6.4L Upgrades and Aftermarket - EngineUpgrading or adding OEM or aftermarket equipment to your 2008-Up Super Duty truck with 6.4L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
I recently installed a Cold Air Intake in my truck and I instantlly got an Engine Warning light come on. It went off after a day or so. However, then I started to get puffs of Grey Smoke around town after acceleration. The light then came back on.
I took the Cold Air Intake off and it all went back to normal.
Any Comments? Now im stuck with a 1 week old $400 Cold air intake. It sounded pretty cool installed and added some spunk down low.
I have read your posts on the DP switch but that is not consistent with this problem. Logic tells me that its and air fuel ratio issue and that if i waste/spend another $500 on a programmer maybe this will go away.
My primary reason for installation was for better MPG and for towing my 10,000 pound toy hauler.
Here we go. Don't mean to sound like an ass but modding this truck is asking for trouble.
2003 350 Lariat FX4 Short Box 6.0L *SOLD*
2008 FX4 F350 6.4L Dually Long Box, Black on Black PICTURES
2007 Keystone Raptor 3712TS PICTURES
I would certainly put the stock air assembly back on. I just do not see any reason for replacing the very good Donaldson air filter assembly. I can only guess that if a turbocharger on one of these 6.4 suffered blade erosion from dirty air, what the replacement cost would be. $400.00 for a aftermarket air filter assembly?
2008 F-450 Lariat Dark Stone Metallic over Pueblo Gold 4x4(manual shift transfer case, manual hubs), High capacity tow 4:88s, Off Road, Camper packages, Sirius Sat, Upfitter switches, DVD entertainment, tailgate step, traction control, Audiophile 6-disc, PTC Supplemental heat and heated seats(warm buns), rear sensors, traction control, tailgate step. Built May 8, delivered May 24
Reese Signature Series 24k fiver hitch, I installed it myself, best hitch I have found yet
Line-X bedliner, heavy duty floor mats
2003 Sunline F281SR(weekend getaways)
Sea Ray 240 Sundeck http://community.webshots.com/user/C...host=community
Why would you mod an 08 when they havn't been out long enough to know how or what they will do stock ? Those intake salesmen must be very good at their jobs.It doesn'r surprise me that they have stuff out so that guys can mod an 08.
Live and learn
Hopefully it doesn't cost you to much this time.
O5 F-250 SuperDuty CC SWR 4x4 Lariat
8' box 6.0 PSD Tow Comand new 04/05
2001 40' Alfa Toyhouse
Pulls better stock than my 01 with a programmer
New engine at 42k . Hope my luck with this 6.0 is changed .
Yeah, give me a Clean Air Intake over a Cold Air Intake any day of the week...
Duncan
The 1997 F250HD Crewcab: Picture
The 2000 XLT Excursion <font color="red">(SOLD)</font>: Picture
The 2003 F250 Crewcab 6.0L: Web page
The 6.0L Bible: Web page
The 6.4L Bible: Web page
You don't want to know what a replacement turbo assembly is worth. Just estimating my mechanic was throwing the $4,000.00 number out.
First step would be to try to scan for the codes that set the check engine light, then return the intake to stock to see if it happens again. I'm not sure if these motors have a mass air flow sensor to sense the increased airflow coming in. The 7.3's did not.
I don't think any of the tuners out right now have a compensation for different air intakes.
Black/black leather 2008 F250 FX4 - work in progress - 20" KMC Hotwheels d-back in black, RDS 60gal aux. tank/toolbox Gallery
Black 2002 7.3 Excursion (sold) - 103k and lots of mods, great truck!
Many of these "Cold Air Intakes" I've seen are really hot air intakes that take hot air from under the hood, I just don't understand why anyone would purchase them. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
I don't have an 08, i have an 05, but the ONLY mod i have done to mine is DieselKleen fuel additive. I would suggest this mod or no mod, but thats just me. [img]/ubbthreads/images/graemlins/grin.gif[/img]
This is part of a thread from another forum that seems to be similar...
"6.4 PSD Does not like changes
The check engine light came on in my truck so i took it down to have it checked out. Dealer said i had 42 codes regarding the mass air flow and the regen system. Dealer said it was caused by my AFE intake, and my MBRP cat back exhaust i had installed.
My service rep said that the AFE was causing to much air flow, and the resanator i removed on the exhaust was causing the computer to not see enough back pressure. He said mine was one of many he had seen. Anyways, he told me the computer is to sensitive for any changes and to put it back to stock or i would continue to have problems."
__________________ '04 F-250 Harley-Davidson 6.0L CC SB
What he could have told you was,The threshold for DPF backpressure could be reset,and you wouldn't have anymore problems!I had similiar problems.I took it to my MOD friendly dealer,and the tech did a manual regen,and reset the dpf backpressure threshold.Haven't had a problem since!I put over 12,000 miles on now with a Magnaflow exhaust and Airaid intake [img]/ubbthreads/images/graemlins/wink.gif[/img]
sounds like the maf sensor is not hooked up right ! either air is getting unregistered of the little gasket that goes between the maf sensor and the new tubing has been not replaced or replaced incorrectly. make sure you go back over the entire install and see if anything is out of place.
Thanks. AFE sent me a new intake and i reinstalled it yesterday. i double checked the install and put it back together again.
After driving it for the day it has started smoking again and now the mpg is 6.4 under light throttle around town. power seems good but its now making a gurgling sound after i let off the throttle, like a rubbing sound.
im going to take it to oc diesel in the morning and see what they say. otherwise im throwing hte air intake in the garbage.
i have the dry intake stage 2 from AFE and an MBRP dual exhaust on my 6.4. the exhaust didnt do a dam thing but the intake did. I can hear it while im running and the truck just seems let restricted. No problems or codes after a few thousand miles so far. LOVE IT!
2008 Blue and Silver F450 with 4.88's - Current
2008 F250 White and Gold 6.4, 4.5 DR lift, 22in XD rims, 35in Toyos - sold
2005 f150 FX4 Black SuperCrew - Sold
2003 F250 5.4l CC Blue and slvr - Sold
2002 F250 5.4l EC Blue and slvr - Sold
Thanks for the input. Can or are you allowed to give me the name and number of the guy so i can pick his brain. I went to the local "expert" and he had no clue. he even had a issues opening the hood of my truck.
