Well.... here I go again... check engine light! - Diesel Forum - TheDieselStop.com
Old 08-11-2008, 11:02 AM   #1 (permalink)
Well.... I'm just about to roll 15K on my truck and it has thrown its first check engine light. The truck is running fine, can't tell any difference at all (except maybe the fuel economy is getting worse). I can reset the light..... and it will go off..... you can drive it for twenty miles..... but when you turn the truck off..... start it up again.... it will run a mile or two and throw the light again. The weird thing is.... I have a scan tool.... and it reads "NO DTCs".... no codes? weird.
Any ideas?
I'm gonna take it on wednesday for this... and the fuel tank bracket recall.
2008, F-250, FX4, Crew Cab, Short Bed, Oxford White w/ black interior, Dual Alternators, Sat. Navigation & Radio, Overhead DVD System, ESOF, Solid Rear Window, 3.73 Limited Slip, Upfitter Switches, Tow Command System w/ Power Scope Mirrors, Power Seats, and the Reverse Aid Sensor - Edge Insight Monitor, 2.5" Donahoe Racing Lift Kit, Fox 2.0" Piggy-Back Shocks, KMC Beadlocks w/ 35" Toyo M/T's, MBRP DPF back exhaust, Recon mirror lights, Fitch Fuel Catalyst, Randy Ellis Design Light Bar, Line-X, MotoBar, Gentex Temp/Direction Mirror
RRose is offline
Old 08-11-2008, 12:01 PM   #2 (permalink)
RVrs R US's Avatar
Send a message via AIM to RVrs R US
Lightbulb Ours did the same thing at 2500 miles.....
...and come to find out, I didn't have the fuel tank cap on tight. Took care of that and it hasn't happened again.
Dave
2008 F-450 6.4L LARIAT 4X2 DRW CREWCAB, JOB 2 BUILD (10/22/07), X-Plan, White/Silver w/Chrome Package, Gray Leather Interior, Torqshift Tranny, 4.88, 33K Tow Package, Sirius Sat Radio w/Audiophile, Supp. Htr, Rear Video Camera, Traction Control - DEALER INSTALLED OPTIONS Line-X Bedliner, Advance Folding Tonneau Cover, Chrome Bugshield, Dually Splash Guards, Remote Start.
2003 40' TRAVEL SUPREME Triple Slide Fifth Wheel - (OUR COW - Condo On Wheels)
Retired Fulltime RVers "Goin' Places, Makin' Friends, Havin' Fun!"
Our Pictures * Great RV Site * Our Website
RVrs R US is offline
Old 08-11-2008, 12:34 PM   #3 (permalink)
i wish it was that simple.... cap is on tight!
RRose is offline
Old 08-13-2008, 05:17 PM   #4 (permalink)
ok..... my Edge Insight is telling me that their are two codes thrown:
P244: Unknown
P2002: Unknown
Can anyone tell me what these are?
RRose is offline
Old 08-13-2008, 05:43 PM   #5 (permalink)
chuckster57's Avatar
from canOBD2.com
P0244 Ford Turbo/Super Charger Wastegate Solenoid A Range/Performance
P2002 Ford Particulate Trap Efficiency Below Threshold Bank 1
P244 does not show, says must be 4 digit number
P2440 FordSecondary Air Injection System
Switching Valve Stuck Open Bank 1
I don't think the P2440 is applicable to a diesel. I posted the P0244 in case you miss typed. If it is p244 then I don't know
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
PM please not visitor message
chuckster57 is offline
Old 08-13-2008, 06:21 PM   #6 (permalink)
Supporting Member
my03psd's Avatar
A loose gas cap shouldn't affect a diesel,it doesen't have an evap system like a gas vehicle.
3/28/03 F250 6.0L PSD ,TORQSHIFT,CC,SB,FX4,LARIAT
Charcoal Gray/Black,
Tint,RhinoLined,Sirius,Roll&Lock,Strobes,
SCT X3 Custom Tuned by Innovative,
MBRP Stainless 4" Turbo Back,
ISSPRO Pyro,Boost, & Trans Gauges
Prodigy Brake Controller,Remote Start and Turbo Cooldown,
High Idle Mod., PM-13A on the Oil Pan,
HFCM Plug Upgrade,DieselSite Coolant Filter,
Energy Suspension Bushings,& Stanadyne every tank
my03psd is offline
Old 08-13-2008, 06:33 PM   #7 (permalink)
CASPER's Avatar
my03psd,
The diesels do have a closed system and a loose cap does give a light. It will reset when the cap is on tight.
2008 F-350 Super Duty 4X4, DRW, Long Bed, Auto Trans, Lariat, 3.73, 6.4L Turbo Diesel, Transfer Flow 50 Gal Combo Tank
2000 Alpenlite 32 RK
CASPER is offline
Old 08-13-2008, 08:32 PM   #8 (permalink)
Supporting Member
my03psd's Avatar
Is that something for the 6.4?I know my 03,or any of the GMs that people that I know own that this isn't the case.
my03psd is offline
Old 08-15-2008, 04:02 PM   #9 (permalink)
Ironically..... I fired the truck up to drive it to the dealer this morning.... and the check engine light had cleared!
RRose is offline
Old 08-17-2008, 09:15 AM   #10 (permalink)
alexb's Avatar
Originally Posted by CASPER View Post
my03psd,
No, that's not right...
Proud to be a member of Ford Doctors Diesel Technician Society
alexb is offline
Old 08-18-2008, 07:02 PM   #11 (permalink)
CASPER's Avatar
Well I loosen the cap, I get a light. Tighten the cap and within minutes the light goes off. How can that be explained if it is not sealed?
CASPER is offline
Old 08-18-2008, 07:12 PM   #12 (permalink)
Supporting Member
my03psd's Avatar
It may be on the new trucks, but I know older trucks are not like this.I don't own an '08 so I can't argue,but maybe some of you guys that do can elaborate.
my03psd is offline
Old 08-18-2008, 10:54 PM   #13 (permalink)
had same situation-dpf is being replaced
I have a job 3 f450 -this weekend the truck went into active regen,came to a stop,the idle was fine,then jumped to 1800 rpms at a stop in gear-i knew what it was doing-even though it has never done that and is not supposed to,lasted about 30 seconds and was fine on the ride home-went to dinner came to a stop-the truck would not accelerate for about 3 seconds then took off-about 2 miles later the engine light came on...also the temp gauge got all out of wack-would read cold-to about 1/8 when fully hot(normally runs about 1/2 on gauge)..stopped and tried cycling the key a couple of times-but still stayed on.
Got up this morning and the engine light was off-decided to take to the dealer anyways-had P2002 Ford Particulate Trap Efficiency Below Threshold Bank 1,dealer called back and said ,having to replace the dpf(6000 miles on my truck)...also will update the pcm with the newest flash....no other trouble code for the other concerns-thay are chalking it up as a casuality code,
said i should have it back tommorow
ktb706 is offline
Old 08-19-2008, 02:26 AM   #14 (permalink)
Banned
It wouldn't work that quick on a gas truck.... and the diesels still have no EVAP system.... if you want to lend credence to your claim, post the code you retrieve... I would hazard a guess that it has more to do with your transfer tank than anything else....
For the original poster... you would be further ahead with a scan tool you can trust....
GrampyJim is offline
Old 08-19-2008, 02:59 PM   #15 (permalink)
It would be interesting if you had a Diesel with evaporative emissions controls and even more interesting if it worked that quickly at setting off the light.
checkthisout is offline
