Edge Insight Gauge........any thoughts???????????? - Page 5 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 6.4L Upgrades and Aftermarket - Engine
6.4L Upgrades and Aftermarket - Engine Upgrading or adding OEM or aftermarket equipment to your 2008-Up Super Duty truck with 6.4L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Old 03-06-2008, 06:28 PM   #61 (permalink)
I copied your post from the other forum and also sent it to EDGE. Lets see if we both get the same answer!
2008 F350 Crew Cab 6.4 PSD 4X4
Excel 33RSO 5th Wheel M/C Lift on the back
jayhirsch is offline
Old 03-06-2008, 11:08 PM   #62 (permalink)
taboky's Avatar
Guy on another site just replied that he has the Insight and an Autometer pyro, and they are reading about 40 degrees apart. Close enough for me.
'08 F350 Lariat DRW CC LB Job 3 Black/Silver
towing a '07 Raptor 3712TS toyhauler
with a '02 Kawasaki Nomad Dresser in the garage
taboky is offline
Old 03-07-2008, 10:23 AM   #63 (permalink)
also a confirming post from a tech who just replaced one. Looks like a consensus...I plan to order one....have about analyzed this to death!!!!
Old 03-07-2008, 07:05 PM   #64 (permalink)
I have monitoring a few other forums...a guy has just reported in...that has both an Insight and a Autometer ( conventional gauge) installed. INSIGHT reads 40 degrees lower than Autometer...all the way thru the range. He feels INSIGHT may be closer to correct. In any event..40 degrees is close enough for me!!!
Old 03-07-2008, 07:29 PM   #65 (permalink)
Yes , the insight in my unit is within 40 degrees of me autmeter gauge. Insight is lower throughout the range. Very happy with the insight. Can monitor anything I want.
2008 F350 CC, LB, Dually, 6.4, Auto, 4.10LS, Lariet, Moonroof, Pueblo Gold/Black, Chrome steps, plus the rest of the goodies.
WhiteKnight is offline
Old 03-09-2008, 02:48 PM   #66 (permalink)
guardrail22's Avatar
set EGT warning at 1250F and the regens from towing the new 5ER set it off
New Truck
2008 F450 CC Lariat White/Gold, JAD Solutions Lights, 62 Gal Titan, B&W Hitch, Gold Remote Start, TruckTrunk box, Viair 550+2x2.5gal receiver, 2010 NAV and Sync
____________________
2008 Carrilite XTRM5
Traded In Nov 07:
2003 F250 CC LB XLT 4x2 PowerStroke, Captains Chairs, White/Parchment, Torqshift, Heated Mirrors, Trailer hitch,
Delivered 11/27/2002
towing a 2005 Pilgrim 306RL-SS w/Hensly Arrow
guardrail22 is offline
Old 03-09-2008, 04:58 PM   #67 (permalink)
So do I conclude that EGT's go up when the regen hits? I only noticed a regen 1 time last year...while going up a steep hill..seemed like boost was limited to about 20 ish lbs...and my speed dropped a little..so I assumed it was in Regen...I just kept going..just a little slower! Any other regens either happened at idle..the high idle etc.... or at speed where I didn't notice it. Hw much did you have to back off to get egt's back under 1200 degrees?
Old 03-12-2008, 10:42 PM   #68 (permalink)
bdnowel's Avatar
I am going to order the Insight tomarrow. Is it easy to program? And I do not need the egt probe I can use the facory one if I read it righ in this forum.
bdnowel is offline
Old 03-13-2008, 12:11 PM   #69 (permalink)
You read it right. No need for the extra probe. Just select Ford settings and you'll have what you want.
2008 SD 250 PSD King Ranch 4X4, SWB, CC, Auto 3.73
Viper 791 XV alarm with remote start. FS2500 bypass filter. Edge Insight multi gauge. Line-X. Retrax.
Sequoia is offline
Old 03-14-2008, 07:27 PM   #70 (permalink)
I have one coming as well. Appears that the EGRT ( exhaust gas recirculation sensor) is the one that is mounted pre-turbo and will actually give pre-turbo egt readings. Will know in a few days..but I believe others have discovered this to be true.
Old 03-14-2008, 11:13 PM   #71 (permalink)
bdnowel's Avatar
I just got mine installed and it has the EGT,Boost,Trans and ECT on the display. I can find the other sensors that were mentioned earlier. I went for a ride and the egts went as high as 1000 and thats it. Any other info on this thing would be cool. The book is VERY vague.
bdnowel is offline
Old 03-14-2008, 11:23 PM   #72 (permalink)
Sprinks542's Avatar
Where are you guys ordering this unit from? New to the diesel world and have been reading up on this monitoring system. I want to get one as soon as possible.
2008 F-350 Lariat PSD.
2010 Fuzion 322 TE II Toy Hauler
07 Can-Am 800 xt
08 Can-Am 500 Renegade
Sprinks542 is offline
Old 03-14-2008, 11:26 PM   #73 (permalink)
Truckaddons.com was the cheapest when I ordered mine. I paid about $280 and that included shipping.....
2008 F350 4X4 6.4L Lariat Crew Cab Torqueshift, Dark Shadow Grey, Loaded minus the sunroof, Edge Insight, B&W hitch, more soon.............
bearsfan1 is offline
Old 03-14-2008, 11:28 PM   #74 (permalink)
bdnowel's Avatar
I paid 300 for mine and got t in one day.
bdnowel is offline
Old 03-14-2008, 11:51 PM   #75 (permalink)
im about to order my edge...probably from truck addons as i have a small gift certificate....
is everyone happy that has one??????
stunya is offline
