Go Back   Diesel Forum - The Diesel Stop.com > 2008-Up Super Duties > 6.4L Power Stroke Engine and Drivetrain
6.4L Power Stroke Engine and Drivetrain Discussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008 Super-Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Old 11-13-2007, 04:53 PM   #1 (permalink)
Tranny Issue - - - Please read
I found this by accident. I went to pull my truck in to the garage for the night and inadvertantly put it in 3rd, not drive. Pressed on the pedal...w t f ...did I have the parking brake on...NO. The RPMs came up about 800 before it moved. Put it in 1,2 or drive and no lag. It's like it is slipping or something when positioned in 3rd. Cold or hot, doesn't make any difference.
Before going to the dealer to have them tell me it's common***, I'd like to hear what the rest of you find.
Note: ***common - a term that ford and my dealship like to use. I told them "common" doesn't mean that it's right and not a problem
2008 F350...Lariet Super Cab , 6.4, 3:73 with all the goodies, 29,000 miles, 35 foot 11K Fiver
New Radiator
12-13 MPG HWY if I drive like a p-ssy
"Passes everything except the fuel pumps"
TIM K is offline
Old 11-13-2007, 04:57 PM   #2 (permalink)
Send a message via ICQ to agdodge4x4
Re: Tranny Issue - - - Please read
uhm...i think if you put it in third...its in third...as in, third gear. Like starting a manual transmission off in third from a dead stop. I wouldnt expect anything less than what you described.
Jason
Texas A&M University
Class of 2002
2005 F-250 4x4 (FX4), Lariat Arizona Beige/Black two-tone, 5 spd Auto, 6.0L.
agdodge4x4 is offline
Old 11-13-2007, 04:59 PM   #3 (permalink)
3rd is intended for starting out on glare ice etc.....I would think frequent use of it would fry the torque converter!
2008 F350 Crew Cab 6.4 PSD 4X4
Excel 33RSO 5th Wheel M/C Lift on the back
jayhirsch is offline
Old 11-13-2007, 05:04 PM   #4 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: AggieFord4x4</div><div class="ubbcode-body">uhm...i think if you put it in third...its in third...as in, third gear. Like starting a manual transmission off in third from a dead stop. I wouldnt expect anything less than what you described. </div></div>
Putting it in 3 should not let it progress past 3. It should still start from the beginning...
Any tranny techs out there???
New Radiator
TIM K is offline
Old 11-13-2007, 05:07 PM   #5 (permalink)
Most auto's have the 2nd or 3rd gear start now..gas and diesel.poor man's traction control!
Old 11-13-2007, 05:09 PM   #6 (permalink)
Nope, putting it in 2 or 3 holds it in that gear.
2008 Tundra Crew Max Limited 5.7
2004 F-250 CC Lariat FX4 6.0 PSD with 132K miles (traded)
boatingncst8fan is offline
Old 11-13-2007, 05:09 PM   #7 (permalink)
Stymie's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: TIM K</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: AggieFord4x4</div><div class="ubbcode-body">uhm...i think if you put it in third...its in third...as in, third gear. Like starting a manual transmission off in third from a dead stop. I wouldnt expect anything less than what you described. </div></div>
Any tranny techs out there??? </div></div>
third should start in third. my lightning starts in 2nd when my retarded wife leaves it in second at the race track alos.
2008 Ford F-250 CC SB
6" Stage II Pro Comp Lift
17x9 Pro Comp 7189
37x12.5 BFG M/T KM2's
Try the SEARCH Button
Stymie is offline
Old 11-13-2007, 05:42 PM   #8 (permalink)
I think it's a Ford thing My f 150 was like that but all my Chevies just won't pass the intended gear they do start out in 1st no experience with an Allison however
ZMANN is offline
Old 11-13-2007, 08:32 PM   #9 (permalink)
Mark Kovalsky's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: TIM K</div><div class="ubbcode-body">Any tranny techs out there??? </div></div>
I'm not a tranny tech, but I was an automatic transmission engineer at Ford, and I calibrated the TorqShift for three years.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: TIM K</div><div class="ubbcode-body">Putting it in 3 should not let it progress past 3. It should still start from the beginning...</div></div>
That's how GM does it, not Ford. All Fords will ONLY use the gear you select. If you put it in 3, it will start in 3 and stay in 3. No shifts. If you put it in 2, it will only use 2.
Read your owner's manual. It should be in there.
Mark
Mark Kovalsky is offline
Old 11-13-2007, 09:13 PM   #10 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Mark Kovalsky</div><div class="ubbcode-body"> I'm not a tranny tech, but I was an automatic transmission engineer at Ford, and I calibrated the TorqShift for three years.</div></div>
So it's all your fault? lol
ZMANN is offline
Old 11-13-2007, 09:15 PM   #11 (permalink)
Now that's funny.
2008 F450 4wd crew, forest green over pueblo gold, 4.30 rear, several options, Lord help me keep my truck stock.
Deeregreen is offline
Old 11-13-2007, 09:57 PM   #12 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: ZMANN</div><div class="ubbcode-body">So it's all your fault? lol </div></div>
I may have been the one that programmed it that way (at least the '05 model year) but I didn't make the decision to do it that way. It's company policy, I just implemented it.
For the record, I like it better this way than the way GM does it. I feel that it gives the driver more control in selecting what gear to use. GM only allows you to limit how high you can shift. I find a lot of times living in a cold area that I don't want to start in 1st gear.
Mark
Old 11-13-2007, 10:16 PM   #13 (permalink)
I wasn't trying to be smart either. Agree I like this way better, makes more sense to me.
Old 11-13-2007, 10:22 PM   #14 (permalink)
i was just kidding! I'm on the fence about how I like it the first time I did it I accidentally put it in 2nd and almost killed myself pulling out into traffic ( I jumped out of the truck to secure something and when I jumped back in I just dropped it into gear to get going ) like I had done in GM's it took me a minute to figure out what I did
ZMANN is offline
Old 11-13-2007, 10:25 PM   #15 (permalink)
Putting the selector into 3rd. gear should not mean that the truck starts out in third gear. It should mean that the tranny will start in first gear and wont shift past third gear.
(Arrived 10/27/07)08' F350 Lariat CC LB SRW 6.4L auto Dark Shadow Grey - Everything except sunroof and nav.
SOLD- A go Fast Bombed '01' Dodge 2500 Quadcab
08guy is offline
