Go Back   Diesel Forum - The Diesel Stop.com > 2008-Up Super Duties > 6.4L Power Stroke Engine and Drivetrain
6.4L Power Stroke Engine and Drivetrain Discussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008 Super-Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Old 05-08-2007, 01:10 AM   #1 (permalink)
Selecting a proper gear ratio for '08 F250
I just ordered a new 2008 F250 Lariat with all the options I wanted. But when asked what gear ratio I wanted I responded with 3:73. After thinking about it I began to wonder what happens to performace if I put a little bigger tire on it, say a 34" diameter tire. Do I significantly change the sweet spot in the torque curve and reduce my economy? Should I change my order to a 4:10 to compensate? I do tow a toy hauler that when loaded is about 10K lbs. That is about 24 times per year or about 25% of the time that I'll be driving this truck will be towing something.
Opinions welcome and encouraged.
Bud
2008 F-250 4 door 4X4 Lariat
Short Bed Black with Dark Stone interior, leveling kit with Nitto 35" Terra Grapplers on 20" KMC stainless Black Spoke wheels. Pioneer AVIC Z2 navigation. Remote Start/security system.
LineX with SnugSL tanneau cover.
2002 Yukon Denali XL
1997 F-150 4X4 three door 4.6L
1989 F-350 4X4 crew cab 460 Gas
1978 F-250 4X4 400 Gas
1970 Bronco Roadster 302 Gas
Connie42 is offline
Old 05-08-2007, 02:50 AM   #2 (permalink)
Re: Selecting a proper gear ratio for '08 F250
Any time you go with a taller tire acceleration and hill climbing power will decrease. You are planning to tow a 10,000 toy box and being in California I suspect you will encounter some pretty steep hills and hot temperatures. I think most people with toyboxes loaded with toys are also performance enthusiasts who enjoy acceleration. Based on these assumptions I'd say go with the 4.10s if they are available. It sounds like this probably is not your daily driver so the slight fuel mileage penalty is not going to be a big issue. I'd strongly encourage you to look at the pin or hitch weights on your toy box and confrim that you will be in the trucks rated capacity. Better to realize a 350 would be a better truck now than later. I'd also spend some time researching the weight capacities of the wheels/tires you plan to add. Most larger tires in the range you are talking about will have a lower weight rating than stock. You may want to post your same questions over on the towing forum. There are some very smart people there who have lots of towing experience.
'94 F350 4x4 PowerStroke, 5-speed, 4.10 gears, crew cab, XLT, Luk Clutch, ZF-47, 294,000 miles
'96 F350 4x4 PowerStroke, auto, 4.10 gears, crew cab, XLT, DRW conversion, 436,000 miles
'95 Lance 11'3" Model 900
Diesel_Aggie is offline
Old 05-08-2007, 09:06 AM   #3 (permalink)
SmokeyWren's Avatar
My Photos: (33)
I just ordered a new 2008 F250 Lariat with all the options I wanted. ... Should I change my order to a 4:10 to compensate?
The only gear ratio available for an F-250 with a diesel engine is 3.73.
Same story with F-350 SRW.
The only way to order a 4.10 rear axle ratio is to move up to an F-350 DRW - as in dual rear wheels or dually or Dooley.
The 3.73 will be about perfect for towing a 10,000-pound trailer with a stock truck. If you later decide to ruin the truck with huge tires, then just plan on the cost of a gear ratio change to be part of the total cost of that mod.
SmokeyWren is online now
Old 05-08-2007, 01:57 PM   #4 (permalink)
Hmm, Smokey...intersting that you think a 34 inch tire would "ruin" a truck. Arent the big stockers at about 32 1/2 to 33?
Sold 7/02/01 2000 F350 XLT CC, 4x4 3.73 LS, Off Road Camper. graphite int, 6 spd. Ox.White, J&J Grill & lighted boards, 10k FEY Drop bumper,(Centurion conversion) 12k Reese receiver. 285's. Duke's Springsteen. (DAC3)
Need me a 7.3 is offline
Old 05-08-2007, 03:07 PM   #5 (permalink)
33.2 to be exact for the stock 18 Conti's and 34.1 for the stocks on 20 inch rims
tzurick is offline
Old 07-08-2007, 05:30 PM   #6 (permalink)
Thanks Guys.
I got my truck and stuck with the 3:73's. Added 35" Nitto's on 20" rims and it looks and rides terrific.
Speedo is a little less than 5% slow. Pulls my boat and tow hauler like they're not there.
Connie42 is offline
Old 07-09-2007, 03:59 AM   #7 (permalink)
im wearing 325/65/18' (~34.5) tow 10k or more regularly and doesnt seem any different then with the stock tires
05 f350 cc sb lariat loaded bullydog powerpup(being replaced with sct) 4" turbo back straight pipe 6" tip outlook monitor two tone blue and silver funtional ram air hood
big tex 10et 18' for my '41 willys americar coupe
now in the garage:
1969 fj40 with 350v8 sm465 np 203/205 doubler sprung over waiting for 4 more inches of lift and some 40 inch boggers
1984 fj60 needs a 6.0 stroke and few other things
2007 Mazdaspeed 6 270hp, turbocharged, 6spd, awd
coming soon:
new f450 darkstone and pueblo gold
jgoff78 is online now
Old 07-09-2007, 08:40 PM   #8 (permalink)
i just put on 35" on 20's on my 350 and i have noticed a small change in accel. For me the tradeoff was worth it for the off-raod (yes i do)and looks. Fit fine with no mods. I would have wanted the 4:10's but as everyone knows ford wont give us what we want...
while i think the acceleration can be helped with a few more HP's the big difference i noticed was BRAKING. My truck definitely does not stop as quickly with the new wheels. a couple of times i almost ran into the back of someone on the freeway cause the truck took it's sweet time slowing down.
borg54 is offline
Old 07-09-2007, 10:06 PM   #9 (permalink)
Gabby's Avatar
My Photos: (11)
Thanks Guys.
Aw man you "ruined" your truck! [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/warmsmile.gif[/img] [img]/ubbthreads/images/graemlins/phoney.gif[/img]
'01 F-350, SD, Reg Cab, 4X4, PSD, 6-Speed, 3.73, Off Road & Snow Plow Packages (X-springs), Rhinoliner, Tuff Country 1 1/2" leveling kit, 3" Donahue hanger kit, 315/70/16 Goodyear Wrangler AT/s on 16x10 Eagle Alloy 058's, Stull 5399-P grille mounted in a full chrome grille, Ford AIS Air box, Westin bull bar, 4" MBRP 409 SS turbo back exhaust. Edge EZ module. Zoodad mod. 20% tinted windows - Born on date 6/18/01. Delivered 6/28/01. Picked up 6/29/01.
78 F150, 4X4, Shortbed, 460, tunnel ram, duel 600 holleys, 4-speed, 10 lift, 44 monster mudders.
72 F-250, 4-speed stock plow truck.
85 Corvette, 4+3, Black. (Sold)
96 Dodge Status ES.
02 Dodge Stratus RT, 5-speed.
93 Suzuki GSXR 750
04 Suzuki 650
06 Ski Doo MxZ X 1000 Renegade
02 Ski Doo MxZ 800 (Sold)
02 Ski Doo MxZ 500 (Sold)
08 Ski Doo Mxz X XP 600 SDI
Truck Pics
Gabby is offline
Old 07-09-2007, 10:08 PM   #10 (permalink)
Gabby's Avatar
My Photos: (11)
Oh no not another one that "ruined" their truck too? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
96 Dodge Status ES.
93 Suzuki GSXR 750
04 Suzuki 650
Truck Pics
Gabby is offline
Old 07-31-2007, 02:43 AM   #11 (permalink)
I know what you mean about breaking. It does take a bit longer to brake but i though it was my imagination since I only had the stock tires on for one day.
All in all very worth the trade.
By the way Gabby those tires on your truck look very close to 35's too!
You're truck doesn't look ruined [img]/ubbthreads/images/graemlins/smile.gif[/img]
http://good-times.webshots.com/album/560091589NMcXfr
Connie42 is offline
