Edge Insight - Page 2 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 6.4L Upgrades and Aftermarket - Engine
6.4L Upgrades and Aftermarket - Engine Upgrading or adding OEM or aftermarket equipment to your 2008-Up Super Duty truck with 6.4L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Old 02-16-2009, 05:03 PM   #16 (permalink)
Bucktail's Avatar
Has anyone found a paint number for the dash panels in the 2008 F250 SD.
I would like to paint my Edge dash pod to match.
Thanks,
Bucktail
2008 F-250 Lariat, Super Cab, 4X4 Off Road, Shortbed, 6.4 Power Stroke, TorqShift, 3.73 Limited Slip, ESOF, 9800# GVWR Package, Chrome Tubular Cab Steps, 20" Alum Wheels, LT275/65r20e OWL All-Terrain Tires, Tow Command System, Tail Gate Step, Sirius Satellite Radio, Powerscope Mirrors, Leer 100XQ Color Matched Cap, Silver Clearcoat Met Exterior, Medium Stone Leather Interior. ( My first diesel )
Previous Fords,
1997 F-150 XLT 4x4 Off Road 4.6 Loaded
1990 F-150 XLT 4x4 Off Road 300ci Loaded
1976 F-150 Heavy Duty 4x4 300ci
Bucktail is offline
Old 03-26-2009, 09:08 PM   #17 (permalink)
Shinny's Avatar
I'm a newbie to the forum and to running a diesel, so forgive me. I talked to my local dealership today about the Edge Insight and was told that the warranty would not be voided unless the Edge Insight contributed to or caused something to fail. Has anyone been able to get a definitive answer from Ford? All I can get is double talk to get around a yes or no. I want to monitor my truck while towing my RV, but don't want a voided warranty.
Thanks,
'08 F250 FX4 6.4L Super Duty Crew Cab SB Silver Metallic & Dark Shadow Grey Job 1
Extang Trifecta Bed Cover,
High Idle Mod,
Spray in Bed Liner
second radiator
EGR Valve replaced
100% Stock
Shinny is offline
Old 03-27-2009, 01:00 AM   #18 (permalink)
The Edge Insight does not change the fueling. It just reads off the OBD for monitoring parameters. So, no it should/will not void the warranty.
You may have to explain to the dealer what it does.
firemansdiesel is offline
Old 03-27-2009, 09:17 AM   #19 (permalink)
It was the latest update that canceled out those parameters. Edge reprogrammed to the previous firmware and all was well again
mlbmd is offline
Old 03-28-2009, 12:22 AM   #20 (permalink)
burnetma's Avatar
So the manual is a bit ambiguous.
Does the Edge Insight monitor and report transmission and torque converter slip?
Having this data real time could be worth the price of admission.
2008 F350 FX4 Crew, 4x4, 6.4L, Torqueshift, 4.30, tow command, leather, power everything. 75k+ miles. Built 4/17/2007 (Job 1), Purchased used 3/16/2009
2010 Mustang GT Premium - 4.6L-3V, 5 Speed, Grabber Blue - Now this is FUN!
1997 F250 EXT Cab, 4x4, E4OD, 4.10, 273k+ miles.
Modifications: Pyro & boost guage, 202 T-stat, transmission cooler & Tymar - SOLD!!!!!!!
2004 John Deere 5420 MFWD Utility Tractor with 541 MSL Loader.
burnetma is offline
Old 03-28-2009, 09:31 AM   #21 (permalink)
Bucktail's Avatar
Edge Insight
Yes, it will monitor trans temp and torque converter slip.
I still can't it to read the correct MPG reading.
I had to contact Edge to get them to put the old settings back into the Insight using Fusion.
Bucktail
Previous Fords,
Bucktail is offline
Old 03-28-2009, 04:52 PM   #22 (permalink)
kmcg1300's Avatar
My Photos: (5)
Cool About to get edgy
Thanx guys for all the good replies on the edge insight, but i am really concerned about warranty voidance with the way ford is all skeptical of everyone with any type of tuner or monitoring device. Just want to know for sure because the insight sounds like the perfect piece of equipment for all of us guys that want to upgrade during warranty period, and i really want one.
kmcg1300 is offline
Old 03-29-2009, 10:14 AM   #23 (permalink)
I have had my truck in for service with the edge insight in view and connected. They had no problem with it, disconnecting it to update flash, and reconnecting afterwards.
mlbmd is offline
Old 03-31-2009, 12:40 PM   #24 (permalink)
I just got my insight and installed it.
What parameters do most people prefer to watch? There is so much you can look at that I am at a complete loss as to which ones are the most important.
Specularius is offline
Old 03-31-2009, 03:54 PM   #25 (permalink)
I am interested as well as mine will be arriving today.
2008 F250 4x4 Crew Cab, King Ranch 87K miles, Spartan Tunes and DPF Delete exhaust, 35x12.50x18 Cooper STT tires on Rockstar wheels. AFE Stage II Intake, Ready Lift leveling kit w/F350 Blocks.
jtfrisco is offline
Old 03-31-2009, 04:53 PM   #26 (permalink)
Common parameters to watch is EGT, Boost, Tranny, Engine Temps..
Old 03-31-2009, 05:08 PM   #27 (permalink)
One word of caution, do not allow fusion to update the unit as it will no longer read transmission temps.
Old 03-31-2009, 11:04 PM   #28 (permalink)
Mine out of the box isn't reading transmission temps....any idea why? Also, I thought I read it was supposed to read MPG and fuel levels but I don't see that setting.
jtfrisco is offline
Old 04-01-2009, 09:14 AM   #29 (permalink)
gypsybill's Avatar
My Photos: (13)
I just talked with Edge and if yours is a late build like mine (2.19.2009) it probably has the software upgrade that messed with the sensor readings... call Edge Tech Support.. they are sending me a new one (for another unrelated problem) but we talked about the software version and he is going to set the new one he sends me so it will again read the sensors..
Bill
2009 F450 Lariat 4X2, Sterling Grey over Black
ReTrax Tonneau, AirSafe 25k 5th Wheel Hitch
2010 DRV MS 36RSSB3
gypsybill is offline
Old 04-01-2009, 06:26 PM   #30 (permalink)
If you get a chance can you tell me what firmware and calibration you have? I have spent 4 hours with Edge support today and they can't get it working. If you want to PM me your last night they can look it up that way as well. Thanks, Jason
jtfrisco is offline
