Go Back   Diesel Forum - The Diesel Stop.com > 2008-Up Super Duties > 6.4L Power Stroke Engine and Drivetrain
6.4L Power Stroke Engine and Drivetrain Discussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008 Super-Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Old 05-17-2008, 08:06 AM   #16 (permalink)
HamerDown's Avatar
Originally Posted by dit6_4 View Post
I know, that is scary! I have tried that stupid octane boost and it was absolutely useless for this tick. This was before I found out that it was base engine related.
We should all ban together and send a huge email to the Ford executives telling them how pissed off we are because of this darn ticking. Maybe that would put some pressure on International and Ford SD Engineers to get this issue solved. I am sick of hearing that random tick everyday....it is driving me crazy.
Just make sure when you send your letter to Ford you don't come off like a crash test dummy...it's cetane NOT "octane".
Unless you're useing the wrong stuff and also putting gas in your diesel
88 F 250 7.3 Super Cab XLT Lariat4X4...Cream Puff
81 Corvette...Pampered
Harley Shovel 88" Show Stoper...WOW
BBC 468 Jet Boat...Gotta get Wet!
It's the Women that cost me the $$$$
HamerDown is offline
Old 05-18-2008, 08:14 AM   #17 (permalink)
Harley350's Avatar
The fix is in!!!
Drain oil, drive utill engine blows up, fill engine with oil, tow to dealer, get new engine. Simple!
Harley350 is offline
Old 05-18-2008, 07:30 PM   #18 (permalink)
Okay, you are right and I feel like an idiot! This is my first diesel and I am so used to gas engines....but I know that I have been using the CETANE booster and not octane booster! ha ha ha.
Anyways, I have been over 1500 miles since my oil change and I still have the tick. As I reported before, so internet posters reported no tick 1500 miles after an oil change.
dit6_4 is offline
Old 05-18-2008, 07:31 PM   #19 (permalink)
Originally Posted by rlchv70 View Post
Why do you say it's BS? It took GM a long time to fix a similar issue on the Duramax.
What was done to fix the Duramax?
dit6_4 is offline
Old 05-19-2008, 10:02 PM   #20 (permalink)
I fixed all my ford problems by buying a chebby, now I just drive it and knock on wood.
08 LTZ CC D/A 4X4 Dually
rebuilder is offline
Old 05-20-2008, 05:31 AM   #21 (permalink)
Legend or not- some folks have had their "tick" go away using Stanadyne. Maybe their tick wasn't the same tick as yours- I don't know, I have never heard it.
Red 2002 F-350 XLT SRW 4x4 7.3L reg. cab 6-speed rubber floors traded at 50K for:
Red 2005 F-350 XLT SRW 4x4 6.0L reg. cab 6-speed rubber floors BFG 12.5x35 mud-terrains, no lift traded for:
Red 2008 F-350 XLT SRW 4x4 6.4 reg. cab 6-speed. Got carpet this time- audiophile stereo deletes rubber floors. BFG 12.5x35 mud terrains, no lift.
torino73 is offline
Old 05-20-2008, 05:37 AM   #22 (permalink)
That's a good cure until your doors become misaligned, your hood will no longer latch correctly, your instrument cluster fails, your rear end implodes, your a/c quits, and your fuel pump goes out- all common failures on the chebby's my employer has owned. They switched over to Fords. You will need more help than a little wood to knock on.
torino73 is offline
Old 05-20-2008, 09:28 AM   #23 (permalink)
ddduallyfan's Avatar
I've heard the notorius "typewriter" noise on those also, its a different sound than the "tick". Still bites that its not fixed yet. I'll tell ya what, IMHO if it was an issue that the trucks couldn't be sold until it was figured out...it would be figured out. Ford or GM.
ddduallyfan is offline
Old 05-20-2008, 07:32 PM   #24 (permalink)
Originally Posted by ddduallyfan View Post
Thats BS too. I've heard the notorius "typewriter" noise on those also, its a different sound than the "tick". Still sucks that its not fixed yet. I'll tell ya what, IMHO if it was an issue that the trucks couldn't be sold until it was figured out...it would be figured out. Ford or GM.
You got that right! I am sure they are working on it....very very low priority though. I am anxiously awaiting the "fix."
Not to change the subject or start in on the Ford/Chevy thing, but I know people who drive Chevy cars but when it comes to trucks they rely on Ford. IMO, Ford lives up to "Built Ford Tough" everyday.
dit6_4 is offline
Old 05-20-2008, 07:45 PM   #25 (permalink)
Just did my first oil change early with 2000 miles,because going on a trip in a week, no ticking yet knock on wood!!!
2008 F350 FX 6.4PSD 4X4 AUTO SC, TRADED 2000 F350 LARIET LE 4x4 PSD,AUTO,CC,RWD,AIS,4" MAGNAFLOW EXHAUST, PILLAR,PRYO,BOOST,TRANNY GAUGES,6.0 TRANNY COOLER
bowstring is offline
Old 05-21-2008, 10:48 AM   #26 (permalink)
add me to the tick list, started 100 miles after first oil change. been doing it for 100 miles, seems to be getting lower, hopefully it goes away.
bigtruck311 is offline
Old 05-22-2008, 11:01 PM   #27 (permalink)
When does it do it? At idle for above 2,000 rpm's?
Ford Diesel Technician located in Northern California. I'm a mod friendly technician, contact me if you need warranty work in the Sacramento area.
Gofasterdammit is offline
Old 05-23-2008, 07:39 AM   #28 (permalink)
Update on my ticking engine
Okay everyone...I am about 2800 miles after my first oil change (when the ticking started). The tick has disappeared at idle but I still have it on deceleration (when the injectors are taking turns shutting down, I can hear it) and when I bring the engine up to 1500-2000 rpm in neutral.
I ran OASIS again and found the same SSM for the ticking and no new updates. What is taking so long I wonder? The SSM was released at the beginning of April. That is long enough to find a solution and run accelerated durability tests. I personally think the fix will be some type of dampner or an oil additive.
dit6_4 is offline
Old 07-07-2008, 06:23 PM   #29 (permalink)
Another update on ticking
Just changed my oil for the second time (10K miles) and the ticking returned. It seems the last 2K miles the ticking had disappeared. I ran OASIS again and still not updates from Ford on a fix.
dit6_4 is offline
Old 07-07-2008, 09:31 PM   #30 (permalink)
Question for you guys who notice the "tick" after your oil change. Are you changing fuel filters at the same time? The reason I ask is my current brand of truck is known for an annoying tick too, and it has been attributed to the high pressure common rail injection system. Which you guys now have too. My truck has done it to a greater or lesser amount since day one. I can tell you also that not all of them sound the same. My friends '05 sounds completely different from mine. Different fuels will have a different affect on my truck. I believe it is related to fuel lubricity. If I run high concentrations of bio diesel (>B20)it quiets down a bunch. Of coarse anything higher than B5 is not approved by any of the manufacturers, so if you are going to try that be aware before you do.
2006 Dodge CTD 2500 SLT 4X4 Quad Cab Long Bed 6 Speed.
Traded:2004 F250CC FX4 XLT Long Bed Torque Shift, $5.00 AIC.
NickBeek is offline
