Re: Water separator won't drain after new filter
The simple side of me says that the hole in the housing that exists to support the yellow plastic valve is clogged. Though it may cost you $71 from Ford for a new set, open the lower filter and remove it. Perhaps the oil changer at the dealer that did the work had greasy hands or something. I will be changing mine out in Dec, and hope I don't have the same issue. If you can not see inside, try one of those 'one man bleeders' from Napa. Open the valve and see if you can suck fluid out. If that fails, back to the que at Ford.
Michael B.
2008 F350 XLT, SC, LWB, SRW. 6.4 L. 4x4. 6 spd. Job 1. 31,000 miles. ***For Sale***
2009 VW Jetta Sedan, 2.0L TDI, 6spd, Silver, Protection Pkg. Bought 23OCT08
