150online.com/galleries/...w.cfm?num=3016
guardrail22 is offline
Old 11-19-2007, 11:02 AM   #6 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: guardrail22</div><div class="ubbcode-body">have the carrier bearing for the driveshaft checked </div></div>
My initial thought as well. That, or try some Gas-X
2008 SD 250 PSD King Ranch 4X4, SWB, CC, Auto 3.73
Viper 791 XV alarm with remote start. FS2500 bypass filter. Edge Insight multi gauge. Line-X. Retrax.
Sequoia is offline
Old 11-19-2007, 12:02 PM   #7 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: LittleBigRig</div><div class="ubbcode-body">I seem to remember a few TSB's about driveshafts on 08's with dana axles (80 & S110) and moan/drone/whine condition @ 1500-2000rpm and/or 50-60mph.
</div></div>
You are correct about the TSB's. Here is the one that may apply in this case...
TSB 07-16-3 AXLE WHINE NOISE - 50-60 MPH (80-97 KM/H) - WIDE FRAME WITH PICKUP BOX - DANA S110
FORD: 2008 F-450
ISSUE:
Some 2008 F-Super Duty F-450 wide frame vehicles equipped with a pickup box and the Dana S110 axle may exhibit an axle whine noise between 50-60 MPH (80-97 Km/h). Most noticeable at 58 MPH (93 Km/h) under load during a floating condition with a tip out then tip in on acceleration.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
Replace the driveshaft with revised service part per application.
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
'04 F-250 Harley-Davidson 6.0L CC SB
PowerStrokeHD is online now
Old 11-20-2007, 08:52 PM   #8 (permalink)
Mad Max's Avatar
My Dad's new F-450 did the same thing and the dealership ended up replacing the Rear End. That was about 15K miles ago and so far so good.
If you live in AZ come join us at Arizona Powerstroke Group... Click here...
http://www.azpsg.com/index.php?referrerid=6
99.5 F-350 PSD Lariat, 4x4 Off Road, CC, SB, 3.73's, NVK2, BTS Trans and T/C, V-10 and Tru-Cool Max Trans Cooler, Evans NPG Coolant, BTS 100 HP Chip, ART Cryogenically Treated & Slotted Rotors with Performance Friction Brake Pads, Dynatrac Spin Free HD Front Hubs, TAG I & II, Ford AIS Intake, 4 inch Stainless Exhaust from turbo to 5 inch chrome tip. Auto Meter Ultra Cobalt Gauges. 35X12.5 BFG KO's on 16x10 Rims, Bilstein Shocks.
Mad Max is offline
Old 11-20-2007, 09:44 PM   #9 (permalink)
Mine goes in for this next week and my 3rd radiator we'll see what happens
2008 F450 CC Black
KAT Transport Services Inc Media , Pa
Support your local Ford Technician buy a 6 Liter
SVTKYLE is offline
Old 02-05-2008, 12:31 PM   #10 (permalink)
OTP
I have the whine in a 08 450 with 4.88's. First time to the dealer, they said it was a new truck and they did not have the tools to inspect it.
While I was checking around to find out if there was any truth in that, they called to say there was a TSB for the driveshaft and to bring it in. Driveshaft was replaced and the whine is still there.
Took it in today for an unknown leak coming from the area of the left side headlight (light oil) and the service advisor said she will call in a few days. I said yeah righ, you mean hours?
"No these new trucks take time to figure out sometimes, and we have a few ahead of you."
Until the 08's this dealer has not sold many, if any 450/550 so they may truly not have the tools for the larger rearends in these truck, but they should. I will see what they say later today, adn then probably will have to go to a dealer who knows the heavier trucks.
OTP is offline
Old 02-05-2008, 03:11 PM   #11 (permalink)
Find a commercial Ford truck dealer. That is what I use, they have the equipment, experienced diesel techs to handle our larger trucks.
2008 F-450 Lariat Dark Stone Metallic over Pueblo Gold 4x4(manual shift transfer case, manual hubs), High capacity tow 4:88s, Off Road, Camper packages, Sirius Sat, Upfitter switches, DVD entertainment, tailgate step, traction control, Audiophile 6-disc, PTC Supplemental heat and heated seats(warm buns), rear sensors, traction control, tailgate step. Built May 8, delivered May 24
Reese Signature Series 24k fiver hitch, I installed it myself, best hitch I have found yet
Line-X bedliner, heavy duty floor mats
2003 Sunline F281SR(weekend getaways)
SeaRay 215EC
http://community.webshots.com/user/C...host=community
CaptSkup is offline
Old 02-05-2008, 03:26 PM   #12 (permalink)
OTP
I will see what they say this time and go from there. I talked to a commercial dealer this morning and he made it clear that it was no big deal to open up the diff and inspect them. I will take it there if I get anymore inflated stories.
OTP is offline
Old 02-05-2008, 07:19 PM   #13 (permalink)
OTP
I got the call that my oily leak is the radiator, my chirping while cold is a pulley and they still need tools for my rear end. Parts on order and I will be getting a loaner vehicle. Sure hope it can tow.
This truck has been real nice, and despite these little issues, I am still a Ford man. I could care less about mileage, but I want my truck back.
Is it true that my coolant is 60,000 mile rated and light gold in color? I thought this was a hydraulic leak and they tell me it is the radiator.
The chirping could very well be a pulley, and i do not dispute that one, but the tool issues does have me a little miffed.
In a nice way, I tried to tell the service lady that this is the Dana s110 and has been used in other years, so why do they not have the tools, and she assured me that despite the above, the new trucks have newer rear ends and are different.
Not being one to rattle the cage of the person with my vehicle, I made her think I believed that, but have serious doubt going on.
OTP is offline
Old 02-05-2008, 09:24 PM   #14 (permalink)
rearend humming ( Can it carry atune?)
In all sincerity, my suspicion is that the shims are wearing in and need to be adjusted?
Airforce is offline
Old 02-06-2008, 12:49 AM   #15 (permalink)
FLATBED ED's Avatar
My 550 did the same thing. Ford replaced the rear end. Not the whole thing,just the inner parts. It was out of tolerance. They had to redo it a few times before they gave it back to me. No more noise. It is very quiet. BTW,I had 14,000 lbs. on it today. No problem. Just leave some braking distance.......
FLATBED ED,99 F-450(May she rest in peace)
2008 F-550 w/16-ft. Flatbed
FLATBED ED is offline
