6.4L Power Stroke Engine and DrivetrainDiscussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008 Super-Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Has anyone changed out the exterior transmission filter that is installed on the Job1 trucks equipped with the Torqueshift? I am only at 13,000 miles( and will probably stay there for awhile with diesel at $4.79 a gallon) but want to plan for future filter replacement. It looks like a solid cannister that has to be replaced as a whole without a seperate element. I understand that Job2+ trucks have an interior conventional filter, wonder if I can have my Job1 adapted to this setup. The couplings on my truck's filter look to need to have special tools to seperate the lines from the existing filter much like fuel lines.
2008 F-450 Lariat Dark Stone Metallic over Pueblo Gold 4x4(manual shift transfer case, manual hubs), High capacity tow 4:88s, Off Road, Camper packages, Sirius Sat, Upfitter switches, DVD entertainment, tailgate step, traction control, Audiophile 6-disc, PTC Supplemental heat and heated seats(warm buns), rear sensors, traction control, tailgate step. Built May 8, delivered May 24
Reese Signature Series 24k fiver hitch, I installed it myself, best hitch I have found yet
Line-X bedliner, heavy duty floor mats
2003 Sunline F281SR(weekend getaways)
SeaRay 215EC http://community.webshots.com/user/C...host=community
I was wondering the same thing about changing to the job2 tranny filter. I am not sure what is involved externally to the trans, but I reviewed the shop manual procedure for trans filter replacement. It seems to indicate the PAN and internal filter are different in the Job2+ setup. Not sure if its worth it or not
If it is the same as on the earlier 6.0's. There is a hex nut on the bottom. Use an impact wrench to break it free or you will twist it off the bracket. Just pop it with the air gun to start it then spin it off by hand. The element looks like a roll of toilet paper (small)
2008 F-450 Lariat loaded on order 7/3/07 delivered 9/13/2007 Pueblo Gold and all the goodies except Nav radio and moonroof and Fisher 8'6" X-blade
2005
F-350 Lariat LOADED CC SRW LB 6.0 SOLD
Med. Wedgewood Blue
All Options except moon roof
8'6" Fisher X-blade SS
2003 PSD 6.0 Lariat CC SB SOLD
All options but the moon roof
Go to the link below. From the table of contents select automatic transmission. Then select section 307-01. From that menu, scroll down to general procedures and you will see a topic for the remote filter...
1991 YJ
Dad has a 2004 6.0L all stock.
1960 CJ5 all stock
1987 F-250 XLT lariet 6.9L [img]/ubbthreads/images/graemlins/cool.gif[/img] 3.55 limited slip, 4 speed, auto meter pyro, Napa water temp and oil pressure, 344,460KM on her. Injector pump rebiult at 255,000 KM Here are some pics of her
Correct, the TorqShift is technically a 6 speed that only uses 5 during a given shift pattern. 4th gear is only used in extreme cold situations as a replacement for 5th gear...
Normal Shift Pattern - 1,2,3,5,6
Cold Weather Shift Pattern - 1,2,3,4,6
__________________ '04 F-250 Harley-Davidson 6.0L CC SB
Thank you very much, PowerStrokeHD for supplying the information. I greatly appreciate it.
