Go Back   Diesel Forum - The Diesel Stop.com > 2008-Up Super Duties > 6.4L Power Stroke Engine and Drivetrain
6.4L Power Stroke Engine and Drivetrain Discussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008 Super-Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Old 02-22-2008, 01:33 PM   #1 (permalink)
Yellow snow under my F350 -- don't eat the yellow snow!
I noticed yellow drops of something in the snow under my F350 FX-4, with 20K miles. Is this a coolant leak? or is my truck having prostate issues.....
My coolant level is just a little low.
TPompei is offline
Old 02-22-2008, 01:44 PM   #2 (permalink)
Rutcutter's Avatar
My Photos: (5)
Is it on the drivers side?
08 SD CC 6.4L 4x4
SCT Extreme Livewire
Loaded Lariat/20" wheels
Nav/audiophile system
Tailgate Step
Sunroof
Clearance Lights
Leveling kit/F350 blks
Rancho 9000X shocks
06 SD CC fx4 (traded ) Great Truck
06 Cat 420D Backhoe Loader
http://community.webshots.com/user/hdsilverado
Rutcutter is offline
Old 02-22-2008, 02:36 PM   #3 (permalink)
I appears to be on the passenger side.
TPompei is offline
Old 02-22-2008, 04:58 PM   #4 (permalink)
Take it to the dealer. It sounds like you, like many others, have a leaky radiator. Make it clear to the dealer you want a recently-built replacement, because one guy on this forum is trying to have his truck lemon-lawed, since he has had his radiator replaced FOUR TIMES and it still leaks. Supposedly, the newer radiators are OK.
Red 2002 F-350 XLT SRW 4x4 7.3L reg. cab 6-speed rubber floors traded at 50K for:
Red 2005 F-350 XLT SRW 4x4 6.0L reg. cab 6-speed rubber floors BFG 12.5x35 mud-terrains, no lift traded for:
Red 2008 F-350 XLT SRW 4x4 6.4 reg. cab 6-speed. Got carpet this time- audiophile stereo deletes rubber floors. BFG 12.5x35 mud terrains, no lift.
torino73 is offline
Old 02-22-2008, 05:27 PM   #5 (permalink)
If the yellow snow is appearing somewhere in the vicinity of the radiator good chance that it is coolant. My radiator started seeping coolant around 9500 miles. I saw a very small puddle pretty much under the right side of the radiator, traced it back up the right front frame rail to the seam between the right tank and cooling fins. New radiator was manufactured in Mid November 2007. Since installation no further issues.
2008 F-450 Lariat Dark Stone Metallic over Pueblo Gold 4x4(manual shift transfer case, manual hubs), High capacity tow 4:88s, Off Road, Camper packages, Sirius Sat, Upfitter switches, DVD entertainment, tailgate step, traction control, Audiophile 6-disc, PTC Supplemental heat and heated seats(warm buns), rear sensors, traction control, tailgate step. Built May 8, delivered May 24
Reese Signature Series 24k fiver hitch, I installed it myself, best hitch I have found yet
Line-X bedliner, heavy duty floor mats
2003 Sunline F281SR(weekend getaways)
SeaRay 215EC
http://community.webshots.com/user/C...host=community
CaptSkup is offline
Old 02-22-2008, 06:05 PM   #6 (permalink)
Somebody is peeing on your truck... I would be pretty mad if I were you
dustinwill23 is offline
Old 02-22-2008, 08:08 PM   #7 (permalink)
Probably that golden destroyer that lives down the street.
Y2K F250 CC PSD Auto, Short-bed Lariat, Woodland Green/Gold, ordered 07/10/99, born 09/12/99, delivered 10/08/99, Access bed cover, Bed Rug, Zoodad mod, Viper Remote Start Alarm, Fumoto valve, 103K somewhat error-free miles (so far) [never back to dealer for anything]
Repairs: CPS, Water Separator Valve assembly, rear axle bearings, VSS, batteries, brakes, alternator, serpentine belt (x2), driver door pwrlock actuator, water pump
2003 VW Jetta TDI auto, 90k miles, all stock, no mods, 41 mpg most days. A rocket in disguise...
Repairs: alternator, brake switch (x2), power window wire harness, #4 glow plug, glow plug wire harness -TRADED as of 11/24/2008
Newest purchase - 2009 VW Tiguan 2.0 l turbo 200 hp gas engine (TDI engine not available yet)
short_stuff is offline
Old 02-23-2008, 07:36 AM   #8 (permalink)
Seapig53's Avatar
That happens man, those guys are REAL!!!
golden destroyer.........
You guys are goofs.
I have not heard of to many problems with leakage on the 6.4L's except for the one (5 radiator's, Lemon law. I dislike my Ford guy).
Must be bad Karma because that is like the only issue I have ever seen that is even simalar to that.
~Mike~
2008 F-450 CC Lariat...Plus moon roof
Seapig53 is offline
Old 02-24-2008, 07:02 AM   #9 (permalink)
loft306's Avatar
You guys are goofs.
~Mike~
haha!... there were alot of them a few months back i want to say the fixed radiators were made after about sept 14 2007 anything with a radiater manufacture date b4 that is suspect. or was it oct. 14th
~ Mike
2008 BLACK F350 XLT RC SRW 4x4, 6.4, Auto,3.73ls, ManualTransferCase,PTC-Heater. Pic's She is Sweet...
DORA recieved:9/14/07 || ReceiptDate:9/14/07 || SerializeDate:11/01/07 || SegmentDate:11/01/07 || SequenceDate:11/10/07 || BlendDate:11/13/2007 || GesitmatedBuildWeek: 12/10 || ProducedDate:11/21/07 || GateRelease:11/21/07 || ShipDate:11/24/07 || ArrivalDate:11/30/07 || SoldDate:11/30/07 ||
1992 F150 | 1987 E250 | 1983 CutlassCiera | 1979.5 K5 blazer
loft306 is offline
Old 02-24-2008, 07:18 AM   #10 (permalink)
Did you see any dog or cat tracks around your truck. Serisouly if you drove your truck, an animal may have crawled under your truck where it was warm to sleep for the night. Then before leaving marking the area for there return.
Big Old Countryboy from South East Michigan.
USMC 1996-2003
2002 F-250 Crew Cab 4x4
DIY Tymar Intake
4 inch straight pipe exhaust
ts-6 position chip
built transmission
More to come later......
bigcountrysg is offline
Old 02-24-2008, 05:53 PM   #11 (permalink)
I've got some devilish squirrels that need to eat your snow.
Y2K excursion XLT 2wd, ordered july '99, built august '99, delivered september 9 '99, 4R100 fried & replaced at 900 miles still running like a champ
exoval is offline
Old 02-24-2008, 06:06 PM   #12 (permalink)
No animal tracks under there. Just to be sure, I'll go out and remark my territory. Then take it to the dealer.
TPompei is offline
Old 02-25-2008, 10:57 AM   #13 (permalink)
Hopefully if there is a problem, it is the rad, because they can just replace it with a recently built one and it should be good to go. It would suck if it ended up being a continuing problem.
Rednecks have more fun!
1992 F350 CC LB 5.8L 5-speed 4.10 L/S. Stock
92F350CC is offline
Old 02-26-2008, 08:04 PM   #14 (permalink)
Well, I was just sitting here laughing maniacally (not really) because I thought I had lucked out on the radiator problems. I was installing my Job 2 air dam tonight and noticed coolant all over the frame. A quick search revealed it was coming from the radiator on the driver's side.
20K miles, Job1 truck, thought I was safe on this one......
2008 F350 SRW 4X4 Lariat, Crew Cab, SWB, 3.73 LSD
HMTR is offline
