What's the best oil to use in 6.4? - Diesel Forum - TheDieselStop.com
Old 05-31-2009, 05:14 AM   #1 (permalink)
I have '08 F250 6.4 liter and it's time for the 2nd oil change (10k miles). 1st one was at the dealer. I am a huge fan of Mobil 1, but I'm not sure what oil meets the CJ4 spec requirements and won't plug up my DPF.
Lancelot is offline
Old 05-31-2009, 08:43 AM   #2 (permalink)
Fanuc's Avatar
I am using Mobil 1 Turbo Diesel ... it meets the CJ-4 spec ... I have used Mobil 1 in my last 2 trucks so, I say stick with what you know works
Fanuc is offline
Old 05-31-2009, 10:57 AM   #3 (permalink)
DELO LE 15W40 is CJ certified and will meet all your 6.4's oil requirements out to 10k. Its about half the cost of any synthetic. Your money, your call.
OMC
OMCUSNR is offline
Old 05-31-2009, 11:16 AM   #4 (permalink)
Motorcraft 15W40 is CJ-4 certified and comes in 5 quart jugs at Walmart for $11. Shell Rotella T 15W40 is also CJ-4 certified and comes in 4 quart jugs at Walmart for $10.50. I noticed most of the other compliant oils are similarly priced.
Motorcraft is the best value for your money. I'd run it just because it's simple: three 5 quart jugs. Whereas you'll have some leftover with the gallon jugs.
2008 F250 PSD XLT Super Cab Long Bed (4x2)
2006 Nissan Titan, 6 inch Procomp lift (4x2)
2000 Nissan Frontier, Custom Motorsports 8 inch lift (4x2)
timid1 is offline
Old 05-31-2009, 11:51 AM   #5 (permalink)
Phil_R's Avatar
I'm using Motorcraft 15w40 in my '08 F250 6.4, purchased in 5 qt. jugs @ Wal-Mart for $11.50 each. ( Motorcraft oil filter FL-2016 / $18.44 @ Wal-Mart) Obviously meets all Ford warranty requirements, and changed at 5,000 mile intervals.
2008 F250 XL 4x4 6.4L
2000 VW Golf GLS TDI 1.9L
Phil_R is offline
Old 05-31-2009, 09:35 PM   #6 (permalink)
Price varies from Walmart to Walmart apparently. The Walmart in Brea, California (Orange County) charges $11.50 (last I remember) yet the Walmart in Rosemead, California (Los Angeles County) charges $10.50. It pays to do your shopping, folks.
timid1 is offline
Old 06-01-2009, 05:02 AM   #7 (permalink)
I didn't know that Mobil 1 made a turbo diesel oil. Where do you buy it?
Lancelot is offline
Old 06-01-2009, 05:13 AM   #8 (permalink)
How often do you change your oil? I think Ford says you should change it every 7500miles whether you use sythetic or not.
Lancelot is offline
Old 06-01-2009, 08:46 AM   #9 (permalink)
Fanuc's Avatar
I buy the gal jugs at Wal-Mart, I change it every 5000. For me changing my oil every 5000 miles is cheap insurance for a long lasting engine.
Fanuc is offline
Old 06-01-2009, 11:24 AM   #10 (permalink)
Super08's Avatar
My Photos: (6)
I am using Mobil 1 Delvac 5w40 same as I used in my 6.0. It enables me to run the same oil year around. I had very good oil analysis results on the Mobil oil.
2011 F350 CC Lariat 6.2 4WD SB 4.30's
Super08 is offline
Old 06-01-2009, 10:27 PM   #11 (permalink)
The Delvac 5w40 is suppose to be the same oil sold as Mobil 1 5W40 turbo diesel you get in quarts.
lugnut99 is offline
Old 06-02-2009, 09:10 AM   #12 (permalink)
StanMI's Avatar
Isn't an oil and filter change 15-1/2 quarts ?????
2008 F350 Lariat CC Black two tone and darn near everything else.
StanMI is offline
Old 06-02-2009, 11:24 AM   #13 (permalink)
rock_doctor's Avatar
14.5-15qts
2005 Excursion w/ 6.0L PSD
2008 FX4 F250 CCSB w/ 6.4L PSD
rock_doctor is offline
Old 06-02-2009, 08:17 PM   #14 (permalink)
Exactly 15 quarts. On the dot. Just like the diesel supplemental handbook says.
timid1 is offline
Old 06-03-2009, 05:18 AM   #15 (permalink)
Mine usually comes out to 14.
Red 2002 F-350 XLT SRW 4x4 7.3L reg. cab 6-speed rubber floors traded at 50K for:
Red 2005 F-350 XLT SRW 4x4 6.0L reg. cab 6-speed rubber floors BFG 12.5x35 mud-terrains, no lift traded for:
Red 2008 F-350 XLT SRW 4x4 6.4 reg. cab 6-speed. Got carpet this time- audiophile stereo deletes rubber floors. BFG 12.5x35 mud terrains, no lift.
Traded at 45K for: Red 2011 F-350 XLT SRW 4x4 6.7L reg cab BFG 12.5x35 mud terrains, no lift. "optioned" out of- stick shift, rubber floors, audiophile stereo, fog lights, chrome step bars GRRRRR!
torino73 is offline
