6.4L Upgrades and Aftermarket - EngineUpgrading or adding OEM or aftermarket equipment to your 2008-Up Super Duty truck with 6.4L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Jeff, cool, so the Foot mode is kinda what I described above like a trailer On/Off mode, making it act more like a manual trans downshift scenario?
I'm actually off this whole week housing hunting. So if you need my truck sooner, let me know. I go back to work on Monday the 2nd.
Exactly, though your brake sounds like it's still on the "high" mode as far as it's aggressivness. Try turning in down to "med" when you are empty as see if that works better
Jeff, I thought the whole High, Med, Low settings were only the Brake On mode, not Speed Control mode? Does the High, Med, Low setting on the Brake On mode affect the Speed Control mode as well?
Shaun
'08 F250 6.4L Lariat 4x4 CC/SRW fully loaded, special ordered
6" Fabtech 2.25 dual shock lift w/18" AR wheels, 35" Toyo AT
Avic-Z2 (Z3 Mod) Nav/Stereo w/iPod, Bluetooth, XM NavTraffic
(2) Rear headrest mnt DVD entertainment systems
Line-X bedliner
Banks CAI, Dual Exhaust, 6-Gun, Speed Brake & iQ (test vehicle)
Bushwacker Fender Flares (color matched)
Ravelco Anti Theft Device
Originally Posted by George Bush
Wait, what did you just say? You're predicting $4 a gallon gasoline?. . . That's interesting. I hadn't heard that.
Yes it does. On the iQ you can change it at will, the PDA makes you dig for it. turn it down and try it out
Jeff, Will do, I thought because it was on that particular screen that it only affected that mode. Will turn it down and give an update later on how that works.
Shaun
Line-X bedliner
2010 F-450 King Ranch (loaded)
Alpenlite Portofino RL36
Reese 24K Sig Series fifthwheel hitch
Reese 30K Sig Series gooseneck hitch
Aerotank 65 gallon tool/tank box ( on timer)
Eclipse AVN726E Nav
Ok, drove around today, mind you, I haven't hooked up the trailer yet as I wanted to drive in similar conditions as yesterday. Before going anywhere, I switched back over to Brake On mode and verified the brake was set on High then switched back to Speed Control mode and adjusted the preset speed to 35mph. Then I proceeded to drive around a bit so I had something to compare against. Just like yesterday, definitely too aggressive for everyday driving. Soon as you let off on the accelerator, it drops quickly into Tow-Haul mode then jumps quickly into 3rd gear to slow you down to the preset speed. As it nears the preset speed it goes back to 4th gear and then goes through the normal downshift procedure as long as your foot is off the accelerator.
So, after a while of being thrown into the seat belt. I pulled over and switched back to Brake On mode to change the setting to Low then switched back over to the Speed Control mode before hitting the road again. Drove around about 45mph again and this time when I let off on the pedal, just like before it drops quickly to tow-haul mode, but it appeared to wait a little longer for the RPM's to drop before doing the 3rd gear downshift. So I wasn't quite thrown against the seat belt as aggressively as when it was on High. Still a bit more aggressive then you would like for an unladen truck, but add a small trailer or small boat to the back and you may not even notice it as much.
Jeff, so on the Foot On setting, it would be even less aggressive then the Low setting I just described?
Shaun
Line-X bedliner
Did you ave a chance to try the settings we spoke about on the phone yet?
Ok, did some more testing this last week regarding the Low, Med and High settings in both Brake On and Speed Control mode.
Speed Control
Started at a speed of about 50 MPH with the setting on High and a Speed Control set at 20 MPH. When you let off on the accelerator the system immediately drops to Tow Haul and 4th gear, almost right after that it drops into 3rd and shortly after 2nd gear. Mind you, the vehicle is still about 40+ MPH so if you don't have a trailer you'll probably have a bruise on your shoulder where the seat belt was. Med and Low were progressively less aggressive but even in the Low setting it would still drop to 2nd while you were around 35+ MPH or so.
Now mind you, I would have probably had the Speed Control set at 45 typically for that MPH. There's no reason for it being set that low when your average speed is that high. But I wanted to see how aggressive the brake was compared to the Brake On mode.
Brake On
Similar to above, started at a speed of about 50 MPH with the setting on High. Very similar to the Speed Control method above, when you let off the accelerator the system immediately drops to Tow Haul and 4th gear. Shortly after it drops to 3rd gear followed by 2nd gear. Again, speed was still about 40+ but I think it was a bit lower then what it was during the Speed Control test. Kinda hard to tell.
The Med and Low settings were definitely lower though as the Med setting was in the lower 30's before dropping to 2nd gear and the Low setting actually waited until the vehicle was in the higher 20s (around 28 I think) before dropping to 2nd gear, but much more controlled
Brake Off
Lastly, I tried with the Brake turned off to see how the truck would normally act through the downshifting. Mind you, with the brake off, it doesn't use the Tow Haul mode to slow down.
So I'm cruising about 50 MPH, and let off the accelerator. Vehicle begins coasting and gradually goes down through the gears. Didn't get it to drop to 2nd until I started applying the brakes when approaching stop lights but when I glanced at the PDA to see what the speed was it read about 25 or so I think.
Observations
Would have been much easier if there was a way to log the test, then I could have had more accurate results. Oh well. In any case, it appears that the Brake On mode with a setting of Low will give you the closest comparison to how the truck would normally slow down and go through the gears. Mind you, that's the setting I have since left it on for normal driving.
I have also noticed that when you are on a road that has a VERY slight grade, it's best to just turn it off as it will constantly be going in and out of Tow Haul due to even the slightest moderation of your foot on the accelerator to maintain whatever speed your traveling. I'm sure everyone has come across those roads where you kinda hover on the pedal because if you press it you go to fast and due to normal road friction you slow down to much. So you have to hover on the pedal to control the speed. Well, when that happens, it constantly feels like the truck is surging as it goes in and out of Tow Haul mode.
Again, these tests have been done on an unloaded truck doing normal street driving and/or freeway driving.
Shaun
Line-X bedliner
Jeff, When should I come in for the SB update? Dwayne had mentioned that they weren't satisfied with how it performed when they first installed and were writing and update for it.
Shaun
Line-X bedliner
Come on by next monday (the 7th) and we can flash your update and get you an iQ Make sure you give a call to Jeff C in tech.
Ok, so I've been playing around with the iQ for the last 2 weeks and I really gotta say I like it. Though the thing is huge and there's no real good place to put it, the fact that everything is right there at a fingers touch out weighs the size. Definitely very user friendly and feature packed.
Pros
The little Brake Pedal icon definitely makes driving around with the Speed Brake more enjoyable on an unladen truck. When the Break Pedal option is enabled, it will not engage the Speed Brake until you physically touch the Brake Pedal. As long as the Brake Pedal is engaged, the Speed Brake is engaged. Soon as you remove your foot from the pedal, the Speed Brake disengages.
The big display allows you to press and get the desired result on anything you want while driving or parked. Definitely no need for a stylus, though it does come with one.
Switching between Speed Brake and Six-Gun functionality is super easy even when driving down a bumpy road.
Customizing the screen displays is really easy and intuitive. Allows for quite a bit of choices.
Screen is bright and clear whether daytime or night. All gauges and readings are easy to see and view regardless of the angle or time of day.
Cons
Thing is freaking huge. hard to find a good place to mount it without causing a blind spot on the wind shield.
The USB cable could have been a little more low-profile. The plug itself sticks out about an inch from the side of the unit. This limits tucking the unit into the corner by the windshield.
Gets real hot. A drive of about an hour gets the unit very hot almost uncomfortably hot while holding in your hands.
Have noticed a few times that the display kinda goes all wonky, kinda like a degauss but stays in the degauss state with no functionality. Have to turn off and turn back on to clear it. Kind of a pain when cruising down the freeway at 65-70.
If I could make some changes
The addition of a gear gauge permanently embedded on analog or digital screens. Even if it was just a circle shaped like a gear with the number in the center. doesn't have to be huge, about the size of the foot pedal symbol. Just some indication other then having to remove a current display to show it.
A method for going back to the default colors on the gauges. was playing around with changing the color and found out that there is no white option. Resetting the gauges doesn't reset the colors.
An option to integrate into an aux input on my Avic-Z2 navigation system. Would be nice to plug it into the Aux input of my stereo similar to the way I have integrated my BlueTooth and iPod and have the display show up on the navigation system. Then I could lock the iQ in the glove box or center counsel. I would definitely pay for the adapter module that would allow this. Something like this.
A low profile USB cable would have been nice. Would have allowed for better mounting capability in the windshield near the handle. but the Cable provided takes up about an inch of space that could have allowed you to tuck it into the corner better.
Overall though, as I mentioned, I like it.
Shaun
Line-X bedliner
