Turbo 101 Question - Diesel Forum - TheDieselStop.com
Old 03-15-2008, 03:38 PM   #1 (permalink)
Turbo 101 Question
Why, when in neutral, if I step on the throttle, does the boost not build. The machine is "smart" enough to only build boost when actually in gear and/or moving.
My question: what manages this component of the turbo process?
D.
dwilliamsceg is offline
Old 03-15-2008, 04:37 PM   #2 (permalink)
Banned
Boost is an effect of exhaust pressure.... Without a load on the engine, it is highly unlikely that any significant amount of boost is going to be built.
Unlike a belt driven supercharger, the turbocharger wont build boost until engine conditions demand it.... At idle, the pressure drop across the turbine stage will only be about 17ish PSI.... and the compressor stage is basically "freewheeling". Adding a load to the engine will increase exhaust pressure and this higher pressure drop will cause the turbocharger to spin faster, creating boost (FWIW, this is a little oversimplified).
GrampyJim is offline
Old 03-15-2008, 08:26 PM   #3 (permalink)
The turbo is equipped with variable turbine vanes. This allows the ECU to control the backpressure, and, therefore, boost.
rlchv70 is offline
Old 03-16-2008, 08:43 PM   #4 (permalink)
Are you sure? I thought I read that the 6.4 twins were fixed...???
Old 03-16-2008, 08:48 PM   #5 (permalink)
Here is another one:
Where does the exhaust gas that spins the turbo go once it has spun up the turbo both under load and under no load? And how is this regulated?
I believe this component is called the waste gate....?? If this is correct, is the waste gate controlled at all by a throttle plate (or similar) that opens and closes as necessary?
D,
Old 03-17-2008, 01:01 AM   #6 (permalink)
Stymie's Avatar
D,
a wastegate is a vacuum operatred mechanism that opens and closes based boost. when the boost reaches a certain PSI it opens to bleed of any excess. the exhaust gas passes through the turbo on the same path no matter what the truck is doing.
Boost a load dependant. Supercharged rigs do not build boost either at idle.
2008 Ford F-250 CC SB
6" Stage II Pro Comp Lift
17x9 Pro Comp 7189
37x12.5 BFG M/T KM2's
Spartan/4" duals/AFE
Try the SEARCH Button
Stymie is offline
Old 03-17-2008, 12:03 PM   #7 (permalink)
Yes, I'm sure.
rlchv70 is offline
Old 03-17-2008, 12:08 PM   #8 (permalink)
D,
6.4L has not wastegate.
The exhaust gases go to the same place. The vanes just vary how much spin is put into the HP turbo.
The exhaust gases go from the HP turbo to the LP turbo. Then they go to the downpipe and the DOC/DPF.
Check this out for more info: http://www.backglass.org/duncan/ps64...ent_system.pdf
rlchv70 is offline
