Go Back   Diesel Forum - The Diesel Stop.com > 2008-Up Super Duties > 6.4L Upgrades and Aftermarket - Engine
6.4L Upgrades and Aftermarket - Engine Upgrading and adding aftermarket equipment to your 2008 Super Duty truck with 6.4L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Old 05-15-2008, 06:18 PM   #31 (permalink)
my truck is a short bed crew cab and did not have to cut at all and fit very well, i had to move it around and tweak a little bit to get the best fit but very easy and getting tons of compliments
2008 F-250 Crew Cab short bed 4x4 lariat Black with Tan interior. 2.5" lift, toyo open country M/T, Banks Monster Exhaust, Recon Smoked mirrors,Billet Side Vents. Bilstein Shocks
blakedog is offline
Old 05-15-2008, 09:41 PM   #32 (permalink)
Blakedog,
Glad to hear yours went in well. Overall its a nice looking system - did get me 1.2mpg increase while towing! That is almost priceless these days!
2008 F-350 4wd Crew Cab Long Bed
6.4 Diesel w/ Torqshift
finchturf is offline
Old 05-22-2008, 11:16 PM   #33 (permalink)
slurrr's Avatar
Installed mine today on a short bed crew cab, very easy installation, the tailpipe sits a little close to body of the truck, but i am gonna try and do some adjustments in the morning. I ran out of daylight, but overall very nice looking compared to the stocker.
2008 F250 6.4L 4 X 4 (Job 1) Crew Cab Lariat Shift on the fly, 3.73 White w/ medium stone leather interior, Banks 4" Single Monster Exhaust, Billet front and side grilles, XM Radio, Rhino Liner...
slurrr is offline
Old 05-24-2008, 08:46 PM   #34 (permalink)
I noticed the same thing about it being close to the body. I also had to bend the heat shield around the spare tire. It still seems to contact that though... Let me know how you make out with your adjustments. I'm not satisfied with the fit and will more than likely remove it. I've contacted Banks and sent them pictures.
Old 05-25-2008, 08:55 AM   #35 (permalink)
Engine31's Avatar
My Photos: (6)
Starting to see a trend here with the long bed installations. I think I'll wait to see how this pans out.
F450 Lariat 4X4, red, 4.88's, everything but the moonroof, S & B Intake, Banks exhaust, Amsoil.
Engine31 is offline
Old 05-25-2008, 09:49 AM   #36 (permalink)
just make sure all of the clamps are loose and you can adjust it very easily to a fit that suits you. i worked on mine for about 5 min after i got all the hangers installed and its a perfect fit. There is about 6 inches of room to move the exhaust back and forth and you have to twist the last piece of the pipe to get it to align right. It helped on mine to look at the picture on how it was installed on the banks truck in the picture.
blakedog is offline
Old 05-25-2008, 02:23 PM   #37 (permalink)
slurrr's Avatar
I loosened the rear hanger for the tail piece and turned the pipe as much as i could and only got about another 1/4 to 1/2" away from the body. So my tail pipe is about an inch clear from the body, better than it was...but still too close in my opinion. I was maybe looking at modifying by dropping the bracket that holds the rubber grommet, but i am not sure if that help, I think i will just leave alone, again still looks way better than the stock pipe and i do notice a difference in the backpressure, especially at highway speeds, seems to not labor as much....
slurrr is offline
Old 05-25-2008, 02:26 PM   #38 (permalink)
slurrr's Avatar
Sorry, i meant to say loosen the rear clamp for the tail piece
slurrr is offline
Old 05-25-2008, 02:35 PM   #39 (permalink)
sheepman's Avatar
My Photos: (6)
Has anyone installed the Banks Tail pipe with a B & W hitch installed yet???
Does it Clear the hitch?
sheepman is offline
Old 07-31-2008, 04:54 PM   #40 (permalink)
Engine31's Avatar
My Photos: (6)
Installed my Banks Monster Ex. and was very pleased with it. It was a little harder to get the old system out with the dually tires eating up some room, I had to remove the two end screws holding the spare guard so I could sneak it through, with the truck jacked too. Originally it looked like the old one would come out easier going forward over the axle toward the front, but that was not the case.
Fit was great, a little close but ok I think, looks great, sounds a little better at speeds. I cant wait to tow with it now. I don't have any expectations of a great increase in mpg, so any will be good.
I'll post on the results.
Thanks Banks for a fast delivery.
Engine31 is offline
Old 08-02-2008, 11:13 PM   #41 (permalink)
Is anyone using the intake as well?
08 F-350 lariat 4x4 dark blue pearl.
The_Juice is offline
Old 08-03-2008, 05:42 PM   #42 (permalink)
guardrail22's Avatar
If you go drag out the posts that were made by the BANKS guy a few weeks back, what you learn is that the claim they make of reducing backpressure 47% applies to reducing the backpressure they attempt to effect - so they reduce the back pressure between the DPF and the tail pipe and lower the EGT AT THE PIPE EXIT.
Both nominally meaningless in the grand scheme. It won't be better until they come up with a better solution than the DPF and wasting raw fuel to clean it.
2008 F450 CC Lariat White/Gold, JAD Solutions Lights, 62 Gal Titan, B&W Hitch, Ford Gold Remote Start, TruckTrunk box, Viair 550+2x2.5gal receiver
New Truck
http://www.f150online.com/galleries/....cfm?num=15052
Traded In Nov 07: 2003 F250 CC LB XLT 4x2 PowerStroke, Captains Chairs, White/Parchment, Torqshift, Heated Mirrors, Trailer hitch, Adv Security Group, Clearance Lights, Adj Pedals, Privacy Glass, Sliding RW
Delivered 11/27/2002
7100# with full fuel and no occupants
towing a 2005 Pilgrim 306RL-SS w/Hensly Arrow
http://www.f150online.com/galleries/...w.cfm?num=3016
guardrail22 is offline
Old 08-07-2008, 06:28 PM   #43 (permalink)
Does anyone have a picture of the banks exhaust from a little ways away, not really close?
mattmeyer05 is offline
Old 08-08-2008, 04:19 PM   #44 (permalink)
Engine31's Avatar
My Photos: (6)
Engine31 is offline
Old 08-08-2008, 09:11 PM   #45 (permalink)
Thanks Engine31 how about one from the side too?
