Go Back   Diesel Forum - The Diesel Stop.com > 2008-Up Super Duties > 6.4L Power Stroke Engine and Drivetrain
6.4L Power Stroke Engine and Drivetrain Discussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008 Super-Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Old 05-28-2008, 04:09 PM   #1 (permalink)
CooperDog's Avatar
Seems like it's missing on acceleration
Just had the truck in to replace #1 injector. Before it went in I had a loss of power and a shuddering effect almost like driving down a washboard dirt road. The whole truck shook and I was going nowhere fast. After getting the injector replaced, I pull off of an off ramp the other day and it started to do the same again, put it to the wood and it finally woke up a bit, but left a huge plum of smoke (white or gray in color) behind it.
Just today on a 150-mile trip it started again. I slowed to go through a toll plaza (30 mph) and gave it throttle. It hesitated and smoothed out then about 3 seconds later it just took off. After my whole narrative is this the effects of the regen? Do you loose the power and have the hesitation during that cycle? It almost feels like a gas motor that has water in the fuel. Any help would be appreciated as I am going back to the shop real soon.
Thanks,
Coop
2008 F-250 6.4 3.73 Lariat Crew Cab, 4X4, Sunroof, NAV etc.
2003 F-350 CC 6.0 4WD DRW 4.10 5 Speed TorqShift
With Cooper Dog (Bloodhound) in back seat, DPPI 4in Turbo Back, thumping stereo. Bilsteins, $5 AIC Mod (SOLD)
2004 Keystone Everest 361P
2000 F-250 2WD 7.3 6 speed manual (Sold)
www.unitedbatteryfl.com
CooperDog is offline
Old 05-29-2008, 07:22 AM   #2 (permalink)
No service engine soon light??
It might just be a regen, but usually you don't notice them.
What was the weather like? There are reports of problems with water ingestion that would cause similar symptoms.
rlchv70 is offline
Old 05-30-2008, 07:56 AM   #3 (permalink)
CooperDog's Avatar
It was bone dry and hot. I am starting to get somewhat frustrated with his truck. I was so pleased when I first bought it and I still love it but it is just unsettleing to spend the money on one of these and have it acting up.
I just broke 5000 miles and I ran the crap out of it yesterday so we will see if it has cleared up. I still suspect something is just not right.
Thanks,
Coop
Old 06-05-2008, 05:30 PM   #4 (permalink)
Coop,
I was reading your thread and your issues sounded exactly like mine so I decided to post up my debacle.
New member, New truck, Blown engine
-Allen
Maxed is offline
Old 06-12-2008, 12:09 PM   #5 (permalink)
shotgundave's Avatar
The same thing here, same symptoms as mine before the engine let go. Mine also fueled it self last going off. I just killed the ignition when it happened, but the ford machanic must have slipped it in N then he said it went past the red line and bang...
shotgundave is offline
Old 06-16-2008, 10:29 AM   #6 (permalink)
FYI, during a regen you'll actually notice what feels like increased acceleration, until boost hits and levels off at 20 psi.
2003 350 Lariat FX4 Short Box 6.0L *SOLD*
2008 FX4 F350 6.4L Dually Long Box, Black on Black PICTURES
2007 Keystone Raptor 3712TS PICTURES
newbie_101 is offline
Old 06-17-2008, 08:35 AM   #7 (permalink)
CooperDog's Avatar
So far it is running OK. I did feel the shuddering and missing feeling the other day, but knock on wood it seems to be running OK. The problem seems to be intermittent and only on a hard acceleration such as passing someone on a two lane county road. Any thoughts...wiring bundle chafing, bad peddle sensor?
Coop
Old 06-17-2008, 10:43 AM   #8 (permalink)
jays2003's Avatar
I have heard this on another truck something to do with a wire harness under a metal cover by the turbo. I'll try to find the thread. In that case they needed to pull the cab. THe owner stated that the truck would fall on it's face from a dead stop and them bam it took off ..
Tow Vehicle: 2008 F250 4x4 Crew Cab Manual 4x4 (No Auto 4x4 Here) Lariat Loaded, Leather, DVD player, Audiophile sound system, Memory seats, power extend mirrors, tow command system, tailgate step, bed extender, Rancho 4" lift with BFG 35/12.50 Rancho XL 9000 Shocks.
Towed Vehicle: 2005 28' Sprinter Copper Canyon 5th wheel with slideout
66' CJ5 Rock Ready..
Pics Coming soon!
jays2003 is offline
Old 08-14-2008, 04:51 PM   #9 (permalink)
foreman1063's Avatar
Originally Posted by [LEFT
CooperDog[/left];1576841]Just had the truck in to replace #1 injector. Before it went in I had a loss of power and a shuddering effect almost like driving down a washboard dirt road. The whole truck shook and I was going nowhere fast. After getting the injector replaced, I pull off of an off ramp the other day and it started to do the same again, put it to the wood and it finally woke up a bit, but left a huge plum of smoke (white or gray in color) behind it.
regen
Thanks,
Coop
My 08 with 14K is starting to have the same symptoms. Driving 60mph and hit the gas to pass, the truck shudders, hesitates for a few seconds then takes off leaving a huge trail of brown smoke. Any updates on this?
foreman1063 is offline
Old 08-14-2008, 09:46 PM   #10 (permalink)
Not everyone of these issues can be solved with this, but it is the easiest fix, and should solve some problems that may be mis-diagnosed as injector problems.
Have your dealer check the throttle position sensors. The pedal assembly and sensors have been found to be at fault on a few trucks that were originally diagnosed with injector failure.
Tritonbmc is offline
Old 08-14-2008, 11:42 PM   #11 (permalink)
Dodge has some problems with turbo's getting sooted up from the emissions crap. They've developed a cleaning procedure, but some have had to be replaced. Software issues mostly seem to be resolved with the G-30 recall. Fortunately, very few injector issues or other "hard" failures.
Now, if they'd just build a truck with the Ford Chassis/Interior, the Allison Transmission, and the Cummins 6.7 and you'd have the perfect truck........
'07 2500 CTD Mineral Gray QC SRW 4X4 LSD 68RE Auto Laramie
'05 3500 CTD 610/325 STL QC LWB DRW 4X4 LSD 48RE Auto Big Horn.
'99 Dodge 2500 CTD QC 4X4 Auto, 4.10 rear, Edge EZ, only 117,000 miles
'93 Dodge Ext Cab CTD 2WD, auto, 3.54, no mods, only 152,000 miles
T210DRVR is offline
Old 08-15-2008, 03:25 PM   #12 (permalink)
Mine does it too.
I am working on 71k and my truck does it more on humid/raining days, but it will hesitate and blow smoke for a few seconds. I can make it stop by letting off the gas, but I think its something with the egr valve. My 6.0 acted like this at times and it was the egr.
skippydoo is offline
