6.4L Upgrades and Aftermarket - EngineUpgrading or adding OEM or aftermarket equipment to your 2008-Up Super Duty truck with 6.4L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
I pose a question on the different grades of filters AFE has to offer.
(PG-7) - (Pro DryS) - (Pro 5r)
My questions is unless your driving on a gravel road all of the time why wouldn't you use the Pro 5r? It is supposed to have the best flow numbers and is rated to be better at protecting from dust than a stock filter (as far as AFE's info says). I know the Pro DryS allows you to get away from cleaning and re-oiling but other than that why would you choose the Pro Dry over the 5r.
How much off road traveling deems it necessary to use the Pro 7 or the Pro DryS for that matter?
Let me ask you this as well. If the 5r is better than a stock filter and most people aren't afraid to drive off road with stock filters, why wouldn't the 5r suffice in most cases.
Just something I have been wondering about.
2009 F250 XLT 6.4, BRAND SPAKN NEW, BONE STOCK AT THE MOMENT
-SOLD- 2003 F250 7.3 42,000 miles Bully Dog 6 Position 4 Bank Chip, Volant Intake, 4" Exhaust, BD Diesel Gages
I drive caliche roads all day long and have the pg7. all of my trucks have the pg7 filter and i wont try the pro 5 just bc i dont want to chance it. You wont notice any performace gain between the 2
__________________ 2008 F-350 King Ranch 4X4, job build 3, tuned by Spartan
RIP: 95 F-350 Powerstroke, 4X4, 5 Spd, Crew Cab,Long Bed, 4" Superlift on 35" BFG All-Terrain, Diesel Innovations 4 Bank chip, 4" exhaust, DIY Tymar, Ranch Hand repalcement bumpers
Thanks powerstrokin03, I was wondering if you loose any performance by using a higher grade filtration.
Does anybody know what the flow difference is between the 5r and the pg7. The AFE website doesn't compare apples to apples. The pg7 and the dry-s use the same vacuum but the 5r uses a different vacuum to compare to.
Originally Posted by caryt
You already have the best filter system...stock
Sorry but I have a hard time believing that. If stock was the best AFE, Volant, S&B and many other would be out of business. No one would use there filters for risk of engin damage.
on the tuned trucks like mine the stock intake doesn't become a restriction until you start using the 210 and higher tunes....
As far as filtration you won't find a better set up. Also, other than the S&B all those intakes are prone to CEL's with an otherwise stock truck. Do a search
2008 Ford F-250 CC SB
6" Stage II Pro Comp Lift
17x9 Pro Comp 7189
37x12.5 BFG M/T KM2's
Spartan/4" duals/AFE Try the SEARCH Button Because It's Probably already been asked
My old 7.3 was tuned and ran substantialy better with an intake. My top tune only added 100hp so I think a no matter what tune you use, added air flow helps. Less restriction no matter on what level increases power.
All the searching I have done describes CEL's coming on with an intake. I was thinking of just using a drop in filter. Are people still haveing trouble setting off the CEL's with a drop in? If so, what filter were you using?
i have heard of no issues with just a drop in. As far as your 7.3... the filter set up on the 6.0 and the 6.4 is far superior to anything the 7.3 had. That is why i commented on a fairly stock truck, an aftermarket intake is just going to add noise... but what do i know?
17x9 Pro Comp 7189
I guess you never heard of PT Barnum.
