Go Back   Diesel Forum - The Diesel Stop.com > 2008-Up Super Duties > 6.4L Power Stroke Engine and Drivetrain
6.4L Power Stroke Engine and Drivetrain Discussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008 Super-Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Old 12-10-2006, 08:16 PM   #1 (permalink)
Is there any hope of a 6 speed auto from Ford?
Just curios. The 6SP Ally in GM trucks is pretty nice piece of equipment. Does Ford have any plans for something like this?
SLT223 is offline
Old 12-11-2006, 02:40 PM   #2 (permalink)
Re: Is there any hope of a 6 speed auto from Ford?
If it becomes the industry standard they will have no choice...ever see any new cars with a two speed auto? What about a 3 speed???
I'm no expert, but I would hazard a guess that there are already some prototype 6 speed auto's running around, not sure how much $$ Ford's looking to spend right now on R&D in their current financial shape tho...
Sold 7/02/01 2000 F350 XLT CC, 4x4 3.73 LS, Off Road Camper. graphite int, 6 spd. Ox.White, J&J Grill & lighted boards, 10k FEY Drop bumper,(Centurion conversion) 12k Reese receiver. 285's. Duke's Springsteen. (DAC3)
Need me a 7.3 is offline
Old 12-11-2006, 03:58 PM   #3 (permalink)
mudguppy's Avatar
My Photos: (12)
it may not be too far off and it may not be that big of a change to the current transmission. the reason i say that is the allison got a 6th gear by using an additional valve to add another combo of the existing gears IIRC.
Travis
'03 F350 Dually, 6.0, Supercab, longbed, 4.10 LS, sport pkg, extremely RED, STRAIGHT PIPED, SCT Xcalibrator, full guages
- Job1 programming, Harpooned, Skweeker Mod, Zoodad Mod
- Did that thing that you're not supposed to talk about
'79 Bronco, 468cid Ford 460 marine motor, C6/NP205
Previous -'99 F250, Rg Cab XLT, 7.3/6spd, 3.73
Project truck
- '96 Cummins, 215hp/5spd, Diprocol guages, Plate & AFC full fwd, hi-capacity external lubrication system
To add: 2 1/2T axles, 46" goodyears, etc.
mudguppy is offline
Old 12-11-2006, 09:50 PM   #4 (permalink)
Brian_C's Avatar
IIRC, the torqueshift has 6 gears in it already. I think it has two 2nd gears that are used at different times, depending on temp.
Brian
2004 F250 SC Shortbed 6.0 (03 Engine) Auto 4X2 Lariat, John Wood tuned SCT, AFE Proguard7, STC Performance 4" Turbo back exhaust with cat, Bedrug, Snugtop, Boze Fatal Eight 20x10 Wheels, Toyo Proxes ST 305/50-20 Tires
SOLD - Stroked Lightning - 2004 F250 6.0 Reg Cab Shortbed (longbed frame shortened 16"), Lowered 3"/5", 22" wheels, SCT tuned by John Woods, John Woods built 5R110, straight pipe with exit in bed, custom 4 link rear end, custom injectors by Full Force Diesel, Nitrous, Spearco IC, custom built 76mm turbo by Turbonetics, fuel system, batteries relocated to bed. All work done by Gene (weweld), driven by Gene.
Brian_C is offline
Old 12-11-2006, 10:03 PM   #5 (permalink)
Correct, and from what I have read, the Allison in GM Products is also designed the same way, alternates between two different gear ratios depending on temp, so only 5 are only used typically. I may be incorrect however, since I do not work on too many GM's.
Buddy
Former Ford Diesel Tech
ASE Certified Parts Counterperson, Automotive, Medium, & Heavy Truck Technician
1999 F250 XLT 4x4, Red, 7.3 6spd AWA5, 3.73LS rear, CCV Mod, APC Headlamps, Autometer C2 Gauges, (Boost,Pyro,Trans), 4" Turbo-back exhaust, XM Radio, AIS, ITP Regulated return, fuel feed lines, Airdog, & 4pos. chip.
My Truck
2001 Ford Escort ZX2 - Black- 4cyl 2.0DOHC, 5spd.
1999 F350 4x4 XLT, CC/LB PSD, 6spd, Aluminum service bed, York Compressor Onboard air, CCV, Custom Intake & Exhaust, Strobes and a few other goodies
RIP Steph F. & Trista J., 4/27/07, you will be missed by many.
budman451 is offline
Old 12-11-2006, 10:42 PM   #6 (permalink)
Brian
It's two forth gears it goes like this:
Remember It is just a three speed with an over drive
First Low, this is lower than the 4R100
Second, Is first with over drive this is the added gear if you will in the 5R
Third is same as second in the old 4R100
NOW COMES THE CHOICE GEAR
Fourth is Straight Drive TC and out put are at the same speed
In Very cold weather Fourth is not used but third over instead, I forget the ratio but it very close to straight through but still a bit of reduction.
Then overdrive
As I understand it there is no programed shift from third over to forth they are to close together It could be programed but there is not point.
Now if Ford were to want to revise it to a 6 speed they would have to lower first a bit more and second/third so it could shift as follows
Remember it is a three speed with overdrive. (they are not adding gears they are just rearanging them to use overdrive more.
6 speed
1st gear very low
1st gear over or second added gear
second gear in a three speed or third in a five or six speed
Second over or fourth in a six speed
Third gear/straight drive in a three speed or fourth in a five sp or Fifth in a 6 speed
Then at last over drive in a 4 5 or 6 speed
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available.
Under Construction
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket)
2005 Ex and Specs and Pictures of 2002 X
Bruce1954 is offline
Old 12-12-2006, 09:17 AM   #7 (permalink)
the biggest advantage with a 6 speed is achieving less rpm at highway speeds. gm did this by adding a second overdrive. the torqshift could be used as a 6 speed, but wouldnt really gain anything unless they reduce the overdrive ratio a bit more for highway cruising. every truck should come with a 75+ mph empty highway cruising gear.
Ford Truck Enthusiest!
FOR SALE! 2003 F-350 lariat crew cab long box.
My Vehicles
justinthurn is offline
Old 12-12-2006, 09:37 AM   #8 (permalink)
AllOutFirefighter13's Avatar
<font color="blue"> For those that don't understand how an auto tranny works, or to further explain for those that somewhat do, check out THIS site. Very informative.
The thing that puzzles me is why the engineers that calculated the different ratios could seperate 4th and 5th gears more to utilize all six gears. I feel there has to be a reason, but I can't determine what that is. I believe that if the 6.4L is a success for Ford, they may be willing to beef up the tranny a bit and get the full 6 gears out of it. Many people have said (not necessarily on this site) that higher efficiency can be achieved by keeping the engine in it's powerband over the range of acceleration, which another gear could help in this area. This was one of the major pushes for the CVT trannys (the one's with the suped-up rubberbands).
Later, </font>
Joey
* '04 F250 XCab LWB 4X4 w/ FX4 *
* TorqShift *
* Manual 4WD *
* Carpet Delete *
* No. 2 ONLY *
* High-Idle Mod *
* Fumoto Valve *
AllOutFirefighter13 is offline
Old 12-12-2006, 12:56 PM   #9 (permalink)
The reason that I have been told for the gear spacing has to deal with what the intended primary purpose for the vehicle is. For example, if a vehicle is a delivery truck that makes frequent stop / starts, the gears will be lower and more evenly spaced. If the truck is used primarily at highway speeds (like pickups), then the top two gears are closer in ratio. This is so that there is not as large a difference when one has to downgear for moderate hills, etc.
Just the way that it was explained to me, who knows if the engineer telling me this knew what he was talking about. Anyways, it sounded good.
2008 F250 King Ranch 4x4 SWB
EKUgrad is offline
Old 12-12-2006, 05:35 PM   #10 (permalink)
I don't know the particulars of what these transmissions look like on the inside (ie, how they work), but my experience with Ford transmissions is this:
1. My '03 4R100 4-spd auto has been flawless. The shifting is smooth, it doesn't hunt for the correct gear all the time (like my dad's D-max/Allison), and it holds the torque going up hills while towing very well.
2. Any Torqueshift auto I've driven (in other people's trucks) has impressed me with the performance.
2003 F-350 SRW XLT 7.3L 4R100 PSD 4x4 Supercab SB 3.73
1985 Chevy K20 6.2L Turbo-400 3spd auto 4x4 4.10
2003 Ford Explorer XLT 4.0L V-6 5-spd auto 4wd 3.55
16' American Hauler tandem axle cargo trailer
NRA Life member
Wobblin-Goblin is offline
Old 12-13-2006, 07:59 AM   #11 (permalink)
mudguppy's Avatar
My Photos: (12)
i agree with you, Goblin. i personnally feel the TrqShft is the best auto tranny i've ever driven. the 6spd ally is basically the same 5spd that they added a second OD. so when you're haulin'/towin', it's the exact same transmission, anyway.
i wouldn't mind a second OD for hi-way traveling. [img]/ubbthreads/images/graemlins/cool.gif[/img]
Travis
Project truck
mudguppy is offline
Old 12-20-2006, 12:30 PM   #12 (permalink)
It would be nice to see 4th 1 to 1 and 5th a .90 (somewhere) then 6th a .70 or so. I do not need the tranny to always down shift to 1to1 (4th) when it can not stay in 5th and rev up so much when towing.
EDAZS is offline
Old 12-21-2006, 09:43 PM   #13 (permalink)
The discussion about the cruise speed from justinurn and others. What makes the most efficient drive gear for cruising is running at TQ peak as a cruise gear. I think it is about 1800 RPM on this engine, which is what was stated above I think (the 1800 part). Not sure if the 6.4 peaks there too but it should be close. CVTs do this exactly, stay at TQ peak all the way thru acceleration to maximize efficiency. Now keep in mind, part throtle Tq peak is lower in the efficiency calculation. Tq peak on a V6 gasser might be 2800 for example but the CVT under light load would stay say 2100. Under light throtle that engine is most efficient about there so thats where is stays. Public press releases quote peak HP and Tq. Not 33% throttle ratings and such.
Hide
HideOut is offline
Old 12-21-2006, 11:26 PM   #14 (permalink)
The 6 speed Allisons that have been used for years in medium ,and heavy trucks and buses have two overdrive gears. Usually about .75 for the first over and about .65 for the second over. If the Torque Shift had a double over then just like on these larger vehicles you can run a lower geared rearend for pulling bigger loads and still keep your RPM's down and have a good highway speed. You could also have lower gears in the tranny and one O.D. with the taller rearend gears but that puts more strain on the driveshaft and the transfer case gears in a 4X4 than lower rear gears and double O.D.s.
You do not want to cruise at peak torque for a couple of reasons. First, it is usually not the most efficient part of the RPM range like some seem to think. And secondly if you are cruising at your peak torque then as soon as you hit a hill or head wind you engine will fall on it's face because for every RPM it looses the engine is getting weaker. If you are cruising about half way between your TQ peak and your HP peak you are apt to be in the sweet spot for efficiency and as you hit a hill or other extra load the torque of the engine increases as the RPM fall. This is what allows you to pull a hill with out having to downshift with every tiny hill. If you notice most every "truck" comes out of the factory that way. If you don't believe check CAT's or CUMMIN's web sites or brouchures for their recommended crusing speeds for their big truck engines. They even have a spec called torque rise which is stating how much the torque goes up as the RPM's fall. They usually have TQ peak about 1100 and HP peak about 1850, and the engine RPM is goverened also about 1850 to 1950. They say determine what your cruising speed will be then spec trans, rearend and tire size to cruise between 1400 and 1600 RPM for best fuel economy and pulling ability combo.
fullservice is offline
Old 12-22-2006, 06:48 AM   #15 (permalink)
The 6R140 is on the drawing board as we speak.
lriggnoht is offline
» Site Navigation
» Home
 > FAQ
