TPMS in new truck - Page 2 - Diesel Forum - TheDieselStop.com
Old 03-12-2008, 06:43 PM   #16 (permalink)
Originally Posted by Stroked & Stoked View Post
aren't you transferring the bands over to the new wheels?
The bands are not reuseable, the sensors are however. $50 a peice for the stupid bands from ford, what a joke! I bet it costs them a whole dollar to make them, just another way for them to bend us over! I searched and searched for an alternate method of reattaching them but came up with a couple of ideas that failed. So now i ponied up the extra $200 to put them back on the way they came.
If i only knew which fuse (not listed in owners manual), or what wire i would just cut the damn thing!
EDIT: Just found and ordered these, will save you some cash rather than buying from ford at $50/ea., and these can be reused: eBay Motors: FORD GM DODGE TPMS AIR PRESSURE SENSOR STRAPS TO 26" (item 300206168657 end time Mar-15-08 07:54:21 PDT) I got these overnighted to me, and still saved me $100 over the ford bands! I was about to go into the band making business for $50/pop! $60/all four from here.
2008 Ford F-350 Lariat crew cab dark shadow gray w/all options except camera and nav.
2006 Dodge Ram 3500, CTD, 6speed, quad cab long box, mineral gray, bighorn edition, edge w/attitude, stainless nerf bars, billet grill, 285 BFG a/t's.
2003 F-350 XLT, crew cab, 7.3L, auto, 80k
2005 F-150 Lariat Supercrew, moon roof
2006 F-650 XLT, CTD, allison 5speed auto, 14' landscaper body w/fold down sides
1997 Ford F-250 XLT, extended cab, 7.3L, Auto 140K
1996 Ford F-250 XLT, extended cab, 7.3L, 5 speed man. 125K
honda_guy4 is offline
Old 03-13-2008, 03:48 PM   #17 (permalink)
I have never seen a TPM and don't fully understand how they transmit or what / where the receiver is. That said, is it possible to install TPM's from a F150, which would be lower pressure threshold in the SD wheels? If a F150 TPM is set to "alarm" at say 45psi then a SD owner would have a large margin to adjust pressure as he sees fit.
Just a thought from an idle mind.
'05 F350 CC LB SRW 4X4 auto
dosdedojack is offline
Old 03-13-2008, 08:10 PM   #18 (permalink)
Jcard's Avatar
I read somwhere to stick the sensors in a pvc tube with a valve stem in the end, pressure it up till the puter is happy then hoseclamp it to the frame and buy a pressure guage like in the old days.
08 550 lariat silver crew
Previous Fords
05 350 lariat silver crew (wrecked)
04 250 lariat silver crew
04 250 lariat silver crew (lemon)
2000 350 xlt silver crew
late 99 350 xlt silver crew
Jcard is offline
Old 03-14-2008, 08:41 AM   #19 (permalink)
FULLTILT3's Avatar
I too read about defeating the TPMS with a PVC tube with a valve stem on one end. I read it on here. My truck doesn't have it, but my next one will. I will try it then.
08 F350 DRW FX4 CC 172" Black on Black Leather Job#1 Remote Start Rhino liner Extang Express Tonno cover (14,800)
Traded: 07 GMC POS Sierra 2500HD 4x4 White Clssic Crew SB SLT D/A LBZ (6000 miles)
Traded: 05 Ram3500 4x4 Quad Cab LB Black SLT CTD 5.9L (52,000 miles)
Traded: 03 F350 Lariat CC LB SRW FX4 Gray 6.0L (39,000 miles)
Traded: 02 F350 Lariat CC LB DRW 4x4 Gray 7.3L (52,000 miles)
Traded: 99 F350 Lariat CC LB SRW 4x4 Black 7.3L (51,000 miles)
Traded: 97 2500 Laramie 4x4 V10 8L (36,000 miles)
FULLTILT3 is offline
Old 03-14-2008, 09:20 AM   #20 (permalink)
Unfortunately the PVC tube trick does not work. The sensors need to be rotating/moving at 20 mph or more for them to "wake up" and start sending signal. When the sensors do not sense movement at 20 mph or greater for more than 30 minutes they will go into a sleep mode. Being in a PVC tube they will not sense motion and will not send signal to the SJB which will eventually set off a DTC.
'04 F-250 Harley-Davidson 6.0L CC SB
PowerStrokeHD is offline
Old 03-14-2008, 01:22 PM   #21 (permalink)
I too read about someone doing the pvc tube trick with a gm vehicle, but as stated i don't beleive it works on the fords. If you can replace the bands for $55 plus shipping like i did, why wouldn't you?? Better than screwing around with a unproven tactic that may or may not work. Hopefully will have my bands later today (had them overnighted) so i can finally get my wheels/tires put one!
Old 03-14-2008, 05:24 PM   #22 (permalink)
let us know how it goes!!
stunya is offline
Old 03-15-2008, 04:44 AM   #23 (permalink)
Here is some information that Ford released to service personnel on the TPMS subject...
2006-2008 VEHICLES - TPMS CANNOT BE TURNED OFF OR REPROGRAMMED
2006-2008 VEHICLES WITH TIRE PRESSURE MONITORING SYSTEM (TPMS) CANNOT BE DISABLED OR REPROGRAMMED TO A LOWER OR HIGHER TIRE PRESSURE. THIS SYSTEM IS REQUIRED BY FEDERAL REGULATION. FEDERAL LAW PROHIBITS DEALERS FROM DISABLING TPMS. IF A DEALER DISABLES TPMS, THE DEALER CAN BE SUBJECT TO FINES OF $6,000 PER VEHICLE. AFTERMARKET WHEELS AND TIRES ARE NOT RECOMMENDED. REFER CUSTOMERS TO THEIR OWNERS GUIDE FOR COMPLETE DETAILS.
Old 03-16-2008, 12:39 AM   #24 (permalink)
Smokewagun's Avatar
My Photos: (9)
Well, I'm sure I don't have TPMS on my 2007. I have thought of avoiding the expense of the new 20's when I order a 2008 and just switching the wheels/tires (20's) from my 2007 to the new 2008 upon delivery at the dealer. I would then expect the TPMS warning light to be on all the time. I sure hope there is a bulb in the back of the cluster to pull out. If not, I assume it will burn out after a few thousand miles.
2010 Ford F-250 Superduty Harley Davidson. Navigation. Moon.
Smokewagun is offline
Old 03-16-2008, 08:47 AM   #25 (permalink)
Harley350's Avatar
The bulb is not whats a pain for me I can live with it. It's the stupid low tire pressure warning message staring me in the face and I have to reset it eveytime.
Harley350 is offline
Old 03-16-2009, 08:59 AM   #26 (permalink)
I did this on an a 07 mustang and it does work. Tires do not need to be turning for sensors to work. The SJB will wake them up when you reach around 20 mph. If sensors go to sleep let the air out and refill. I did this over 2 years ago and is still working fine. The car sits all winter and the sensors have not went to sleep yet. I keep them in a tube under my drivers seat at 30 psi. PVC will take 250 psi plus. My car has blue sensors I think the truck have green ones with higher pressure rating. My light will come on if the tube leaks below 26 psi. Again this is not hear say i am doing it. Sometimes power sub stations set off a light so i hit the reset and good to go. I did not check on how the truck system works but i bet its close to the same. Good luck
gtstang is offline
Old 03-16-2009, 01:24 PM   #27 (permalink)
rock_doctor's Avatar
Just for my information, why is this required by the government?
2005 Excursion w/ 6.0L PSD
2008 FX4 F250 CCSB w/ 6.4L PSD
rock_doctor is offline
Old 03-16-2009, 02:38 PM   #28 (permalink)
compman72's Avatar
My Photos: (9)
The Firestone recall in the United States in the late 1990s which was attributed to more than 100 deaths from rollovers following a tire tread-separation, pushed the Clinton administration to publish the TREAD Act. This act mandates the use of a suitable TPM technology in order to alert drivers of a severe under-inflation condition of their tires. This act affects all light motor vehicles (<10,000 lb) sold after 1 September 2007.
2008 F250 XL Crew cab, manual 4x4, 6.4L, Job 3, TorqueShift, w/ Decor group, Camper Pkg, Off Road Pkg, LWB, Power Equipment Group, Tow Command, Knapheide Utility Bed with sliding top. Built 2/5/2008 & Purchased 9-1-08
08B07 Flash 1-16-09
Firestone Ride Rite Air Springs 3-20-09
Radiator (end cap leak) @ 34,100 miles 11-19-09
11B23 PCM Recalibration 4-11-11
Hydroboost Replacement (leaking Power Steering Fluid) @ 82,866 miles 7/25/11
Upper & Lower Hoses (new design) @ 90,000 miles 11/10/11
compman72 is offline
Old 03-16-2009, 03:35 PM   #29 (permalink)
While on my first camping trip at a State Park with my new truck last year, I noticed a guy with cool 2008 F250 with so many after market parts on it that you could hardly tell it was a Superduty. The next day I made a plan and ambushed him because I was new to a diesel truck and had lots of questions. He was a great guy, he removed his DPF, added a programmer, lift kit, tires, rims….etc. Anyway, being a diesel newbie, when I brought up that the tires that came with my truck are crap and on all my other vehicles I’ve bought an extra set of snow tires on plain rims for the winter season, this is when he pulled out from behind his rear seat a 10” length of yellow plastic high pressure natural gas pipe and briefly told me about the TPMS sensors, At that time I knew I wasn’t going to put on 37” tires so I didn’t think that I was going to have a problem with snow tires, so through my ignorance I had to drive in winter weather with summer tires because of a government safety regulation!! I don’t know his forum name, but I know he is a member of this forum and hopefully he will read this post and respond. My truck has 65psi in the front and 80psi in the rear and it came with a TPMS Fob in the glove box, I’m going to have to find out if I can lower the rear tire pressure to 65psi during pot hole season also, without ending up in TPMS prison.
-2008 F-350 CC 4X4 Lariat, SRW, 3.73.
Any color, as long as it's "Black".
Ordered 12/31 - Born 02/11 - Picked up 03/29.
-1972 First Ford - 1956 Fairlane - Mint
Rolled it at 100+mph (Teenager, Duh, no one hurt)
Totaled Oct/73 (Over 35 Years ago and still remember that lesson).
-First New Ford - 79 Bronco - Ordered Mar/79
150K Miles - I disassembled 2000 and I sent it to three different scrap yards.
-1982 - My Sister married a GM Sales Manager (He Retired 2007, "Hello" Ford Super Duty, enough said, LOL).
-2003 - ZRX1200 (Some say "Mid Life", LOL).
-2008 - Jayco 313RKS 5th (The kids won't move out of the house).
MPD56 is offline
Old 03-16-2009, 03:58 PM   #30 (permalink)
dieselwhisperer's Avatar
Smile
I didn't know that. I always thought the TPM was to save fuel! Remember a few months back when Obama said if everyone would inflate their tires to the recommended pressure we would save gazillions of gallons of gas.
2008 F250 Crew long bed XLT 6.4 diesel, automatic, White.
dieselwhisperer is offline
