high idle issues with sct livewire + dpf delete - Diesel Forum - TheDieselStop.com
6.4L Upgrades and Aftermarket - Engine Upgrading or adding OEM or aftermarket equipment to your 2008-Up Super Duty truck with 6.4L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
post #1 of 9 (permalink) Old 11-17-2011, 07:31 PM Thread Starter
I just did a dpf delete and got the latest livewire 9625OR tuner. Before I got it, the sales guy mentioned it could have idleing issues using a canned tune if I deleted the EGT sensors. Since I was just planning on running the canned tunes I bought the dpf exhause that has the sensor bungs. Got everything installed and it idles high. Tried different tunes and the same problem. Called SCT and the tech guy wasn't much help other than to say the pcm uses imput from the egt sensors for idle speed. He couldn't explain why it was idling high if they were installed. I double checked in the tuner that I did NOT select egt sensors deleted. The truck was running fine with the dpf in place, no check engine lights, etc.. What I did find upon monitoring all the EGT sensors was that the 3rd sensor was reading super high compaired to all the others, 1400 degrees while the others were around 250. I was thinking this could be the problem... I unplugged that sensor just to see what would happen and the tuner is still showing it reading 1400 degrees with it unplugged! Could there be a wiring short somwhere? Or the other possibility I thought of was the pcm reading a max temp like 1400 if the circuit is open like being unplugged, and possibly the sensor is just totally bad? I didn't bend it all up or smash it getting it out...
any suggestions would be great, the high idle thing is pretty annoying at stoplights and parking lots!
Jason
2002 F250 Powerstroke Crew Cab Lariat 4wd auto, Bone stock for now...
Wife's truck:
'00 Excursion Limited, 4" turbo back, Dura-Lite filter/intake, 20% tint all around.. The highway cruiser!
jd99psd is offline
post #2 of 9 (permalink) Old 11-23-2011, 07:07 PM
dude i have the same thing going on with my 08 with an sct livewire canned tunes with the dpf delete and no sensors in the exhaust at all i would love to know whats wrong too it idles at about 950-975 rpms
some one help us in here
timfrayko9185 is offline
post #3 of 9 (permalink) Old 11-29-2011, 09:59 AM
You have to plug the egt sensors back in and do not turn them off, if you left the sensors in then one or all of them are broken, they break very easy
PaulBoss is offline
post #4 of 9 (permalink) Old 11-30-2011, 08:02 AM
you have to keep the one thats furthest towards the back plugged in.. happened to me when i did mine.. i couldn't get the sensor out of the stock pipe.. found a new on ebay for like $25... installed it plugged it in.. idles normal..
2003 F350 CC SB King Ranch - 09/05-02/11 - SOLD
2008 F250 CC SB King Ranch - 02/11-Current
5" Flo-Pro Straight Pipe
S&B Intake
Livewire w/ IDP, Gearhead and KEM
p8ntballn2 is offline
post #5 of 9 (permalink) Old 11-30-2011, 08:37 AM
Yep your right sorry, it is that last one that does it, in case anybody else has an issue also, if you take them out and do not turn them off with a tuner the vehicle will start once after you tune or return to stock then will not start again after that
PaulBoss is offline
post #6 of 9 (permalink) Old 11-30-2011, 09:15 PM
awesome thanks guys so there are 3 of those sensors and if i reinstall the furthest one back thats the one i need right
post #7 of 9 (permalink) Old 12-01-2011, 08:55 PM Thread Starter
Yup turned out I ruined the sensor when I got it out... Didn't thinkg I was that rough with it but obviously they aren't very hearty parts. Got a new one from the dealer and it runs like a dream.
Jason
Wife's truck:
jd99psd is offline
post #8 of 9 (permalink) Old 02-06-2013, 11:40 PM
Same Problem!
I just installed a 4" stright exhaust this past weekend from the down pipe back... I used my SCT tuner and programed a simple "street" tune with
DPF deleted, EGTs ON, No new tires, and NO EGR mod.
She's idling around 950-970!
I've read above and even hooked up the rear (3rd) "secondary EGT" sensor, used the monitor function in the programmer and observed the EGT sensor display current temps. The MAIN EGT must be up on the manifold or something.
Why would this solution work since when you select "deleted DPF" I'm assuming the tuner will program the truck NOT to use any of the three "secondary DPF" sensors?
Short of ordering a custom tune I don't know what to do. The truck ran fine with the different tunes before the exhaust mod. I have no CELs and she runs fine... just idles too high!!
Vicseek is offline
post #9 of 9 (permalink) Old 03-08-2013, 02:29 AM
srjd's Avatar
Do yourselves a favor and grab some custom tunes they don't have to be high hp. I thought those canned tunes were terrible
srjd is offline
  Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 6.4L Upgrades and Aftermarket - Engine
