Go Back   Diesel Forum - The Diesel Stop.com > 2008-Up Super Duties > 6.4L Power Stroke Engine and Drivetrain
6.4L Power Stroke Engine and Drivetrain Discussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008 Super-Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Old 12-08-2006, 03:55 AM   #1 (permalink)
Weight of new F450?
Hello folks,
I am considering buying a new truck, which will be my first diesel. Crunching the numbers, the new F450 has a weight of over 14k, has anyone else noticed, or am I looking at the right weights.
refering to the fact that new truck will be for *work* *cough* [img]/ubbthreads/images/graemlins/eek.gif[/img]
defuzer is offline
Old 12-08-2006, 04:50 AM   #2 (permalink)
Re: Weight of new F450?
welcome to the diesel stop. it will have a gross vehicle weight of 14k i think its going to be around 1.5k more than the current 350 dually empty, acording to its weight and gvwr you are better off buying a commercial f450 or 550 and sending it to the upfitter as you will have more payload in the end because of the ratings
05 f350 cc sb lariat loaded bullydog powerpup(being replaced with sct) 4" turbo back straight pipe 6" tip outlook monitor two tone blue and silver funtional ram air hood
big tex 10et 18' for my '41 willys americar coupe
now in the garage:
1969 fj40 with 350v8 sm465 np 203/205 doubler sprung over waiting for 4 more inches of lift and some 40 inch boggers
1984 fj60 needs a 6.0 stroke and few other things
2007 Mazdaspeed 6 270hp, turbocharged, 6spd, awd
coming soon:
new f450 darkstone and pueblo gold
jgoff78 is offline
Old 12-08-2006, 05:22 AM   #3 (permalink)
Not to concerned with the higher payload. As a f350 would do fine for what I need. (tow 5th wheel to job sites).
More concerned with tax implications. The Ford truks, f150-f350 are over the 6000lb mark. The new f450 is over 14k? just want to make sure I am looking at the right number there. Over 14k weight puts this vehicle into another category for people who use the trucks for work, but don't necessarily need a (work truck) as they drive them home and do other (work) related tasks where you wouldn't need a truck without a special set up.
defuzer is offline
Old 12-08-2006, 08:43 AM   #4 (permalink)
I think you may be confusing the curb weight of the truck with the GWR or the weight fully loaded with payload. The 14K refers to the masximum possible loaded weight. The payload I think is around 6000 lbs. so that would put the truck weight at around 8000 lbs. Is this right folks?
7.3 99.5 550 Lariat Fontaine conversion, auto leveling airbags, auxillary transferflow midship tank, fiberglass bed,liner, 25K pullrite hitch, Diesel Innovations six way chip,pillar gauges, 4 inch exhaust. SOLD
08 f-450 4X4 LARIAT 4.88 Dark Shadow Gray to match my Mobile Suites fiver. Line-x, 0503 Pullrite 25.5k superfifth hitch, Retrax rollcover, 50 gal transferflow under cover aux tank, aftermarket pioneer avicz2 nav to come,
larryhutto is offline
Old 12-08-2006, 09:54 AM   #5 (permalink)
I believe that the new F450 crew cab dually will weigh in at about 8500-8600lbs. with fuel. My truck is over 8000lbs empty. I believe the GVWR on the F450 is 14,500lbs... which is what you get taxed on. $200 a year to reg my 13,000lb. GVWR truck in MA. [img]/ubbthreads/images/graemlins/eek.gif[/img]
2006 F350 CC LB DRW 6.0PSD
F350OilBurner is offline
Old 12-08-2006, 10:00 AM   #6 (permalink)
Thanks for the responses,
Doesn't being over 14k GVWR allow a 100% deduction now, as opposed to 50% with depreciation on the F350 and below?
defuzer is offline
Old 12-08-2006, 10:12 AM   #7 (permalink)
This is from some information sheets I was able to find. These were intitial release figures.
2008 F450 Pickup 4x4
Curb Weight - 8687
Max Payload - 5720
GVWR - 14500
2008 F450 Pickup 4x2
Curb Weight - 8290
Max Payload - 6120
GVWR - 14500
'04 F-250 Harley-Davidson 6.0L CC SB
PowerStrokeHD is offline
Old 12-08-2006, 11:11 AM   #8 (permalink)
My F-450 weights 9150+ or - a little with half tank of fuel.. See my sig for specs.
Pics here:
http://www.texasoffroad.net/galleries/ohv/album320
Mike Strickland
Web Master
www.BigCountryOff-Road.com
2003 F-450 4x4, 6.0 PSD, 4.30 Gears, Western Hauler, 19.5 Wheels/Tires
1970 Ford Bronco, 302 EFI-T19-D20, PTO winch, 35" boggers.
93' F350 Dually, Ext Cab, 4.10's 7.3 IDI non-Turbo
RajinCajun is offline
Old 12-08-2006, 03:03 PM   #9 (permalink)
Cab chassis F450's, and pickup F450's while similar, are going to weigh different weights. I take it the original post here is relating to the F450 pickup, but these posts never seem to specify which version is in question. LS
2005 F450 XLT Super cab tow truck 6.0, 87K mile, POS Soon to be traded for 09 F550 Lariat Super cab V10
2003 F450 rollback, with V10 power, 141K and still running great.
LSchicago2 is offline
Old 12-08-2006, 03:19 PM   #10 (permalink)
Good point.. Mine was a chassis cab outfited with the Western Hauler bed... Honestly I thought all 450/550's were chassis cab and had to be sent to an upfitter for a bed etc.. because the 450/550 frame being longer, a standard dually bed won't fit??
Mike Strickland
Web Master
Old 12-08-2006, 04:05 PM   #11 (permalink)
RVrs R US's Avatar
Send a message via AIM to RVrs R US
Until this year, you were correct. Ford will be introducing the new 2008 F-450 Pickup shortly which is 4" shorter to accomodate the F-350 bed. Here is the Media Ford News Release about the new truck.
And here are the 2008 Super Duty Order Guides courtesy of Bobby from Sunrise Ford
Dave
RVrs R US is offline
Old 12-08-2006, 09:57 PM   #12 (permalink)
Refering to truck model of the F450.
Also, is the 14500, the number for GVWR that is what you would use when writing off for tax purposes? Not to conncerned at the moment of the actual weight, just whether its 50% or 100% hehe.
Thanks for all the input.
defuzer is offline
Old 12-08-2006, 11:56 PM   #13 (permalink)
You mean pick up? They are both trucks. Not trying to be rude, but unless you specify pick up, or cab/chassis, most people will assume the one they are familiar with. My c/c F450 has the 16,000 GVW. The Pick up F450 has the 14,500 GVW. LS
Old 12-09-2006, 01:17 AM   #14 (permalink)
yeah, pickup sorry. question on the gvw was pretty much answered.
thanks again for all the responses.
defuzer is offline
Old 12-14-2006, 01:42 PM   #15 (permalink)
GVWR is what matters for tax and registration.
2007 F350 Lariat CC, Power Stroke, A/T, SRW 172", <font color="red">Scarlet</font> & <font color="#666666">Gray </font>, Captain's Chairs, Power Moonroof and Sliding Rear Window, Tow Command, Upfitters, Roof Clearance Lights, Sirius Satellite Radio, Line-X Spray Liner, B&W Turnover Ball Gooseneck
MX727 is offline
