Edge juice question - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 6.4L Upgrades and Aftermarket - Engine
6.4L Upgrades and Aftermarket - Engine Upgrading or adding OEM or aftermarket equipment to your 2008-Up Super Duty truck with 6.4L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Old 03-15-2009, 09:41 AM   #1 (permalink)
sawtooth's Avatar
Edge juice question
I was reading about the Juice and it mentions a turbo timer feature. Can someone tell me how it works? Does it shut down the truck after so much time has passed?
Thanks,
2008 Job 3 6.4 F250 Lariat CC 4x4 Dark Stone
ATS Color Matched Street Flares
Eaton ELocker "front" and Truetrac Limited Slip "rear"
sawtooth is offline
Old 03-16-2009, 08:32 PM   #2 (permalink)
scscrew's Avatar
Sawtooth,
I have the Edge Juice on my 08 but have not turned on the turbo timer. However, it works off of either EGTs or a set time. You can go into the Attitude monitor and set the EGT to something like 350 degrees (or whatever you want to set it at) and your truck will not shut off until the temp drops below the set temp. You can also specify a time period such as 1 minute or so. I hope this is what you are looking for. Let me know if you have any other questions.
2008 F-250 CC SB Lariat 4x4 6.4 PSD Job 2
Torreador Red/Pueblo Gold with Tan leather
305/65/18 BFG A/Ts, Bilstein HD shocks, Edge Juice w/Attitude, Line-X, DVD
scscrew is offline
Old 03-16-2009, 09:25 PM   #3 (permalink)
sawtooth's Avatar
Thanks for the info. So do you turn the key off and pull it when you leave the truck? Also, does the juice help with the turbo lag from a stand still?
thanks,
sawtooth is offline
Old 03-17-2009, 08:04 PM   #4 (permalink)
scscrew's Avatar
It is my understanding that when you get to your destination you turn the ignition switch off and remove the key like you always do but the engine remains running until it reaches the preset time/EGT. I have noticed a slight decrease in turbo lag. There is still some lag if you try to floor it from a dead stop but if you gradually roll into the throttle it takes off nicely.
scscrew is offline
Old 03-18-2009, 06:37 PM   #5 (permalink)
Do you have to drill in the EGT Probe for the Juice to display EGT's or does it read it anywhere else?
2008 F250 FX4,CC,SB,6.4L Auto, 3.55, 4x4
2003 F250 Crew Cab Shortbox Sport, 6.0L, TorqShift, 3.73, 4x4 Sold 102K
CowFarmer is offline
Old 03-18-2009, 07:41 PM   #6 (permalink)
No you do not have to drill. There are 4 EGT sensors on the truck already. The Juice knows which one to read for pre turbo.
I have a Juice W/att forsale for the 08 if anyone is interested
2008 F-350 King Ranch 4X4, job build 3, tuned by Spartan
RIP: 95 F-350 Powerstroke, 4X4, 5 Spd, Crew Cab,Long Bed, 4" Superlift on 35" BFG All-Terrain, Diesel Innovations 4 Bank chip, 4" exhaust, DIY Tymar, Ranch Hand repalcement bumpers
2004.5 Cummins 600, 2500 Larimie, 4X4, LWB, 48RE, Full billet DTT, FASS fuel system, TST, SMARTY, Flux 3 injectors, Helix cam, Di-Procol (Boost, EGT, Trans, Rail, Fuel), AFE PG7 stage 1, JL Stealth box, Donaldson, 315 BFGs. (893 on fuel )
2005 Chevy 2500 Duramax, Diablo tuner, PYRO.
powerstrokin03 is offline
