6.4L Power Stroke Engine and DrivetrainDiscussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008 Super-Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Looking at getting a 08 F350 4 Door Short Bed 4X4 373 gears
Build date is 5/07 What kida Fuel Milage should I expect to get
I have a 06 Dually 4x4 Now dont get but 13 to 14 at the Most with It
Thanks for ur Help
David
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Firefight181</div><div class="ubbcode-body">Looking at getting a 08 F350 4 Door Short Bed 4X4 373 gears
Thanks for ur Help
David </div></div>I traded in an early 99 small turbo only to get a new fancy 08 that doesn't get any better mileage (more power though). 13 ish unloaded driven sensible, 11 ish local/highway work duty, 8 ish towing 6000 lb enclosed trailer @ 75-80 mph.
2008 F350 Super Duty XLT, 6.4, Auto, Crew Cab, Long Bed, 4x4, Silver!
XD Monster Black 20x9, LT275/65SR-20 Goodyear Wrangler AT/S E, 2 1/2" front leveleling kit, Arnott Industries rear air bags w/ Air Lift on board compressor,
From what I have seen posted shoot for 10 all around mileage. Anything better will just be gravy on your steak.
Y2K excursion XLT 2wd, ordered july '99, built august '99, delivered september 9 '99, 4R100 fried & replaced at 900 miles still running like a champ
expect about the same i'm only getting about 13 with only 1000 miles, i'm hoping it will get better with break in & my lieometer is right on the money.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: SLT223</div><div class="ubbcode-body">Why is the 6.4 getting such bad fuel mileage? </div></div>
more turbo boost = more fuel. One thing I noticed right off my 08 F350 is 4-5 lbs of boost higher at lower speeds/start and stop than my 06 F250. That second turbo is part of the fuel consumption issue.
In my 08 with 1800 miles on it, I get 12.2 around town by the meter, and it pretty much makes sense from looking at the odometer, but I havent done a hand calc.
Both prior vehicles (02, 07) were in the 14's, low 14's when new, and higher 14's after break in in the same exact driving conditions, same route
Towing 10K the 02 got high 12's, hand calculated multiple times across country, never towed on the highway with the 6.0, but the 08 got 10.5 hand calculated over 550 miles. So the 2 mpg diff is pretty accurate
To tell you the truth, the 2 mpg drop sucks big time LOL its amazing how you notice the gauge drop faster, however, the quality and silence of the truck and how it drives makes up for it over earlier models.
Just barely makes up for it to be honest, but it does.
- 2008 XLT Crew Cab 4x4, Tow Command, Camper Special
- 2007 Lariat Crew Cab 4x4 - GONE
- 2002 F250 S/C 4x4 PSD, 4 inch turbo back, zoodad, pre-pump and tank mods, QLJ5/PMT1 Tipton Econotune, Sonnax/Tricumulator, ISSPRO under cubby mount gauges, Prodigy controller, 3.5 inch rear blocks, KYB Monomax Shocks...GONE BUT MISSED
- 1971 F100 Ranger XLT shortbed 4x4, hotrod resto
- 1970 Fastback Mustang, 489 cid FE, TKO-600 5 speed, 3.70 9 inch, ported KC alum heads, giggle gas
- 2007 HD Street Glide, Vivid Black, 96 inch 6 speed
I'm only guessing but I'd say I'm getting around 11 or 12 mpg with my dually and 3.73 gears. The computer says 10.9 as of today and it moves up every day. I have about 1,500 miles on the truck. My 2003.25 dually with 4,10 gears got about 13 mpg all around and as stated above, this truck makes up for it with the quality. I just did a 225 mile each way trip yesterday and I filled the tank before I left and had to fill it on the way home and had about 5/8's of a tank left. When I get serious, I'll waste the time and fill it up to the neck to do a real test. I wish this was like my Sprinter van, it fills to the top (I can see it in the neck) every time on the first click off of the fuel pump nozzle.
I'm not going to say I'm happy with the mileage but, I expected it....I just didn't expect to pay $3.56 a gallon like I saw today at a Shell on Rt. 60 in Vero today [img]/forums/images/%%GRAEMLIN_URL%%/eek.gif[/img]
John
2008 Job 2 F-350 4x4 Crew Cab SWB dually
Lariat with the chrome package.
I'm running an F350 with 4.10 axles and my mileage has been as follows:
250 miles on odometer, 9.9 computer, 9.91 hand calc
600 miles, 10.1 comp, 10.15 hand calc
750 miles, 10.2 comp, 10.21 hand
1025 miles, 10.5 comp, 10.66 hand
I just filled up today and that is the 1025 mile figure above. My '03 6.0 on the same route was getting 13.9 MPG with 80,000 miles on the clock.
__________________ 2008 F350 XLT CC DRW 4x4, 6.4, Auto, 4.10, Manual Transfer case, Supplemental Heat, Wide Track Front Axle, Sirius. 1996 Newmar Dutchstar, 8.3L Cummins 6CTA, MD3060 Allison
** SOLD with 80,300 miles ** 2003.25 (Feb. 14, 2003 build) F350 Crew Cab 4x4 XLT, 6.0
