Exhaust Brake for 6.4L - Page 3 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 6.4L Upgrades and Aftermarket - Engine
6.4L Upgrades and Aftermarket - Engine Upgrading or adding OEM or aftermarket equipment to your 2008-Up Super Duty truck with 6.4L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Old 07-09-2009, 10:52 AM   #31 (permalink)
Originally Posted by bankspower View Post
The factory tow/haul setting works almost exactly the same way it does on the chevy. Blade position is brought down to a set point but it generates very little back pressure on the engine. In fact our testing on the stock setup was a mirrior image of the chevy run posted above.
On Edit: There's also a big warning on the Banks Speed Brake brake to NOT use it on the high strength setting with little or no load. It will nearly lock the tires up.
So then it is a turbo assisted braking deal and not variable valve timing then? Hmm, I learned something new today...it was a good day!
91 4runner. 1 ton locked and 40's
2008 F350 SD FX4
6.4TT
20" Jessie James 1 off rims
35" rubber
4" procomp lift
wontonrunner is offline
Old 07-09-2009, 11:17 PM   #32 (permalink)
smotrs's Avatar
My Photos: (16)
Shaun
'08 F250 6.4L Lariat 4x4 CC/SRW fully loaded, special ordered
6" Fabtech 2.25 dual shock lift w/18" AR wheels, 35" Toyo AT
Avic-Z2 (Z3 Mod) Nav/Stereo w/iPod, Bluetooth, XM NavTraffic
(2) Rear headrest mnt DVD entertainment systems
Line-X bedliner
Banks CAI, Dual Exhaust, 6-Gun, Speed Brake & iQ (test vehicle)
Bushwacker Fender Flares (color matched)
Ravelco Anti Theft Device
Originally Posted by George Bush
Wait, what did you just say? You're predicting $4 a gallon gasoline?. . . That's interesting. I hadn't heard that.
smotrs is offline
Old 07-10-2009, 11:28 AM   #33 (permalink)
bankspower's Avatar
Originally Posted by smotrs View Post
Hey smotrs, do you do any towing?
bankspower is offline
Old 07-10-2009, 08:16 PM   #34 (permalink)
smotrs's Avatar
My Photos: (16)
Jeff, 21' Bass boat, tandem axle fully loaded and a smaller toy hauler when hauling the dirt bikes and camping for the weekend. One of these days I need to get both weighed so I know exactly how much I'm towing.
Shaun
Line-X bedliner
smotrs is offline
Old 07-12-2009, 11:52 PM   #35 (permalink)
line3500's Avatar
Hey banks, don't know if its been asked before, but why no speed brake for the 6.0's? thanks.
Alex Strand
2010 F350 6.4 DRW 4x4 FX4. Lariat ultimate package, homelink, 3.73 limited slip, line-x bedliner. white platinum metallic tri coat with 2 tone adobe and camel leather interior. Born on date: 09/2009 Delivered 5/27/10 with 43 miles
Currently 76K on the clock as of may 11'
Mods:
*Scan Gauge II
*CAT/DPF stock exhaust
*Recon cab, mirror, and fender lights
*High idle Mod
*20K Curt 5th wheel
*100 gallon aluminum flush mount fuel tank with direct fill into factory tank.
*Flush mount tool box
*Tinted windows
*Airlift bags on rear with compressor and 2.5 gal tank
Traded 2006 F350 SRW 6.0 Lariat, Loaded
*15K Reese 5th wheel
*110 gallon fuel tank w/ 18gpm pump
*high idle
*banks 4" dual monster exhaust.
*Ford OEM navigation 6CD audiophile radio.
*Dieselsite coolant filter.
American by birth, Teamster by the grace of God!
Teamsters local 399.
line3500 is offline
Old 07-13-2009, 11:33 AM   #36 (permalink)
bankspower's Avatar
You'll be hearing from us shortly
We are putting the finishing touches on one now, and it's going to be realesed at almost the same time as the 6.4L The function on both will be exactly the same. No welding, no wire splicing, no cutting. Just plug and play.
Old 07-15-2009, 01:20 PM   #37 (permalink)
I am interested just dont know how well it will work with aftermarket ecm tuning.
2008 F-350 King Ranch 4X4, job build 3, tuned by Spartan
RIP: 95 F-350 Powerstroke, 4X4, 5 Spd, Crew Cab,Long Bed, 4" Superlift on 35" BFG All-Terrain, Diesel Innovations 4 Bank chip, 4" exhaust, DIY Tymar, Ranch Hand repalcement bumpers
2004.5 Cummins 600, 2500 Larimie, 4X4, LWB, 48RE, Full billet DTT, FASS fuel system, TST, SMARTY, Flux 3 injectors, Helix cam, Di-Procol (Boost, EGT, Trans, Rail, Fuel), AFE PG7 stage 1, JL Stealth box, Donaldson, 315 BFGs. (893 on fuel )
2005 Chevy 2500 Duramax, Diablo tuner, PYRO.
powerstrokin03 is offline
Old 07-15-2009, 02:34 PM   #38 (permalink)
bankspower's Avatar
The brake is independant of the ECM so it will work with any programmer out there. It may NOT work if you have something plugged into the OBDII port like and edge insight however.
Old 07-15-2009, 03:17 PM   #39 (permalink)
senix's Avatar
exhaust brake
I too am interested in this. I pull loads up to 10K
senix is online now
Old 07-15-2009, 04:07 PM   #40 (permalink)
Welp edge insight is what i use for gauges so im out!
Old 07-15-2009, 05:30 PM   #41 (permalink)
bankspower's Avatar
The system will come with our display so you can use it instead. The two won't work at the same time though. So it's 1 or the other.
Old 07-16-2009, 02:30 AM   #42 (permalink)
i like yalls stuff, but i love my edge mount with the insight and wont replace it
Old 08-07-2009, 06:04 PM   #43 (permalink)
bankspower's Avatar
Anybody local in the SoCal area care to try one out?
If your interested PM me your phone number as there are a few requirments. You MUST be local to us.
Old 08-08-2009, 08:53 PM   #44 (permalink)
senix's Avatar
oh i wish i was there now...but you can ship it to md
08F250 CC 6.4 PSD
Banks 6 gun/ram air
40' Stoneridge 5th wheel, coming in at 14K.
senix is online now
Old 08-31-2009, 08:58 PM   #45 (permalink)
ANY news about the speedbrake for the 6.4? when will it be available?? how much??
renegade600sdi is offline
