I took a set of running boards and flares off my recently purchased truck. (97 ext. cab long bed) I have all mounting hardware and bolts. Just missing maybe two self tappers and one through frame bolt where I snapped it off. Ideally you pick them up, I'm located in Rising Sun, MD. Google bremen composites, they look a lot like those, except have the access step to the bed. The color is Teal color code PT from Ford, which will most likely have to be painted to match your truck. I've seen these go for over seven hundred dollars so let's be reasonable. If anyone wants them make me an offer and they're yours. For more info just call me at 443 309 1887. Pics
F410-01
That's really the best I can do for pics unless you guys call and want me to email you some. Thanks very much, Eli Wilson
