Edge Insight Gauge........any thoughts???????????? - Page 7 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 6.4L Upgrades and Aftermarket - Engine
6.4L Upgrades and Aftermarket - Engine Upgrading or adding OEM or aftermarket equipment to your 2008-Up Super Duty truck with 6.4L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Old 10-12-2008, 03:56 AM   #91 (permalink)
1/2tired's Avatar
Thumbs up Edge Products
I have the Edge Evolution and have been very happy with the ease of use with the product! It monitors everything I ask, just by plugging into the ODB II port... Reads as No Drilling Required!!! The dash pod mount is a very close color match to the gray portions of the dash, so it is a completely clean install. It will also compensate for oversize tires, but the true speed will only be monitored on the Edge unit. 4 programmable control schemes, as well as custom programming available for the serious performance people!!! I have noticed a definite improvement in the fuel milage while towing, noting an increase from 11.1 to 11.6 mpg. I hope the performance continues to go so well!!!
2008 F-350 4 X 4 Crew Cab, Long Bed, SWB, Lariat
6.4 Liter Power Stroke that I traded up to!!!
Edge Evolution, Rhino Lining, Snug Top, 3.5 " Tube steps
1/2tired is offline
Old 12-02-2009, 11:25 AM   #92 (permalink)
Y'all talked me into it! I just ordered one today with the dash pod. One question I didn't see answered here though...what powers the thing? Does it run on batteries or is it powered from plugging it into the OMBD port?
2008 Supercab XLT - Stock
taquilatab is offline
Old 12-02-2009, 12:43 PM   #93 (permalink)
jsmichael's Avatar
No batteries - like you said, the power comes via the Onboard Diagnostics port.
Make sure you register the unit with Edge Products so that you can deal with their Customer Service if you need to. Also, you'll want to install the Fusion and Insight software and then pull down the latest updates for the unit's firmware.
'08 F-350 XLT (Job 3) 4X4 6.4L PSD CC SRW LB, Line-X bedliner, UWS toolbox, Goodyear Wranglers (Silent Armor), Marathon seat covers, Edge Insight
jsmichael is offline
Old 02-28-2010, 02:39 PM   #94 (permalink)
Edge Insight with SCT Tunes
Fellas,
I am very interested in purchasing the Edge insight & EGT probe. My set up will consist of using SCT tunes and the edge insight as my monitor/gauge. I currently have the Edge Juice/Attitude. Couple questions:
1. Can i resuse the EGT probe from the juice module or would I have to use the Insight's probe? If so, is the hole the same size? It would be nice to not have to punch any more holes.
2. MOST IMPORTANTLY, I want to be able to monitor my temps independient of what the PCM is telling the insight. Is this possible? Or do i have to use ugly analog gauges? I read on another post that the Insight comes with a "black Box'' like the juice/attitude module. I assume this would only come with the insight if you order the EGT probe. I guess this is a converter for the input from the probe.
Any input on this would be greatly appreciated!! Oh yea, the edge attitude/juice is for sell
Jayybird is offline
Old 02-28-2010, 04:31 PM   #95 (permalink)
mattebury's Avatar
I had the Insight, got really poor customer service, so I returned it.
Edge Insight on 09' SD
2008 6.4L F350 King Ranch, Crew Cab, Long Box, 4X4, Dual Rear Wheels, 4.10 rear-end, Job 1 (built Jan 2007)
mattebury is offline
Old 03-15-2010, 07:25 PM   #96 (permalink)
Someone said that you have to unplug the unit everytime you shut dow and plug it back in when you start. Is this true? Because I would think that would be kinda painful.
xatten is offline
Old 03-16-2010, 07:49 AM   #97 (permalink)
CAMPINGTOM's Avatar
When you shut the truck off, the Insight shuts off. You do not have to unplug it.
I have had great customer service from Edge. They answer their phone and they respond to emails. The one problem I had was resolved quickly.
2005 F-250 6.0
4" Straight Pipe, CCV Reroute, Coolant Filter, EGR Delete, Insight Monitor, SCT X3 (Tuned by Innovative)
Stock head bolts, injectors and turbo
CAMPINGTOM is offline
Old 03-16-2010, 12:35 PM   #98 (permalink)
gypsybill's Avatar
My Photos: (13)
My story: The first time I plug the Insight in the ODB port it comes up fine. When I shut the truck off and exit the truck, when returning to the truck and starting the engine, the Insight will not start UNLESS I unplug the Insight and plug it back in. I have talked to Insight several times, they have sent me a new unit, updated the software and finally admitted they had no resolution for the problem. Others here have had the same problem with their 09s with no resolution. I like the gauge and put up with this but I have given up talking to Edge. They have always been helpful as far as they can, but just don't have a solution (or at least they didnt when I finally gave up). I may revisit the problem and contact Edge again or I may just try another companies product. YMMV.
Bill
2009 F450 Lariat 4X2, Sterling Grey over Black
ReTrax Tonneau, AirSafe 25k 5th Wheel Hitch
2010 DRV MS 36RSSB3
gypsybill is offline
Old 03-17-2010, 01:13 PM   #99 (permalink)
My truck is a 2009. I believe I'll pass on this until they figure it out. I can't imagine having to unplug and plug in every time I start the thing.
xatten is offline
Old 03-17-2010, 11:27 PM   #100 (permalink)
Same problem with mine. They said they are not planning on fixing it since they are replacing the insight. This was last week when I was told that.
RIP 2001 F250 PS SuperDuty
2009 Ford F250 PS SuperDuty
BozoWise is offline
Old 04-27-2010, 12:16 PM   #101 (permalink)
Superduty123's Avatar
Wont this void the warranty on my 6.0 if I tap in a prob?
Superduty123 is offline
Old 04-27-2010, 07:21 PM   #102 (permalink)
DSTRBD's Avatar
Feedback Score: 3 reviews
No, it wont.
Performance Truck Products
Call 888-516-4644 or Chat Live On Our Site
DSTRBD is offline
