Banks Technicooler (sneak peek) - Page 2 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 6.4L Upgrades and Aftermarket - Engine
6.4L Upgrades and Aftermarket - Engine Upgrading or adding OEM or aftermarket equipment to your 2008-Up Super Duty truck with 6.4L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Old 08-05-2009, 08:54 PM   #16 (permalink)
guardrail22's Avatar
what - no DieselStop exclusive field test program?
New Truck
2008 F450 CC Lariat White/Gold, JAD Solutions Lights, 62 Gal Titan, B&W Hitch, Gold Remote Start, TruckTrunk box, Viair 550+2x2.5gal receiver, 2010 NAV and Sync
____________________
2008 Carrilite XTRM5
Traded In Nov 07:
2003 F250 CC LB XLT 4x2 PowerStroke, Captains Chairs, White/Parchment, Torqshift, Heated Mirrors, Trailer hitch,
Delivered 11/27/2002
towing a 2005 Pilgrim 306RL-SS w/Hensly Arrow
guardrail22 is offline
Old 08-11-2009, 02:54 PM   #17 (permalink)
AllWhite08's Avatar
I cant imagine that spending 1200.00 on an intercooler is worth the money. I am regretting buying the six gun as i cant tell if its on after i got used to it.
08 F-250 Lariat 4x4 CC White
Banks six gun, Air Raid ,
AllWhite08 is offline
Old 08-13-2009, 10:07 PM   #18 (permalink)
09F350Stroker6.4's Avatar
Aftermarket intercoolers are made for people looking for serious power. The average driver does not need to purchase this. They can and I mean nothing against anyone buying just to have. But you wont notice that much unless it is working in unison with other performance parts.
09F350Stroker6.4 is offline
Old 08-17-2009, 06:50 PM   #19 (permalink)
Power12's Avatar
Is there anybody that has a replacement pipe for the collapsed one that runs through the frame work,or does that have no efect on the flow.
Power12 is offline
Old 08-18-2009, 07:43 PM   #20 (permalink)
River city dsl- just finished making one
2008 F-350 King Ranch 4X4, job build 3, tuned by Spartan
RIP: 95 F-350 Powerstroke, 4X4, 5 Spd, Crew Cab,Long Bed, 4" Superlift on 35" BFG All-Terrain, Diesel Innovations 4 Bank chip, 4" exhaust, DIY Tymar, Ranch Hand repalcement bumpers
2004.5 Cummins 600, 2500 Larimie, 4X4, LWB, 48RE, Full billet DTT, FASS fuel system, TST, SMARTY, Flux 3 injectors, Helix cam, Di-Procol (Boost, EGT, Trans, Rail, Fuel), AFE PG7 stage 1, JL Stealth box, Donaldson, 315 BFGs. (893 on fuel )
2005 Chevy 2500 Duramax, Diablo tuner, PYRO.
powerstrokin03 is offline
Old 08-28-2009, 03:59 PM   #21 (permalink)
bankspower's Avatar
I've got a few mnore details for you guys. The following is from our engineering department:
*Banks Technicooler is engineered to reduce the temperature of the air entering the engine while not losing any pressure.
*Cooler air is denser air = more oxygen
*More oxygen means a greater combustion, more power, greater efficiency, lower operating temps (egts)
A decrease in air intake temperature provides a denser intake charge to the engine and allows more air and fuel to be combusted per engine cycle, increasing the output of the engine.
Compared to the stock intercooler:
1. Overall, a much larger intercooler:
a. Larger in height, width, and a much thicker core (23% larger core!)
(Larger dimensions allow for greater flow and cooling)
b. Larger, more effective and efficient design resulted in a 64% lower hot-side pressure drop than the stock intercooler. This means the engine is not experiencing any pumping losses (Pumping loss is the power used to pump the fresh air into the cylinder and pump the exhaust gas out, of course the "pump" is the piston. To reduce the power wasted in pumping in fresh air, we can pressurized the input air, that is, using a turbocharger, but we do not want to lose any of that pressurized air …that is one of main design goals of all intercoolers)
c. Designing a larger intercooler, with greater flow and cooling, without any modifications to the original vehicle design and without restricting air flow to the radiator is the result of true engineering!
2. Density Ratio Improvement: (Measured during the Wind Tunnel Test: hot air goes into the inlet or hot side of the Technicooler, air is passing over the front (as it would in driving conditions), then measuring the air coming out of the outlet, or cold side)
a. This is the most important metric, as it shows how much oxygen is present in a given volume of air
i. This Technicooler actually shows the greatest density improvement of any GBE Technicooler.
ii. The density ratio improvement of the Banks Technicooler is what matters……….Banks Technicooler increases the density of the intake charge, resulting in greater power and efficiency.
The intercooler is now available and we'll post up some additional testing info shortly
bankspower is offline
Old 08-28-2009, 05:19 PM   #22 (permalink)
bankspower's Avatar
Here's a little better picture of it:
Old 08-28-2009, 05:46 PM   #23 (permalink)
smotrs's Avatar
My Photos: (16)
Jeff, Read your PM.
Shaun
'08 F250 6.4L Lariat 4x4 CC/SRW fully loaded, special ordered
6" Fabtech 2.25 dual shock lift w/18" AR wheels, 35" Toyo AT
Avic-Z2 (Z3 Mod) Nav/Stereo w/iPod, Bluetooth, XM NavTraffic
(2) Rear headrest mnt DVD entertainment systems
Line-X bedliner
Banks CAI, Dual Exhaust, 6-Gun, Speed Brake & iQ (test vehicle)
Bushwacker Fender Flares (color matched)
Ravelco Anti Theft Device
Originally Posted by George Bush
Wait, what did you just say? You're predicting $4 a gallon gasoline?. . . That's interesting. I hadn't heard that.
smotrs is offline
Old 08-29-2009, 11:04 AM   #24 (permalink)
Martin #6's Avatar
Banks - Does the new intercooler come with new IC pipes also?
Early 99 F-250 4X4, built 9/98, 3:73LS, ATO trans with Chevron 30wt Drive Train Fluid, Garrett 38R BB ceramic coated 1.0 turbo, High Flow ceramic coated outlet, Non-ebv pedestal, BHA, Beans billet intakes, Teminator HPOS w/ R-IPR, Spearco 7.3 IC, 6.0 trans cooler, BWD ceramic coated bellowed up-pipes, DI regulated fuel return, AirDog, SWAMPS Stage II singles, BD Torq-loc, BD 4" in-line exhaust brake, 4" exhaust with ceramic coated downpipe, Live tuned by DP Tuner, Tymar, Racor CCV4500, Coolant filter, 203 T-stat, Pre and post pyro's, OilGuard by-pass filter.
SOLD
2008 F-250 4X4 Lariat CC. Job 3
No longer stock.
Martin #6 is offline
Old 08-31-2009, 11:19 AM   #25 (permalink)
bankspower's Avatar
No. It hooks up to the stock boost tubes and all of our testing was done with them. Changing the tubes would require grinding/cutting the upper core support to install it. For a lot of folks that's more then they want to do on a brand new truck. We're going to offer the tubes in the near future but they will be optional.
Old 08-31-2009, 11:24 AM   #26 (permalink)
Martin #6's Avatar
Good to know that I'll still be able to use the RCD aftermarket IC tube with your intercooler.
SOLD
No longer stock.
Old 09-08-2009, 09:52 PM   #27 (permalink)
warranty
I know it has been brought up but I called my local ford dealer and he told me that if I put a banks in the truck (just air intake) that i have voided the warranty. Any help??
I want the Techni cooler and pda system but don't want to void the warranty of an new truck!
rmcintosh23 is offline
Old 09-08-2009, 10:07 PM   #28 (permalink)
senix's Avatar
The Ram Air from Banks won't void the warranty as it is CARB certified and has a EO #. In other words it is certified to meet the manufactor specs and California emissions.
Gonna be might hard for Ford not to warranty that. Local Dealer knows nothing about that certification. All the rest there is a risk, but the PDA by itself just reads eng peramiters. So that too would not do anything more that a guage.
Intercooler and the 6-gun are the only things that could hurt you, but the jury is still out on that one.
08F250 CC 6.4 PSD
Banks 6 gun/ram air
40' Stoneridge 5th wheel, coming in at 14K.
senix is online now
Old 09-08-2009, 11:31 PM   #29 (permalink)
Careful with that statement. CARB and EO# pertains to emissions legality for the State of California. This has nothing to do with FORD warranty.
Warranty compatibility is still up to the dealer and FORD.
1999.5 F350 Dually 4X4, ITP Regulated Return, DP-Tuner, 4 Inch Pro-Comp Lift, AFE Pro Guard 7, Headers, 4 Inch Banks Exhaust, Matrix Remote Start, Firestone Air Bags with 3/8 Valves and Lines, 2 Viair Compressors, 2 Air Tanks, B&W Turnover Ball
jystorey is offline
Old 10-07-2009, 04:57 PM   #30 (permalink)
any word on the comparison with the turbonetics?
inino is offline
