6.4L Upgrades and Aftermarket - EngineUpgrading or adding OEM or aftermarket equipment to your 2008-Up Super Duty truck with 6.4L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
I am looking to add some gauges to my stock 08 diesel. I recently looked at the Edge Insight gauge which offers a "Regen" status readout as well as EGT's, etc. Anyone have any experience or thoughts on this product? Any input is greatly appreciated, thank you!!!
__________________ 2008 F350 4X4 6.4L Lariat Crew Cab Torqueshift, Dark Shadow Grey, Loaded minus the sunroof, Edge Insight, B&W hitch, more soon.............
Thanks for bringing this product to my attention.... I'm probably going to purchase it for my truck..... depending on what their mounting pod looks like and where it mounts. Edge makes a really clean product. I had the BD X-monitor on my last truck.... but it used a dot matrix type screen and after a couple of years.... several of the dots had died out... making the numbers look funny. A product that plugs right into the OBDII port would be great too... no tapping wires, or having to worry about routing wires.
2008, F-250, FX4, Crew Cab, Short Bed, Oxford White w/ black interior, Dual Alternators, Sat. Navigation & Radio, Overhead DVD System, ESOF, Solid Rear Window, 3.73 Limited Slip, Upfitter Switches, Tow Command System w/ Power Scope Mirrors, Power Seats, and the Reverse Aid Sensor - Edge Insight Monitor, 2.5" Donahoe Racing Lift Kit, Fox 2.0" Piggy-Back Shocks, KMC Beadlocks w/ 35" Toyo M/T's, MBRP DPF back exhaust, Recon mirror lights, Fitch Fuel Catalyst, Randy Ellis Design Light Bar, Line-X, MotoBar, Gentex Temp/Direction Mirror
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Dieselgem</div><div class="ubbcode-body">That is a nice product. I wonder if you can use the Ford probes for the EGT's? </div></div>
I sent that same question to Edge Products last night. According to the online manual it sounds like it might use Fords probes, but I will wait for their responce. This is from the online manual.
Ford Specific Parameters
Air
• EGT = Exhaust Gas Temperature
• EGT B1S1 = Exhaust Gas Temperature Bank 1 Sensor 1
• EGT B1S1 = Exhaust Gas Temperature Bank 1 Sensor 2
• EGT B1S2 = Exhaust Gas Temperature Bank 1 Sensor 3
• EGR S1 = Exhaust Gas Recirculation Sensor 1
Thanks for the replies. I have found this product for approx. $280 and the optional EGT probe for $80. Seems like a pretty good deal for what is offered in this package. Any more thoughts or experiences are appreciated. Thanks in advance!!!!!!!!!
Also, what have you guys seen as far as mounting options? I would like something that sits above the dash but below the driver's grab handle(in order to keep from removing it). Look forward to your responses!!!!!!!!!!!!
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: dfuser</div><div class="ubbcode-body">It uses the same mount as the Juice monitor. The probe that comes with it is designed to fit on it perfectly.
The insight plugs into your OBDII connector and monitors jsut about everything your PCM does.
They are very easy to install and work great. </div></div>
