Edge Insight Gauge........any thoughts???????????? - Page 3 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 6.4L Upgrades and Aftermarket - Engine
6.4L Upgrades and Aftermarket - Engine Upgrading or adding OEM or aftermarket equipment to your 2008-Up Super Duty truck with 6.4L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Old 02-22-2008, 12:23 AM   #31 (permalink)
That is correct.... its not a tuner/chip.... its just a guage set. I'm not risking my warranty.
2008, F-250, FX4, Crew Cab, Short Bed, Oxford White w/ black interior, Dual Alternators, Sat. Navigation & Radio, Overhead DVD System, ESOF, Solid Rear Window, 3.73 Limited Slip, Upfitter Switches, Tow Command System w/ Power Scope Mirrors, Power Seats, and the Reverse Aid Sensor - Edge Insight Monitor, 2.5" Donahoe Racing Lift Kit, Fox 2.0" Piggy-Back Shocks, KMC Beadlocks w/ 35" Toyo M/T's, MBRP DPF back exhaust, Recon mirror lights, Fitch Fuel Catalyst, Randy Ellis Design Light Bar, Line-X, MotoBar, Gentex Temp/Direction Mirror
RRose is offline
Old 02-25-2008, 07:44 PM   #32 (permalink)
The info that should have come from Edge. This is the information that can be monitored with the Insight on the 6.4L Powerstroke (specifically). It took me awhile to put this together..... but I figured someone on here could us it when setting up their Insight!
Ford 6.4L Insight Data Points
Temperature
Engine Coolant Temp
Intake Air Temp
Fuel PIDs
Fuel Rail Press Hi
Fuel Level
Gallons Per Hour
Miles Per Gallon
Air PIDs
Manifold ABS Pressure (MAP)
Mass Air Flow
Barometric Pressure
Boost/Vacuum
Spark/Load PIDs
Calculated Load
Time/Distance/Cnt PIDs
# of Trouble Codes
Engine Run Time
MIL on Distance
Warm Up Counts
DST Since Codes Clear
Time Since DTC Clear
Time Run With MIL
Actuator PIDs
CMD EGR Duty Cycle
EGR Error
ABS Pedal Pos D
ABS Pedal Pos E
Edge EGT – Accessory EGT Sensor
Ford Specific
Ford Fuel PIDs
Injector PW
Ford Air PIDs
Exhaust Temp
Exhaust Temp B1S1
Exhaust Temp B1S2
Exhaust Temp B1S3
Boost (g)
IAT Sensor
Ford Actuator PIDs
Accel Pedal Pos
Trans Input Shaft Spd
Regen Status
Ford Sensor PIDs
Engine Oil Temp
Transmission Temp
Diesel Eng. Oil Temp
Trans Out Shaft Spd
TCC Speed Ratio
Torque Converter Slip
Turbine Speed
Hawk Eye Sensor PIDs
RRose is offline
Old 02-27-2008, 04:53 PM   #33 (permalink)
Are the exhaust gas temp readings the equivalent of a pre-turbo " normal gauge"? Has anybody tested this yet...the EDGE website certainly isn't clear on this point?
2008 F350 Crew Cab 6.4 PSD 4X4
Excel 33RSO 5th Wheel M/C Lift on the back
jayhirsch is offline
Old 02-27-2008, 09:14 PM   #34 (permalink)
I had a pre-turbo EGT probe on my 6.0L...... and the numbers I have seen on the EGT monitor look exactly the same on my 6.4L..... I think the highest I got it was 1159..... climbing a hill with no load... foot in it!
RRose is offline
Old 02-27-2008, 09:15 PM   #35 (permalink)
I believe that the factory EGT probes are installed in/near the dpf and are therefore post turbo. I do not know the exact location of the probes but have found that exhaust temp B1S3(see above post) seems to be the most accurate. If you are planning to tune your truck then you probably want something pre-turbo for safety reasons, but for just shut down temps or basic monitoring the factory probes should be adequate.
2008 F350 4X4 6.4L Lariat Crew Cab Torqueshift, Dark Shadow Grey, Loaded minus the sunroof, Edge Insight, B&W hitch, more soon.............
bearsfan1 is offline
Old 02-28-2008, 08:24 AM   #36 (permalink)
It makes sense that Ford would want to know temperature at DPF for regen purposes...but I was hoping for a consistent set of responses to my question. I just put a hypertech econ tuner on my truck....and the power increase was pretty noticible..but I did it for economy. I am just trying to protect myself when pulling hard up hills, towing my 16.5k th wheel. Last summer, I did ok..in stock tune....but of course I never knew if I was close to being too hard on the truck. I would like to go with the Insight..to avoid drilling, tapping etc...
If I make a couple of test runs with the stock setting...and note the highest EGT readings...couldn't I use that as a benchmark for towing with the tuner applied?
Old 02-28-2008, 10:59 AM   #37 (permalink)
Jay..... The Insight has an option to add a regular drill and tap EGT probe. The wiring that goes from the insight to the OBDII port has a input on it for a accessory EGT probe that you get from Edge for about another $75. So..... it still is pretty much the best guage system you can buy!
I'll have to lay under the truck and look around for sensors on the exhaust system. I would swear that the temps shown on my insight have to be preturbo..... because they can get into the 1100's if you are pushing the truck (unloaded)...... usually post turbo temps in this same condition are about 900*.
RRose is offline
Old 02-28-2008, 04:51 PM   #38 (permalink)
The more I think about this..seems like either one would work...the exhaust gas goes into the turbo and right back out...some heat can get absorbed by the turbo..and of course the exhaust has now traveled another couple of feet. So I would expect a lower reading than pre-turbo...but it should be consistent...ie...200 degree's at high temps.....very litle when idling, etc... That said, I have asked a tech at EDGE to go run a test..since they have an 08 in their fleet and send me the results.
Old 02-28-2008, 05:34 PM   #39 (permalink)
what did the tech say about where the factory egt probes were? Are any of the 4, pre-turbo?
RRose is offline
Old 02-29-2008, 08:00 AM   #40 (permalink)
Will it work on an F-550?
dirtdigger69 is offline
Old 02-29-2008, 08:45 AM   #41 (permalink)
He wasn't sure where the probes were...but was willing to go put one on his truck and drive it around and report the readings. With a different model product , hooked up the same way, he had observed temps in the area of 1300 degrees...so he thought he was getting equivalent to "pre-turbo" readings. By the way, a friend of mine who was a Cummins mechanic for 20 years told me that they always put the probe about 6-12 inches below the turbo outlet..on the exhaust pipe. This was on big rigs.
Old 02-29-2008, 10:41 AM   #42 (permalink)
taboky's Avatar
Looking at the 6.4 Bible, on the right up-pipe it shows a EGRT InletSensor. I am assuming it means EGR Temp. Since it is in the up-pipe, as long as we get the right sensor, it should be fine, right? I am very interested in the answer because I want guages for towing and need to keep the grab ahandle for my wife. Insight would be perfect.
'08 F350 Lariat DRW CC LB Job 3 Black/Silver
towing a '07 Raptor 3712TS toyhauler
with a '02 Kawasaki Nomad Dresser in the garage
taboky is offline
Old 02-29-2008, 02:59 PM   #43 (permalink)
From the edge owners manual....I think you have exhaust gas recirculation.....not sure what that will tell us. I am in midst of clarifying this..will post final answers to the forum. Also...to the 550 owner...the edge should work as long as you have same diagnostic port configuration.
Ford Specific Parameters
Air
EGT = Exhaust Gas Temperature
EGT B1S1 = Exhaust Gas Temperature Bank 1 Sensor 1
EGT B1S1 = Exhaust Gas Temperature Bank 1 Sensor 2
EGT B1S2 = Exhaust Gas Temperature Bank 1 Sensor 3
EGR S1 = Exhaust Gas Recirculation Sensor 1
5
Old 02-29-2008, 08:26 PM   #44 (permalink)
guardrail22's Avatar
does it come with a mount?
New Truck
2008 F450 CC Lariat White/Gold, JAD Solutions Lights, 62 Gal Titan, B&W Hitch, Gold Remote Start, TruckTrunk box, Viair 550+2x2.5gal receiver, 2010 NAV and Sync
____________________
2008 Carrilite XTRM5
Traded In Nov 07:
2003 F250 CC LB XLT 4x2 PowerStroke, Captains Chairs, White/Parchment, Torqshift, Heated Mirrors, Trailer hitch,
Delivered 11/27/2002
towing a 2005 Pilgrim 306RL-SS w/Hensly Arrow
guardrail22 is online now
Old 03-01-2008, 07:25 AM   #45 (permalink)
The Insight is Internet updateable and works on the following truck applications:
  • Ford 2003+ all Powerstrokes and 2004+ F-150s
  • Dodge 2006+ Cummins and Hemi trucks
  • Chevy 2006+ Duramax and 2007+ Chevy gas trucks
dfuser is offline
