Tsb 08-2-3 - Diesel Forum - TheDieselStop.com
Old 11-07-2009, 05:17 PM   #1 (permalink)
Fanuc's Avatar
Tsb 08-2-3
TSB 08-2-3 Has to do with the intercooler, and the paint pealing ... can anybody tell me what else is in this TSB
the dealer just cleaned it and painted half of the intercooler and it look like s**t
Fanuc is offline
Old 11-07-2009, 10:16 PM   #2 (permalink)
Greyman's Avatar
My Photos: (6)
That sucks, mine is peeling and I'm going to take it in soon.
2008 F350 CC SRW LONGBED Larait, moonrf, pwr slider, tow comm., backup cam.& sensors, camper pack., chrome pack.,audiophile, 60/40, 3.73 LS,stock 6.4, Torreador Red/Silver accent, Ride-rite air bags 2071 and 2219 controller,torklift stable load bumpers, dieselsite external tranny filter kit, duraflaps front and rear, Line-X, A.R.E. Z-series canopy, keyless entry, fold-down front slider, 2 lights. Tork lift camper tie-downs, Fast-Guns
10'2" Citation Supreme w/slide & all opt.s
1978 F250 Supercab 4wd Camper Special , 400, Edelbrock Performer 600 carb & intake, 4.10 LS, C-6, custom autosound radio, new interior, 68,000 orig.
1978 F150 reg cab xlt lariat trailer special 400 stock
1970 Torino Cobra 429 CJ C-6 13.02@ 103 1/4 mile, 3.50 Trac. Lok
1970 Torino GT Conv. 4 speed 351C 2bbl
Greyman is offline
Old 11-08-2009, 06:17 AM   #3 (permalink)
senix's Avatar
mine is peeled at the bottom, since it is not steel I don't worry about it. My intercooler works perfect so I would not want to mess with a replacement either.
08F250 CC 6.4 PSD
Banks 6 gun/ram air
40' Stoneridge 5th wheel, coming in at 14K.
senix is online now
Old 11-08-2009, 07:46 AM   #4 (permalink)
Fanuc's Avatar
Senix,
That was my feeling too but, I started thinking because of where it was pealing from (the lower right hand side) where the inlet is I might have a heating problem.
The flaking felt a plastic coating that has bubbled do to heat, so I had the Dealer check it, I just don’t want to get stuck on the road with a intercooler problem.
Fanuc is offline
Old 11-08-2009, 09:53 AM   #5 (permalink)
My intercooler was also peeling at the bottom and there is a wire loom that runs under the intercooler that was not tied down properly, it was touching the bottom of the cooler, it was starting to melt which may be your plastic feel. Check all along the bottom of the cooler to make sure the wire loom is securly tied down and not touching the cooler.
08F450Superduty is offline
Old 11-08-2009, 06:28 PM   #6 (permalink)
ZeroOne's Avatar
Mine peeled a long time ago.... just peeled everything I could, then taped everything off, and hit it with some rustoleum. It sounds ghetto, but it came out looking great and never peeled again.
Unofficially for sale / entertaining offers.
PM me if interested or for more details on it.
'08 6.4 CC/SWB F350 Black FX4, 8" Rize/OUO on 38x15.50s, 4.56 gears,
photo2, photo3
ZeroOne is offline
Old 11-09-2009, 08:44 AM   #7 (permalink)
Does this TSB address the peeling? What does it address?
I noticed mine peeled too. It annoys the heck out of me, but I don't want a new intercooler just because of it. It's my first one and I haven't had any problems with it!! :-)
2008 F250 PSD XLT Super Cab Long Bed (4x2)
2006 Nissan Titan, 6 inch Procomp lift (4x2)
2000 Nissan Frontier, Custom Motorsports 8 inch lift (4x2)
timid1 is offline
Old 11-14-2009, 04:36 PM   #8 (permalink)
Fanuc's Avatar
Thats what I was wondering also ... what does this TSB cover?
Fanuc is offline
Old 01-07-2010, 05:47 AM   #9 (permalink)
fredwilliamson's Avatar
TSB
08-2-3
  • 6.4L - CHARGE AIR COOLER (CAC) PAINT PROCEDURE - BUILT BEFORE 8/1/2007
Publication Date: January 11, 2008
FORD:
2008 F-Super Duty
ISSUE:
Some 2008 F-Super Duty vehicles built prior to 8/1/2007 and equipped with a 6.4L diesel engine may exhibit a charge air cooler (CAC) paint concern.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
NOTE:DO NOT REPLACE THE CAC FOR PAINT RELATED CONCERNS.
  1. Inspect the CAC for paint defects.
  2. If the left hand (driver side) of the CAC has paint defects, remove the fuel cooler radiator retaining bolt, then disengage the radiator from the CAC. Do not disconnect the two (2) hoses at the bottom of the fuel cooler radiator. Carefully tie it out of the way for preparation/painting operations. It does not need to be removed if there are no defects on the CAC in this area.
  3. Use compressed air with a blow gun to remove loose paint from the CAC lower tank and side rails.
  4. Clean repair area surfaces with a suitable wax and grease remover or brake cleaner spray.
  5. Use 180 grit sandpaper to remove and featheredge remaining paint from tank and side rails. Be careful of cooling fin and tank joint areas.
  6. Clean the sanded areas again with wax and grease remover, and allow to dry.
  7. Mask surrounding areas to prevent overspray.
  8. Apply 2 light coats of Dupli-Color® Engine Enamel Gray Engine Primer. Allow to dry between coats per can directions.
  9. Apply 2-3 coats of Dupli-Color® Engine Enamel Ford Semi-Gloss Black. Allow to dry between coats per can directions.
  10. Install fuel cooler radiator, if removed.
PART NUMBERPART NAMEDE-1612Dupli-Color® Engine Enamel - Gray Engine PrimerDE-1635Dupli-Color® Engine Enamel - Ford Semi-Gloss Black
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATIONDESCRIPTIONTIME080203A2008 F-Super Duty 6.4L: Paint Charge Air Cooler, Includes Time To Inspect, Clean, Mask and, Position Fuel Cooler Aside If Necessary (Do Not Use With 6775A)0.6 Hr.
DEALER CODING
BASIC PART NO.CONDITION CODE6K775d4
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford, Lincoln, or Mercury dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources.
Copyright © 2008 Ford Motor Company
"Faster than a speeding ticket!"
2002 Ford SuperDuty CrewCab ShortBed 4X4.Dark Green. 6.5" ProComp Explorer All Spring Lift. Chrome 18" KMC Revolvers with 37x13.50x18 Nitto MudGrapplers. DP TUNED! 4 inch turbo back with 5" bullhauler stacks. Non ebpv turbo pedistal and outlet.ATS ported housing.John Woods Valve body. Home made boost anhialator.HUGE glow plug relay.Adrenaline Pump. Regulated Return with Fuel Bowl Delete.Harpoon Mod.2008 King Ranch seats front and rear.{2} 10" Pioneer Thin Mount Subs 2ohm Bridged in Bassworks Channeled Boxes, Planet Audio 1350w 2ohm Amp, Infinity Refrence Front And Rear 6x8's.Cobra Black Chrome CB peaked and tuned w/300 watt linear.
2004 Ford Superduty Crewcab Longbed Dually 4x4
all stock except body damage. Gotta love "hit and run" semi's!
fredwilliamson is offline
Old 01-07-2010, 05:35 PM   #10 (permalink)
Originally Posted by fredwilliamson View Post
TSB
08-2-3
FORD:
2008 F-Super Duty
ISSUE:
ACTION:
SERVICE PROCEDURE
WARRANTY STATUS:
DEALER CODING
Oh wow - the last thing I want is anyone with a can of spray paint near my truck. Jeez, they don't even remove the CAC to paint it?
2008 F250 - CCSB - 6.4L PSD - Auto - 4x4 - Black - Job #1
On my 2nd radiator and 2nd PCM program - other than that it's been nothing but oil changes.
thw420 is offline
Old 01-07-2010, 08:25 PM   #11 (permalink)
Fanuc's Avatar
Fanuc is offline
Old 01-08-2010, 02:15 AM   #12 (permalink)
it is pretty scary. Not to mention that if the cooler isnt steamed out to remove lodged dirt from the cooling fins and you just paint over it......... dunno if thats such a great idea! But you cant expect much from blue diamond anyways.
any tsb help in the future lemme know.
