Seriously Pricey DPF...."Stop Safely Now" = new EGT sensor and new DPF - Diesel Forum - TheDieselStop.com
post #1 of 10 (permalink) Old 06-06-2010, 12:24 AM Thread Starter
titaniumfan's Avatar
I have a recent flash, still within the 3yr/36K warranty...got the "STOP SAFELY NOW" going uphill at 40mph. I had probably 15 seconds to coast into a nearby parking lot before it shut down completely at 3mph (courtesy of some TSB that I've forgotten). Glad I wasn't towing or on the freeway as that would have been a big mess. It was definitely NOT doing a regen at the time: regens have been every 125 miles like clockwork doing mostly city driving recently. Dash computer says ~11mpg. The programmer that added this shutdown now "feature" obviously never tested it while towing on the freeway!
The verdict: written up with codes 200E and 242E. EGT sensor was out of range high. The EGT sensor broke while removing it leaving half of it in the DPF so I got a shiny new DPF for free.
Now for the sticker shock:
8C3Z*12B591*D sensor - exhaust gas - tempera list $77.28 net $64.92
9C3Z*5H221*B FIlter ASY - Diesel Particle list $2825.80 net $1780.25
7C3Z*5H247*B Kit - Exhaust System Mountings list $84.99 net $79.72
at least the injectors are ok. Throw in probably 3hrs of labor (don't know book times/rate) and this easily adds up to over $3K. Thankfully I didn't have to pay for anything.
I will say that the DPF delete aftermarket tune and exhaust pipes are looking better and better as soon as the warranty is gone. IIRC the DPF is covered under a federal 10/100K emissions warranty but no matter how you look at it that is one seriously expensive part. Gotta wonder if the 2011's DPF is cheaper...
2008 F-450 Lariat Job 1 w/ 4.88, 98 gal. Transfer Flow tank in bed, Tekonsha P3 brake controller (6 electric over hydraulic disc brakes on toyhauler, not supported with TowCommand), TrailerSaver TS3 air hitch, all for a 2007 Glendale Titanium 36E41MPRV toyhauler
SOLD 2006 Silverado 2500HD LT3 (LBZ Duramax)
titaniumfan is offline
post #2 of 10 (permalink) Old 06-06-2010, 05:19 AM
Like some here have said that the aftermarket part companys might make them cheaper. A tuner/dpf delete does sound attractive if the aftermarket doesn't do anything
2016 F350 Lariat Copperfire Bronze,Black Leather Crew Cab,Short Box SRW. Supplemental Heater,3.55 ELD, Remote Starter. Used for hauling 16ft x 8.5ft. Work Trailer , 8ft. Fisher Plow, Lance 820 truck camper for those days I can get away.
Captcaper is offline
post #3 of 10 (permalink) Old 06-06-2010, 06:17 AM
senix's Avatar
I have not seen any aftermarket DPF's yet. I think the shutdown strategy is in all of them at this point, regardless of what reflash you have.
08F250 CC 6.4 PSD
Banks 6 gun/ram air
40' Stoneridge 5th wheel, coming in at 15.4K.
senix is offline
post #4 of 10 (permalink) Old 06-06-2010, 08:08 AM
the 2011's with the 6.7 the exhaust dpf ect is around 7 grand from what im told.
fomocotech is offline
post #5 of 10 (permalink) Old 06-07-2010, 06:22 AM
But if the EGT were correct it might have saved the engine, in which case the truck would have stopped anyway.
formula racer is offline
post #6 of 10 (permalink) Old 06-13-2010, 06:39 AM
yeah but that's not acceptable. You buy a diesel to be dependable not be plagued things that stop you in your tracks. For the price tag on these trucks it shouldn't have any problems ever!
2008 F350 Lariat 6.4L 100%stock as of yet.
2000 Excursion LTD,7.3L, TS Performance chip,Intake,Exhaust,Guages,8" edge Lift, 38"PJ's,4.30gears...
optiwizard is offline
post #7 of 10 (permalink) Old 06-13-2010, 08:24 AM
TousleyParts's Avatar
Keep in mind its a whole new world for diesel engines (not just in trucks).
In a perfect world, the new ones would be as dependable as the old ones.
However, the emissions have become so strict in the last 10 years, there is much learing that is being done to make these things work right.
The number of parts attatched to a new diesel is absolutely mind blowing. When there are more parts on the engine, obviously there is more to break. It kind of reminds me of an 80s gasser engine; a whole bunch of junk on top of an old technology motor.
On the other hand, for $50+k you think they could make a EGT sensor that wouldn't fail (BTW, these have been updated)
TousleyParts is offline
post #8 of 10 (permalink) Old 06-13-2010, 08:52 AM
The 18 wheeler DPFs have been getting cheaper. I talked to the parts manager at a truck dealer last week and he said some of the prices were as low as $350.
444-4D is offline
post #9 of 10 (permalink) Old 06-13-2010, 03:24 PM
I'm sure someone will start making these aftermaket as well in the next couple of years
post #10 of 10 (permalink) Old 08-17-2013, 11:27 AM
If the only reason the DPF needed replacement was a broken off sensor, there is a much cheaper solution now. New threaded sensor bungs are available on ebay, check this link:
http://www.ebay.com/itm/OE-style-exhaust-gas-temp-EGT-sensor-bung-for-Ford-Powerstroke-Diesel-6-4-6-7L-/141039388416?pt=Motors_Car_Truck_Parts_Accessories &hash=item20d69a4700&vxp=mtr#ht_478wt_1162
That's what I did ^^^ when my my sensor broke off out of warranty. It only cost me $35 to fix this problem. The dealer wanted close to $3000.
Leon_D is offline
  Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 6.4L Power Stroke Engine and Drivetrain
