6.4L Upgrades and Aftermarket - EngineUpgrading or adding OEM or aftermarket equipment to your 2008-Up Super Duty truck with 6.4L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
I just installed and AFE intake and after driving it for 20 min my check engine light came on and on my edge it said that i believe it was code p2002 particulate trap efficiency below threshold bank1
aby ideas and ive been driving for a day now mind you its only been around town so 15 km or so and the regen hasnt kicked on yet so im just wondering what to do and a cold air intake wont void the warrenty no???
Make sure that when you install your instake system you reset the "FILTERMINDER" by pushing the button on the sensor as it WILL throw codes if you didnt, Make sure that you put in your stock intake if you take your truck to the dealership as it can void your warranty. Key word CAN.
2008 FORD F350 WHITE
8" BDS 4LINK LIFT
37" TOYO MT'S
18" DEVILSLIDES CHROME
SCT TUNER
AFE STAGE II WITH BOOST TUBE
KENWOOD DNX8120 EVERY ADD
FAB FOUR BUMPER W LINEX COLORMATCH
BEAMER HID LIGHTS
4 KC 8" HID LIGHTS
ION CHROME MIRROR LIGHTS
LED INTERIOR LIGHTS
BUSHWACKER POCKET FLARES
HUSKY LINERS
LINEX BOX
MARATHON SLED DECK, W 10FT RAMPS
is that just the little clear cylinder ??? sorry if thats a stupid question
Its on the passenger side its clear with a blue push button. It works via a vacuum effect so make sure when you change your filter you push the button to reset it.
8" BDS 4LINK LIFT
37" TOYO MT'S
SCT TUNER
BEAMER HID LIGHTS
4 KC 8" HID LIGHTS
LED INTERIOR LIGHTS
HUSKY LINERS
LINEX BOX
Are you saying that those who install aftermarket intakes AND reset the filter minder will not get these codes?
I've read MANY posts here about different intakes throwing the exact same codes. Some how I think that the filter minder isn't going to make the problem go away.
My educated guess is that it's a problem with the intake and the tight parameters of the truck's on-board computer. Translation: there's squat you can do about it without going back to stock.
I was told by a Ford Mechanic to do it I have not had any codes thrown with my truck, A stock filter will throw codes also if it all of a sudden plugs or lets in too much air too fast, ( which is what it would think its doing) after you install a high flow intake. It may not be 100% right but it has seemed to work for me and a few others I know??? Just trying to help
8" BDS 4LINK LIFT
37" TOYO MT'S
SCT TUNER
BEAMER HID LIGHTS
4 KC 8" HID LIGHTS
LED INTERIOR LIGHTS
HUSKY LINERS
LINEX BOX
If you have a way to clear your own codes, I would go with the option of resetting the Filter Minder and driving on... I couldn't locate the codes that you mentioned in the documentation that I have for Ford Diagnostic Trouble Codes...
2008 F-350 4 X 4 Crew Cab, Long Bed, SWB, Lariat
6.4 Liter Power Stroke that I traded up to!!!
Edge Evolution, Rhino Lining, Snug Top, 3.5 " Tube steps
I threw my AFE in the trash. Be aware that you must clean it ALL THE TIME. I'm in a dusty environment and I tap out my stock filter DAILY. Even then, you will want to clean your MAP sensor at the same time you clean your filter. The filter stops the big chunks but not the finer particles. You AFE owners will know what I'm saying when you take a clean paper towel and wipe down the inside of the intake tube.
For those thinking about upping HP on a heavy hauler or work truck, I feel this $240 product is a bad match for a $7k warrantied motor. Bummer.
Here's the deal on AFE. The AFE intake air flow is much different than the engineered stock intake. This effects the readings on the map sensor that will allow the egr's to get hotter, allowing the cat to exceed the operating temp range and that will cause the motor to stop running until the temps drop to allow the breaker to reset. Been there.
well i just did a 1000km drive and the regen finally did come on and it stayed on for a while and then now the morning after my check engine light is on and its that same code particulate filter trap efficiency below threshold bank1 ..............so other then that the truck is running great and my milage got even better so i think for right now im going to keep it in and i got the dry filter with a sock i heard its the oil ones that suck in the dust in the intake tube???
TO be honest, you might as well get used to it. I run the S&B Intake and have not had a single issue in nearly 30K miles.
Its the dry ones that suck in dust, the oil ones stop the dust from going through waaaaay better, Just keep them clean and oiled!!!!
8" BDS 4LINK LIFT
37" TOYO MT'S
SCT TUNER
BEAMER HID LIGHTS
4 KC 8" HID LIGHTS
LED INTERIOR LIGHTS
HUSKY LINERS
LINEX BOX
When I bought my AFE, I called AFE after getting the 2002 codes. They sent me a different size pipe. There are two sizes. According to AFE Ford changed the intake pipe size sometime in the spring of last year. The original system I bought had a loose pipe fit. The new pipe corrected the size problem but I never reinstalled the system. So I don't know for sure if it corrected it or not. According to AFE that corrects the problem. Was your intake pipe a loose or tight fit?
2007 F350 crewcab Lariat shortbox Diesel 4X4, Retrax Roll Top Cover, Newer tailgate with camera and step, Airaid Intake, Magnaflow exhaust, Cortex tuner on mileage setting, Edge Insight CTS Monitor, Upfitter Switch Kit, Sinister Diesel Coolant Filter.
